Author Topic: 98 V11 EV no spark, ECY 3 pin not connected?  (Read 3836 times)
Offline bputney13
« on: June 18, 2026, 09:17:31 AM »
Hello,
My new-to-me 98 V11 EV is not getting spark at the plugs, has 12v at the positive wire going to the coils and no voltage going to the neg wire going to the coils.  Is that correct?  Also, a three pin plug coming out of ECU (White, purple and blue wires) is not connected to anything (where does this go?) and I have a three pin plug nearby that has a yellow wire that loops back into the same three pin plug.  How do I use these two, three-pin plugs?
Thanks,
Brett
Online michaell32
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Re: 98 V11 EV no spark, ECY 3 pin not connected?
« Reply #2 on: June 18, 2026, 12:01:40 PM »
That 3 pin is the diagnostic plug & the other is plugged into it to give you the diag flashes on an LED light by corner of seat bracket. It flashes to give you a code or not a code. You need to read the FI manual. ECU sends power to a ignition relay. There are safety switches also, like on sidestand.
https://www.guzzitek.org/atelier/gb/1000/ECUP8(I_GB)MAJ02.pdf
« Last Edit: June 18, 2026, 12:23:07 PM by guzzisteve »
Offline antmanbee
« Reply #3 on: June 18, 2026, 11:10:18 PM »
Also check and see if the injectors are squirting gas. If not, with no spark and no injector gas the cam position sensor has probably failed.
Online Wayne Orwig
« Reply #4 on: June 19, 2026, 07:26:04 AM »
There are TWO timing sensors on that bike. If they get dirty, which is common, then there is no spark of injection.
