You stripped the fork cap, there is no pinch bolt on the top only the bottom tree. Cap is softer than the tube, get a different cap. Make sure you clean out material from threads in tube and replace cap. If metal goes in the tube you need to remove tube and clean out w/fuel, then add more oil & put back in the upper tree. Where in IL you from? I had a Guzzi shop in Kingston north of DeKalb. If you need someone to do this, there is Joe (the Guzzi Dr) on north side of Chicago. I been down here 21yrs.
If you were trying to pull fork tube up into top tree you can't use cap to do so, it will strip. you need one of these.It is a slide hammer I made to pull tubes into the cone shaped top tree
That would be a costly thread chaser if they make one that big. Stick a rag in tube so you can pull out or vacuum chips. Then use a pic in the threads.
Wow, thank you Charley, not as bad as I thought. But then I have the slide hammer so never happened to me or customer bike.You save the day ALL the time!!!!!!!
