Author Topic: V7 850 Brembo RCS master cylinder  (Read 3492 times)
Online MikeP996
« on: August 29, 2026, 12:26:59 AM »
I'm wanting to increase braking power at the front on my '21 V7 Special.  I have tried various brand pads with no significant effect.  Has anyone fitted a Brembo RCS brake master cylinder to a V7 850?  If so, what parts are necessary in addition to the master cylinder itself?  Any issues with the installation?  Thanks!!  :)
2021 Moto Guzzi V7 850 Special (UK)
1976 Honda CB400F (UK)
2017 BMW R1200RS (TX)
'73 Norton Commando (Mexico
2015 BMW R9T (Mexico)
(Wife's bikes:
2015 Ducati Diavel (TX)
2019 Honda Africa Twin  (Mexico)
2021 Honda NC750  (UK)
Online Dr. Enzo Toma
Re: V7 850 Brembo RCS master cylinder
« Reply #1 on: August 30, 2026, 12:01:14 AM »
Not a direct answer to your question, as I haven't, but I'll mention that Hamlin Cycles and GTM both have an offering of a higher spec Brembo master cylinder and 4-pad caliper.
2027 Moto Guzzi V7 Sport
MGNOC Member
Online MikeP996
« Reply #2 on: August 30, 2026, 12:29:11 AM »
Thanks!  The Brembo system GTM offers is the same one I am considering.  I have all the necessary components in my "basket" (master cylinder, reservoir, line extender, mirror adapter) but still trying to do research to see if it will make a noticeable improvement before spending the money!  ;)
FWIW, my V7 is in the UK so the (same) parts are from a UK supplier rather than GTM, etc.  The same Brembo RCS master cylinder that is $658 in the US (at GTM) is less than 400 USD in the UK!  Tariffs, I guess...
(Wife's bikes:
« Reply #3 on: August 30, 2026, 08:35:13 AM »
Hamlin's V7-850 brake mod is nothing short of amazing.  One had better be very skilled at performance riding as it's quite powerful.
Offline Vagrant
« Reply #4 on: August 30, 2026, 08:37:40 AM »
Will the stock ABS still work with that S/U? It will be needed!
« Last Edit: August 30, 2026, 08:38:02 AM by Vagrant »
Offline michaell32
« Reply #5 on: August 30, 2026, 10:10:18 AM »
A long time ago I used an Accosato on my GSXR. As long as you get the correct master cylinder size it should work just as good as a brembo.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Offline ridingron
« Reply #6 on: August 31, 2026, 12:16:21 AM »
What is the actual change?
Smaller diameter master cylinder?
Different calipers?
More aggressive pads?
2 rotors?
« Last Edit: August 31, 2026, 12:32:36 AM by ridingron »
Online MikeP996
« Reply #7 on: August 31, 2026, 02:14:19 AM »
I'm going to try yet another set of pads - EBC HH - to see if I can gain a bit more "bite" before I spend the money on changing the master cylinder.  They are allegedly the highest friction pads available...
(Wife's bikes:
Offline Vagrant
« Reply #8 on: August 31, 2026, 07:26:00 AM »
I'm 78 have arthritis in both hands and have had two carpal tunnel surgeries. I use EBC-HH in all my v7's and can stop at a max rate with two fingers. Flush the old fluid, scrub the rotor and break them in. You should be happy then.
Online MikeP996
« Reply #9 on: September 06, 2026, 07:21:46 AM »
 :thumb:  I'm a happy guy!!! the EBC HH pads made a huge improvement.  I cleaned the disc and then bedded in the new pads and for the first time I can actually apply enough brake to trigger the ABS on a dry road plus the initial grab is much better!  As Vagrant said, highly recommended!!!  Absolutely no need for a "better" (more expensive) mastercylinder!!! :grin:
« Last Edit: September 06, 2026, 07:22:57 AM by MikeP996 »
(Wife's bikes:
Offline Vagrant
« Reply #10 on: September 06, 2026, 08:24:59 AM »
They help the rear to just not as much.
