Author Topic: V85tt clutch vs arthritis  (Read 18524 times)
Offline guzzimaster
« on: August 26, 2026, 01:46:20 PM »
 :weiner: Arthritis is making it very difficult to ride these days. I've got a new-ish cable and I'd like to oil it! Can I oil these new tangled cables? With what type of oil? Oh god - an oil question  :violent1:  I'm going to carefully inspect the cable routing and finesse the adjustments as well. Lubrication is my main ?  TiA
MotorOverTimeObedie ntly GasUpZigzagZoomInde finetly
'74 California "Santana" / 2020 V85tt "Liberty / 2014 California Custom "Black Pony"
Offline Huzo
Re: V85tt clutch vs arthritis
« Reply #1 on: August 26, 2026, 02:56:04 PM »
Try untangling them first, but failing that, they run dry.
The clutch on the ‘85 is usually very light.
Offline MarinerRime
« Reply #2 on: August 26, 2026, 03:41:55 PM »
Maybe something like Drislide bike aid? It's a moly dry lube so it should be OK with PTFE cables and not get gunked up. I have severe rheumatism and a 82 Bonneville with a clutch cable that gives me a hard time now and then and it's worked for me till recently. I'm about to install a new cable from Venhill and if that doesn't help I'll find a kit to convert it to a hydraulic at some point.
 :bike-037:
Offline Perazzimx14
« Reply #3 on: August 26, 2026, 03:42:56 PM »
Spendy and I don't know f they make a kit fo it but if Rekluse does make an auto clutch for your bike it'll eliminate 99% of you clutch pulls. Roll on/off the throttle and snick up/down through the gears w/o touching the clutch lever.
Offline Perazzimx14
« Reply #4 on: August 26, 2026, 03:44:30 PM »
Teflon lined clutch cables do not get any lube. Doesn't matter if it dry or wet lube they get zip, zero, nadda, nothing!
Online bad Chad
« Reply #5 on: August 26, 2026, 04:55:42 PM »
I don’t know if they changed the clutch at all. I don’t think so on the V 85 2025 and up years, but my 25 has a very light pull.
1988 YX600 Radian
Online faffi
« Reply #6 on: August 26, 2026, 05:13:29 PM »
Not able to help you with the clutch issue, but I will share with you how I went from chronic pain to no pain in my hands on normal days, and only mild discomfort after a long day working with my hands, like laying a new roof or building a shed etc. It was so bad, that on my BMW F800ST that in typical BMW fashion require a button to be pushed on the right hand pod to turn off the indicators, I had to reach over and push the button with my left hand.
Before, after such endeavor, I could barely sleep due to my hands hurting really badly, a condition that became progressively worse over 10-15 years. I then tried stem cell treatment, which basically is they drain some of my blood, spin it and inject the supposedly very good remaining blood plasma directly into my joints. That helped noticeably, but on the fifth and sixth treatment I felt no benefits, so I stopped that 3 years ago. I also did some exercises advised by my doctor that you can see here (in Norwegian, unfortunately, but you do not need language to understand https://www.google.com/search?num=10&sca_esv=2b9577dc054dfb30&sxsrf=APpeQnuMAFOzMrGnput8F0N37HEdLSPpxg:1787781864208&udm=7&fbs=ABfTbFVyMZGZf1hfvX9uKjN_-G8c4u0nXx4bEIpwm1lnNH832cSpkWkfSwsmpNIrD_OQ-UdFAe4qAwsQWVbrtprjzBSpnJQOWUbUFy0AZP2fc5_e7wQK9SpSaccWZEM8174slgzA7lL9Jp-FedBms3jKtDYRkzLfYMnDYMy5pBIIBgIQaS46ps0&q=h%C3%A5nd%C3%B8velser+ved+artrose&sa=X&ved=2ahUKEwjbts63pr-WAxVFFBAIHesZAlsQtKgLegQIGRAB&biw=1536&bih=695&dpr=1.25#fpstate=ive&vld=cid:efdb227d,vid:w2SN_GsB3jw,st:0 )
These also helped, but I do not do them any more. What for me turned out to be the cure, was to lift a steel ball - either size tennis-ball or a much larger one, I alternate - and hold between 10 and 60 seconds. It should be so heavy that I cannot grip it anymore. I do one set once per week, that is all, I can now hold 150 lbs with one hand for up to a minute on a good day with one hand. I do not know why it works, but it does. And if I have the odd bad day, I can just do this static lifting and all or at the least the majority of the pain is gone.
Current bikes:
2002 BT1100
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline ridingron
« Reply #7 on: August 26, 2026, 10:45:27 PM »
Some of you guys need to come into the 70's about oiling cables. When you get to the 70's we''ll work on the 80's, 90's and then the 21st century. Then we'll work on front brakes and "layin' 'er down".
« Reply #8 on: August 27, 2026, 12:10:38 AM »
I have been lubing the cables they say not to lube for over 40 yrs, it is all BS. Use the correct lube & no issues. Petrochem  or Lube 1 by Slick 50.
WD40 and like will screw them up, you can't be cheap.
Sorry to here about the arthritis, my wife has it in her knuckles & I have to scrub pots & pans for her.
Online Moparnut72
« Reply #9 on: August 27, 2026, 08:56:18 AM »
I would try Tri-Flow. Expensive but works well. We used it in the airplane for issues like this. Not much to lose other than a cable.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline DoubleGuzzi
« Reply #10 on: August 27, 2026, 09:13:53 AM »
For decades, I've used 3-in-1 oil dripped into cables.  :shocked: Managed to free up a few cables, including a seized with rust throttle one.
Nearly natural progression..
Online BMCMOTO
« Reply #11 on: August 27, 2026, 11:03:14 AM »
You might like to take a look at this thread and consult a parts manual to see what clutch you have. From around 30 lbs pull to 11 lbs pull!
https://wildguzzi.com/forum/index.php?topic=124796.msg1921338#msg1921338
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline guzzimaster
« Reply #12 on: August 27, 2026, 01:58:40 PM »
Thanks for all your advice & ideas.  The bike is a 2020 V85tt. I believe it has a light clutch pull, but I've never been able to compare it to another V85tt.  My issue may be arthritis,  but anything i can do to make the clutch pull lighter would extend my riding days.  Backstory:   :popcorn:  FYI.  I always ride 2 up, rarely off-road,  dry weather conditions,  very little freeway speeds, and I'm 70.  At 14k miles (2023), the original clutch cable snapped inside the housing about 8" back from the trans. It looked very dry and crunchy, not rusty. There were no areas of kinking, rubbing, or pinching that i could find, and I did pretty extensive investigation.  Course nobody stocked a cable anywhere in the country  :thewife: and I waited for 2 months  :boozing: for an OEM replacement!
Loved getting some ideas from you all - but honestly,  most of them conflict leaving me more confused than when I posted the question.   :drool:  but thanks for trying. I need a ride!   :bike-037:
Online n3303j
  • Ron Cichowski
« Reply #13 on: August 27, 2026, 03:03:17 PM »
From my FWIW department Teflon is a really inert substance. You can dump pretty much whatever you want on it at room temperature and it will do no harm. I always lubricate cables in Teflon lined housings. Cables are multistrand construction. As they curve around bends in the cable housing the strands will rub against the adjacent strands. Oiling the cable helps lessen some of this friction. If the cable is steel the oil also reduces rusting. ACF 50 is my choice because it is extremely penetrating, doesn't get stiff in the cold, inhibits corrosion and comes in a nice can.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline 73 sport
« Reply #14 on: August 27, 2026, 03:36:34 PM »
   On Google, type in "Motorcycle Control Cables". There are the US companies that tha will make what you need.
Offline ridingron
« Reply #15 on: August 27, 2026, 09:53:15 PM »
I have found that AF1 has quite a few parts in stock. Their site is a little bit clumsy to use for looking up parts but doable. Looks like they have one in stock which doesn't matter since you got one elsewhere.
https://www.af1racing.com/2b005851-cable-embrayage-2b005851
Online Vagrant
« Reply #16 on: August 30, 2026, 08:29:07 AM »
This came up on ADV rider or Guzzi tech a few weeks ago. Somebody found a new clutch lever that was claimed to reduce effort by 50% or so. I'll post the info if I find it again.
Maybe someone else here saw it too and remembers.
Online Vagrant
Offline DoubleGuzzi
« Reply #18 on: August 30, 2026, 10:34:53 AM »
Ever so tempted to pull the trigger on that clutch lever. However, being that I usually spend only a quarter of the cost, for both brake & clutch levers, I'd like to see some specific feedback on the product. The claim of (up to) 70% reduction is quite a bit more than 50%. :undecided:
(In my case it'll be for the V7III.)
« Last Edit: August 30, 2026, 10:56:01 AM by DoubleGuzzi »
Online n3303j
  • Ron Cichowski
« Reply #19 on: August 30, 2026, 10:43:45 AM »
From what I understand levers are a direct ratio thing. If you reconfigure for half the effort you will cut the moved object's distance traveled in half too.
Looking at 70% reduction in effort would lead me to conclude 70% shorter travel of the lever at the transmission.
Is 30% of the original design travel enough movement to guarantee complete engagement and release of the clutch plates under all operating conditions?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline DoubleGuzzi
« Reply #20 on: August 30, 2026, 10:58:20 AM »
Assuming your assumption is correct, that's a fair point. The clutch arm doesn't move very much as standard, from what I've seen.
 :popcorn:
Offline Guzler
  • 1977 850 T3
« Reply #21 on: August 30, 2026, 04:21:24 PM »
Zoom Spout Turbine Oil (from HVAC days) is the best in the world for electric motors  and cables. It never gums up or stains.
