Author Topic: 2007 norge no start blown fuse  (Read 3172 times)
Offline delrod
« on: June 04, 2026, 05:50:39 PM »
Had a no start/nocrank event on my 07 norge today. It turned out to be a blown fuse in the status interuptus circuit. 15 amp fuse was renewed and bike seems to start ok for now. Is the 15amp fuse appropriate? What fuse was recommended? Have ridden lots of miles and never experienced this I'm looking for a path forward
Doug in Pittsburg KS
2003EVT
Offline DoubleGuzzi
Re: 2007 norge no start blown fuse
« Reply #1 on: June 04, 2026, 06:49:12 PM »
Sounds like you are borderline with that fuse rating, when an unusual event occurs. Personally, I'd move to a 20A and keep 25A as a value of "last resort".
What's the mileage? You might ask what caused more current to be needed - worn/sticky starter motor brushes for example. A "sticky" starter motor will need/draw significantly more current than one in good condition. Your bike battery should be capable of delivering 10 times that amount for a short duration (cold cranking current).  Check that you have good connections at the starter motor, particularly to frame/engine ground.
« Last Edit: June 04, 2026, 07:00:25 PM by DoubleGuzzi »
Nearly natural progression..
Online michaell32
« Reply #2 on: June 04, 2026, 07:19:33 PM »
I am not familiar with the starter interuptus circuit but going to a larger fuse is never a fix, especially if that fuse is rated for higher amperage than the wire because it defeats the purpose of preventing electrical fires.  If the 15A fuse worked for years do not go larger.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
« Reply #3 on: June 04, 2026, 07:22:44 PM »
All you have to do is SEARCH, well documented in print what size I sure cant remember. Might even say on MPH website
Offline ridingron
« Reply #4 on: June 04, 2026, 09:11:33 PM »
Wow! I didn't know they were still in business.
