Author Topic: White Diamonds Metal Polish  (Read 2988 times)
kballowe
« on: August 01, 2026, 03:39:38 PM »
I stripped these ugly fork legs a year ago.  Sanded and then polished with White Diamonds metal polish.  It's a year later and they are still nice and shiny.  The only thing I've done is wash the bike like normal.
I DID give them the "once over" today when I installed Progressive cartridges.
Here's one picture from October 2025
« Last Edit: August 01, 2026, 06:06:02 PM by kballowe »
Re: White Diamonds Metal Polish
« Reply #1 on: August 02, 2026, 09:17:58 AM »
Hey, Good Stuff! It even takes out scratches on headlight clear plastic on newer cars.
kballowe
« Reply #2 on: August 02, 2026, 10:15:48 AM »
I used Mother's Billet Aluminum polish for years, but the White Diamonds lasts a lot longer.
The Mother's has a bit more aggressive cut than the White Diamonds and so I sometimes use it first and then finish with the White Diamonds polish.
Offline bigbikerrick
« Reply #3 on: August 02, 2026, 11:28:51 AM »
that looks real nice. Did you do it by hand or did you use a buffing wheel?
Rick
kballowe
« Reply #4 on: August 02, 2026, 06:29:35 PM »
Rick
I initially hand sanded the fork lowers, starting with 220 and finishing with 1000.
After than I used a foam pad on the end of a drill with the polish.
MasterPro Refinishing 6 Inch White Polishing Pad - 67-960
https://www.oreillyauto.com/detail/c/masterpro-refinishing/masterpro-refinishing-6-inch-white-polishing-pad/mpr4/67960?q=foam
A couple drops of Dawn in a squirt bottle helps to keep the black crud down to a minimum.  Just spray a little every now and then while polishing.
The same thing works well for most any aluminum polishing.
« Last Edit: August 02, 2026, 06:40:39 PM by kballowe »
