Startus Interruptus
Topic: Startus Interruptus (Read 249 times)
Yo Man
Hatchling
Startus Interruptus
August 12, 2026, 07:49:47 AM »
Having a little trouble with starting my '09 Stelvio. When I hit the start button it usually springs to life but sometimes there is a delay of a few seconds before the starter kicks in. I did the Starter Interruptus fix as recommended by those in the know and also put a new battery in along with cleaning up my battery connections. So what could the problem be? Starter relay? Thanks.
paulbricey
Hatchling
Re: Startus Interruptus
Reply #1 on:
August 12, 2026, 09:53:43 AM »
Beyong more connection & earth checking solutions.........I have 09 Griso 8V and after 9 years no probs I got starting probs....I went for the 'Ver2' of Startus Interuptus with new starter relay down next to the Starter Motor (along with new Yuasa, bigger fuses etc) & I still get odd starting probs (OK after a few goes still) that I put down to solenoid despite trying to clean solenoid several times....I'm thinking it's just getting old & if it gets bad I'll just throw a new starter & relay in.
Riding to live
Yo Man
Hatchling
Reply #2 on:
August 12, 2026, 11:11:55 AM »
Looks similar to what I did. Does the original stock starter relay still have a role to play or does this completely bypass it, anyone?
guzzisteve
"Just Ride It"
Reply #3 on:
August 12, 2026, 11:18:38 AM »
If all else fails(Guzzi's wiring engineering) make a hot wire button. Strait from batt + post strait to the solenoid. Funny, this always works when their crap doesn't. That's cause you get rid of all the lectrical crap in the way.
paulbricey
Hatchling
Reply #4 on:
August 12, 2026, 11:41:18 AM »
Believe it just uses the original solenoid feed as trigger for a new 12V supply (fused). It's here
https://www.grisoghetto.com/t6354-startus-interruptus-fix-2
Riding to live
Yo Man
Hatchling
Reply #5 on:
August 12, 2026, 02:32:41 PM »
So if that relay is not working as it should the new Startus Interruptus fix would be effected, unless I'm not understanding, which is likely.
Startus Interruptus
