Author Topic: Melted plastic bag  (Read 416 times)
Offline YellowDuck
Melted plastic bag
« on: August 16, 2026, 07:37:50 AM »
Someone took my V7 stone for a ride and had an unfortunate encounter with a plastic garbage bag that blew off of a truck.  A bunch of plastic got melted onto one of the header pipes (matte black paint).
We got most of it off using WD40 and a plastic putty knife, but there is some that seems to be resistant to softening.  What should we try next?  AI says acetone but I'm skeptical.
Offline DoubleGuzzi
Re: Melted plastic bag
« Reply #1 on: August 16, 2026, 07:51:07 AM »
It's possible, as acetone does eat some plastics: I used it regularly in a lab. from a plastic bottle, YMMV. Borrow some nail varnish remover, or perhaps (being PC) you have some yourself. Better keep some PJ1 black paint at the ready.
Good luck.
« Last Edit: August 16, 2026, 07:51:53 AM by DoubleGuzzi »
Nearly natural progression..
Online Moparnut72
« Reply #2 on: August 16, 2026, 09:17:22 AM »
Test the acetone on the bottom or the backside out of view location. I have used acetone to remove stuff from paint in the past but it needs to be tested. It will eat some paints and not others.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline mhershon
« Reply #3 on: August 16, 2026, 10:19:18 AM »
I had good luck with coming back from a ride, jumping off the bike and scraping the residual plastic off the pipe with a wooden block or a wooden yardstick in the tight places. My headers are Ceracoted, not painted, so I can't touch them up, but the scraping with wood took the clumps of plastic off....bit by bit. Patience helps.
Online SIR REAL ED
  • uh.... it's personal....
« Reply #4 on: August 16, 2026, 10:34:33 AM »
After scraping with a paint stirrer when the exhaust is hot, I would go with a rag soaked in acetone while the exhaust is still warm.
Perhaps before using acetone, do the same with a rag and some penetrating oil.
I would expect to have to re-paint the exhaust in that area.  I would think that anything that removes the plastic will take the paint off with the plastic.
2019 Beta EVO 250
Offline danomar
« Reply #5 on: August 16, 2026, 03:45:13 PM »
Acetone can help get it started.
If the pipes have the satin finish, I believe WD-40 can get some of the gunk off.
Otherwise, heat will eventually burn off most of the plastic but it will look unfortunate until then.
Offline malik
« Reply #6 on: August 16, 2026, 06:07:47 PM »
Melted shoe rubber/plastic can be removed with oven cleaner - but do note that that stuff is viscious & needs careful watching.
If once the plastic is gone you're not happy with the possibly leprous look of the paint I do recommend ceramic coating - the proper version with the bath & an oven, not just painted on. It's impervious AND good for the engine AND the headers cool down significantly quicker. It does cost, but it is a one-off.
Offline slowmover
« Reply #7 on: August 17, 2026, 08:57:43 PM »
Just the heat from the pipe will eventually make it go poof. It did on mine
Offline jrt
« Reply #8 on: August 18, 2026, 06:16:15 PM »
ABS will dissolve in acetone, but polyethylene or polypropylene will not.
Lego bricks (the toy) are made of ABS- you can make a paste from it to repair some plastic parts and often even color-match.
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Online PeteS
« Reply #9 on: August 18, 2026, 06:29:24 PM »
^^^^This^^^^
You can speed it up with a propane torch.
Offline YellowDuck
« Reply #10 on: August 19, 2026, 08:27:37 AM »
Thanks guys.  It has indeed been improving over time.
