Author Topic: Need help and advice  (Read 26379 times)
Offline willowstreetguzziguy
« on: August 27, 2026, 07:05:16 PM »
My 2008 1200 sport was running fine except for half throttle surging and backfiring between 3000 and 5000 RPMs.So I had an appointment set up today with a Moto Guzzi dealer. All I wanted them to do is check the throttle bodies and see if there was an updated map that could be installed that might help cure the surging and backfiring.
After their first attempt, the bike was running worse. The back fairing was even worse. They said there wasn’t much needed as far as the balancing of the throttle bodies but there was a rubber cap missing on one of them that they replaced.
So I took it back and explained the situation and after their second attempt, they noticed that the “sacred screw” had somehow at some point in time, had been turned all the way in! They said they backed it out to where they thought it should be, but couldn’t guarantee anything and then adjusted the throttle bodies again. After taking it out for a test ride, the bike stalled several times and was idling at around 1000 RPMs
Going back again, they tried to adjust the idling at the throttle grip and now it’s fluctuating idling anywhere between 1200 and 2000 RPMs. (it’s no longer stalling) It was at the end of the day so I rode it home. The bike is backfiring whenever I let off the throttle at any rpm. It’s running worse than it ever has!
On the ride home, I stopped by a friend of mine who is experienced with motorcycles, once he learned that the sacred screw was turned outward, and listened to my bike going down the street, he said I would turn the screw back into where it originally was and see what happens. And adjust it from there.
I’m not quite sure the location of that screw if it’s on both throttle bodies or just the left one? The service guy pointed into the left throttlebody. Does anybody have any advice that will help my bike? You can imagine how bummed out I feel!!!
2008 Guzzi 1200 Sport
Online Tkelly
Re: Need help and advice
« Reply #1 on: August 27, 2026, 07:21:25 PM »
Maybe a tps issue?
« Reply #2 on: August 27, 2026, 07:37:55 PM »
Maybe a tps issue?
Let me first say that the dealer originally spent about an hour working on the bike. And charged me for that amount. The second and third times he worked on it amounted to probably three hours of time which he did not charge me. I could tell that they couldn’t wait to get me out the door because the longer they worked on my bike the more money and time they lost. I left and rode home in torrential rain with it running terribly. So my question is…If it is a TPS issue… Would you
1. Call the dealer up and explain the issue and how badly it’s running and see if they can try and fix it for a fourth time?
2. Go to another dealer and see if they’re able to figure out the problem on their own?
« Reply #3 on: August 27, 2026, 08:11:22 PM »
Maybe I should call the dealer tomorrow morning and say…
“Ever since you backed the sacred screw out and synchronized the throttle bodies, it pops considerably more and surges between 3,000 and 5,000 RPM. It actually ran much better with that screw all the way in. Could the TPS baseline now be incorrect because the bike had been set up around that screw position years ago?”
Any thoughts?
Offline CoolBreezeBreva
« Reply #4 on: August 27, 2026, 08:23:27 PM »
Where do you live? If near Ohio go to Cadre Cycle. If you're in the Northeast go to Hamlin Cycles. Either of these should be able to sort. If not maybe get a set of used throttle bodies off of Ebay or something and put them on and go from there. How is the compression on the motor? Have the plugs recently been changed? Best advice I can come up with off the top of my head
Offline 73 sport
« Reply #5 on: August 27, 2026, 08:30:43 PM »
   Call Charlie Mullendore at "Antietam Classic Cycle". He is in Rohrersville, Md., about 100 miles from Lancaster, Pa. If I cant fix something on my Guzzi, he is the only guy I would trust to work on my bike.
« Reply #6 on: August 27, 2026, 08:51:38 PM »
Anyone have his contact info?
« Reply #7 on: August 27, 2026, 09:04:30 PM »
He's no where near Cadre.
He's maybe equidistant between Kissel and Hamlin. I'd probably choose Hamlin if I was him, but it's a less pleasant trip.
The TPS COULD be the problem, but unfortunately you need to figure out the throttle body balance and sacred screw now.
Charlie is closest, but he restores old bikes (meticulously and he's an artist) but I've never heard of him having any interest in anything within a decade or two of this.
BTW, for the record, this was never a map issue and there's no new map, at least not one in the last decade or two. And if it ran fine until recently, a map change was never the issue.
Is it we're me I'd either start with a new used throttle body and linkage set OR put my faith in Jim Hamlin.
I wouldn't bother stopping at any dealer in between, especially considering the unbelievable incompetence he's already seen in a local dealer.
« Last Edit: August 27, 2026, 09:05:27 PM by Kev m »
Offline 73 sport
« Reply #8 on: August 27, 2026, 09:16:00 PM »
    You have a computer. you could look up Antietam Classic Cycle. The phone no. is 1-301-432-2275.
« Reply #9 on: August 27, 2026, 09:29:18 PM »
Unless you have a way to set the SS so it flows the same rate as the factory dictated, you are cooked.
I have a way of doing it, but I need a known good set to get a base line.
Then I can do it accurately.
Nothing you do with the TPS will matter a jot, unless you get the flow rate on the left TB correct.
Online John Croucher
« Reply #10 on: August 27, 2026, 09:53:05 PM »
The first place I would start is clean the battery terminal connections.
Then use a multimeter to check the tps for bad spots caused by wear.
« Reply #11 on: August 28, 2026, 07:24:46 AM »
What Huzo sez..
« Reply #12 on: August 28, 2026, 08:16:06 AM »
While I appreciate the shout-out, I am already overwhelmed with work and can't take on any more. I'm booked well into 2027 as it is. My 94 yr. old mom requires more assistance each day, leaving little shop time.
Online PeteS
« Reply #13 on: August 28, 2026, 08:21:38 AM »
+2. Were you able to observe the dealer doing the work? Did he have a device to balance the throttle bodies like carb stix or vacuum gauges? The mid range surging might be TPS but idle problems sound like the air bleed screw.
« Reply #14 on: August 28, 2026, 09:10:54 AM »
As with some dealers, the service manager was the go-between between me and the mechanic so they would bring it out and say they think they’ve got it right. I would take it out for a ride and know that it was way off and that happened three times. Call a well respected Moto Guzzi mechanic who may be able to look at it later next week. He’s familiar with my bike and I feel a little bit better, actually much better. Thanks for all your help.
« Reply #15 on: August 28, 2026, 09:30:06 AM »
There are some competent Guzzi mechanics that are not current dealers. Guzzi doesn't even have a dealer list on their website anymore that I could find.
« Reply #16 on: August 28, 2026, 11:24:00 AM »
I found a good one up in Marysville, Pennsylvania, and he’s gonna take a look at it.
Online AJ Huff
« Reply #17 on: August 28, 2026, 11:39:54 AM »
Boy they are heard to find though.
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
« Reply #18 on: August 28, 2026, 11:53:37 AM »
He should be able to put it back to factory, not that difficult. It's not rocket science, it's a motorcycle w/FI.
« Reply #19 on: August 28, 2026, 11:56:02 AM »
-AJ
You got a real good one, Jim
« Reply #20 on: August 28, 2026, 02:16:41 PM »
How does he achieve that ?
What I’ve done is as follows.
I got a pressure vessel from a compressor and fitted a water manometer with a top and bottom mark, they are about 1 metre apart. Then I fitted an outlet that allows me to attach a known good TB.
I bring the pressure up so the water manometer reaches just past the top mark with the TB attached and a rubber plug stopping the air escaping.
I then remove the plug and time how long it takes for the air to flow out through the TB and the water to pass between the top and bottom mark. Do several dump runs and find the median value.
Typically about 20 seconds.
Knowing that, I attach the molested one and test it. If it takes longer or shorter than the control unit, I adjust the SS to give the same reading.
You then have the same flow rate…
It works.
The flow rate is determined by the plate angle in your TB, that is the angle that the TPS recognises as 4.6 when you press “reset” during a tune.
What you are doing when resetting TPS, is “telling” the system that the plate angle is 4.6, you are not altering that plate..(you better not be…)
The right TB is then balanced to the left master TB by use of the appropriate adjuster and the appropriate air bleed is opened to set the idle balance.
The ECU then says…”ok, if that is 4.6, then I will adjust the pulse at the injector, to achieve the target air/fuel ratio (mixture).”
The idle is NOT set by the sacred screw, that is the task of the stepper.
Also.
While I agree it’s not rocket science, the components still have to obey the basic principles, like O rings and foam blocks, or there will be tears.
« Last Edit: August 28, 2026, 03:10:31 PM by Huzo »
« Reply #21 on: August 28, 2026, 04:30:07 PM »
Go ask Pete Roper. I already said how on here years ago, look it up.
It's my job to know this crap. At least I know who I am even though most here now don't, they run off all the real Guzzi techs that were on here w/their insults.
Online RinkRat II
  • Lake Powell AZ
« Reply #22 on: August 28, 2026, 05:16:06 PM »
  Perhaps a link to your procedure? Thanks in advance,
    Paul B :boozing:
Online AJ Huff
« Reply #23 on: August 28, 2026, 06:35:59 PM »
    Paul B :boozing:
https://wildguzzi.com/forum/index.php?topic=84631.0
Also, the long read
https://wildguzzi.com/forum/index.php?topic=106043.0;imode
Roper suggestion to buy a used throttle body is probably your simplest solution.
-AJ
'71 Ambassador
'05 Road King
MGNOC# L-753
Online TN Mark
« Reply #24 on: August 28, 2026, 08:56:33 PM »
Guzzisteve IS one of the few Guzzi gurus left here on WG. I’m as mad at the fools who ran off the other Guzzi gurus as I am at the gurus for leaving. Though the blame is quite easy to peg. And I fully understand why the gurus left.
Offline DoubleGuzzi
« Reply #25 on: August 29, 2026, 05:53:04 AM »
@AJ Huff.
Thanks for the links, I read both - very interesting.  :thumb:
Nearly natural progression..
« Reply #26 on: August 29, 2026, 08:21:46 AM »
I talked to Jim Hamlin yesterday and we set up an appointment for September 9 and he will work on it. 234 miles and 4 1/2 hours of riding but I feel confident he’s the right one for the job. I want to get my back in the best working order. Thanks for the recommendation.
« Reply #27 on: August 31, 2026, 02:52:40 PM »
After the ride home in torrential rain last Thursday from the dealer and it running like crap, I took it out today and when it’s warmed up, it’s icing at 3,500 rpm’s!
Since I’m riding up to Jim Hamlin’s on Sept. 8 to have it worked on the next day, mostly highway miles, is there an adjustment that I can make now on the throttle bodies to bring the rpm’s down from 3,500 to 1,200 rpm’s? If so, can someone describe where the adjustment might be???
« Reply #28 on: August 31, 2026, 03:42:40 PM »
Are you sure it’s not the stepper motor jamming ?
Also not trying to be funny under the circumstances, but can you fix where you say it’s icing ? I reckon you typed idling, but it auto spelled for you.
Icing is not impossible, but I know that’s not what you meant.
The idle is set by the stepper motor, if you have Guzzidiag, hook it up and see where your stepper is parked.
It could easily be not shutting down and consequently commanding a lean mixture, thereby giving the high idle.
Also, check the ball joints on the cross over link, they can become semi disconnected if they are old and hold the right TB too far open.
Did you say you checked the balance with a manometer ?
« Reply #29 on: August 31, 2026, 03:46:45 PM »
Sorry, I meant “Idling”. I don’t have Guzzidiag or manometer. I just thought there might be a simple, easy way to lower the rpm’s.
