Author Topic: 1400 Switch Gear Update  (Read 10071 times)
Online TN Mark
« on: July 28, 2026, 03:19:49 PM »
The RH switchgear on my 2016 Eldorado has now been superseded to the updated RH switchgear on the later model 1400's. The issue is the original RH switchgear (2D000229) has the Cruise Control on the RH side. The updated RH switchgear (2D000673) does not have the Cruise Control button.
Apparently, the only actual option is to upgrade both the RH and the LH switchgear which has the Cruise Control on the LH side. Or, find someone with an original RH side switchgear.
I don't need new switchgear. My Eldorado only has 3,000 miles on it. But, the original switchgear seems like the cheapest Chinese junk switchgear Piaggio could source. I seems like it could give up early.
Has anyone been through needing to update to the later 1400 switchgear? I'm 'guessing' that if I upgraded both sides, they's still plug in and everything would work.
Is that true?
« Last Edit: July 30, 2026, 09:58:31 AM by TN Mark »
Online TN Mark
Re: 1400 Switch Gear Update
« Reply #1 on: July 30, 2026, 11:24:48 PM »
If Google AI is to be believed, RH updated switchgear 2D000673 does in fact have the cruise control function and is compatible with a 2016 Eldorado. Plus it retains the DRL function. Guzzi also made a matching LH side under item number 2D000672. This LH side also retains the heated grip function. Both of these item numbers are supposed to plug and play into the existing 2016 wiring harness without issue.
The reason for the change according to Google AI? The seam molds were changed and a seal was added to prevent water intrusion into the original switchgear which caused corrosion issues.
Online Moparnut72
« Reply #2 on: July 31, 2026, 09:19:48 AM »
I had a 2016 Audace. The cruise on mine was on the right side. I hated it there as the throttle was so sensitive that it was hard to set the exact speed desired. The button was kind of recessed which made it even worse. I always thought that that was the reason the cruise button was moved to the left side on the 2017 models. If there were an up or down speed button it would have been no big deal but it was a set and done. My '26 Special is back to the cruise button on the right side but the button is much easier to reach and use.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online TN Mark
« Reply #3 on: August 01, 2026, 11:54:37 AM »
Yes, the one ‘nit’ I have regarding my 2016 Eldorado is the switchgear. It feels as low budget as Piaggio could possibly find. I use my left hand to set the cruise button on the RH switchgear.
« Reply #4 on: August 01, 2026, 03:52:43 PM »
Mark,  you also have to change the demand sensor for throttle to work then a late map. Will the dealer up there do it for you?
Online 2dogs
« Reply #5 on: August 01, 2026, 05:17:50 PM »
Only MG would  put cruise control on the throttle side controls
« Reply #6 on: August 01, 2026, 05:55:04 PM »
The Chinese have no issues using it.
Online Moparnut72
« Reply #7 on: August 01, 2026, 09:06:56 PM »
I did the same thing. I should do the same thing on my V7 although the button is larger and closer to the grip. On the Audace the button was also recessed making it impossible to acuate with gloves.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Online TN Mark
« Reply #8 on: August 01, 2026, 09:18:21 PM »
My Eldorado has the GTM PC-V fueling system and a full GTM exhaust system. Both are absolutely perfect IMHO. The map GTM put into the PC-V works perfectly. It’s also matched to their exhaust system. I’ve only ridden one other 1400, a box stock 2014 CA Touring. The OEM fueling on that bike was horrendous and soured me on the 1400 line. Then I read every post I could find on the subject. There were three black Eldorados available when I bought mine. The GTM fueling system addressed one of the two major issues I had with the 1400. The GTM exhaust system addressed the second. I hated the OEM exhaust note. I found it as embarrassing as the meep meep OEM horn note. Plus it also had most of the OEM accessories I wanted.
I did buy a demand sensor to have on my parts shelf should that need arise. After having my local Cleveland, TN dealer reset the fault codes, I’ve had zero SERVICE light issues. It’s been perfect in dozens of starts and about 1300 miles.
Although I’m still a couple weeks away from being able to ride again having full left knee replacement a month ago.
« Last Edit: August 02, 2026, 07:11:37 AM by TN Mark »
Online TN Mark
« Reply #9 on: August 01, 2026, 09:20:11 PM »
My Victory has the cruise controls on the RH side and they work perfectly. Easy to get to without issue. The Guzzi recessed button was simply a dumb choice on their part. It ‘may’ have been better had they switched the position of Hazard button and the Cruise button.
« Last Edit: August 01, 2026, 09:24:54 PM by TN Mark »
Online TN Mark
« Reply #10 on: August 04, 2026, 10:37:19 AM »
Well, Google AI is most certainly a crap shoot. I much prefer Grok. I have seen both the 2D000672 and 2D000673 for sale online. The RH side will not accommodate the 2016 throttle cables. Plus the RH side has Mode and the LH side has Cruise. So, plug & play seems like it wouldn’t work either.
To make matters worse, Piaggio also lists the updated RH switchgear, item 2D000673, as ‘New Cruise’. So, it seems, they may have two distinct parts under the same item number.
The original LH side for the 2016 is still available from Piaggio. But, if they actually did made a new style RH side, then they’d need a matching LH side as they look quite different.
If anyone needs a RH replacement, perhaps used is the only option.
I don’t really blame Piaggio because my Eldorado is 10 model years old. They moved on from any 1400 support years ago. But, superseding to a part that just wasn’t designed to work is quite a lazy approach.
« Last Edit: August 04, 2026, 11:50:13 AM by TN Mark »
Offline Motormike
« Reply #11 on: August 04, 2026, 03:55:18 PM »
Sounds a bit like the oil sender unit on the V11's and Griso (and other Carc Guzzis, I suspect).  The superseded part doesn't fit the electrical harness!  They expect you to cut off the plug and wire in the correct one. Not that the correct one is included with the sender or anything.  Fortunately, the older sending unit was used on various BMW applications and is readily available. The joys of out-of-production motorcycles.
Offline Bill W
« Reply #12 on: August 04, 2026, 06:17:12 PM »
Sooo Happy I have a parts bike!!!
Offline moto-uno
« Reply #13 on: August 07, 2026, 11:04:18 PM »
  FWIW , the switches on my 2018 Eldorado , like the alternator,  were all made in China or Hong Kong and came in packs of 5 (usually) for under $15.00. The entire alternator , which I
replaced under warranty myself turned out to cost $212 Canadian delivered ( it was marked on the container it was shipped in to be $1200 retail.) . I could go on , but I did love that bike !
Online TN Mark
« Reply #14 on: August 08, 2026, 09:33:58 AM »
The original item numbers for a 2016 Eldorado and prior  appear to be:
887795 LH side
887796 RH side
Each about $150 and available.
