Author Topic: 73 Eldorado / Jawa sidcar  (Read 342 times)
Offline Wink
« on: September 15, 2026, 09:04:44 AM »
I attached a 74 Velorex Jawa sidecar to my 73 Eldo. The front fork springs are now
 too weak. Has anyone fabricated a preload or found stiffer springs that solve this issue? I have my forks disassembled for rebuild and hate to spend money on springs that won't solve the problem.  thank you for any help
Online DoubleGuzzi
Re: 73 Eldorado / Jawa sidcar
« Reply #1 on: September 15, 2026, 09:35:13 AM »
It's the big pillion that's the issue!  :wink:
Nearly natural progression..
« Reply #2 on: September 15, 2026, 11:28:39 AM »
If they're the original springs, then they are well past due for replacement. You can try the repro stock type springs which I've found to be quite firm: https://www.crustycycle.com/products/moto-guzzi-fork-spring-set-ambassador-eldorado-v700-12526600 . Or the Wirth progressive springs: https://www.mgcycle.com/index.php?main_page=product_info&cPath=197_199&products_id=1147
With either, use more fork oil than the factory spec. of 5.4 oz., I use 8 ounces. With the factory amount there is more than an inch of travel that is totally undamped. The extra amount also reduces the "air gap" in the forks, effectively increasing the spring rate.
Offline Wink
« Reply #3 on: September 16, 2026, 08:27:31 PM »
Thank you for the advice. The springs still measure 9” so I thought they were still in good shape. I’m going to order the progressive worth spring tonight. Think I should use 30 weight oil or automatic transmission fluid?
« Reply #4 on: September 16, 2026, 08:40:02 PM »
I've used 30w fork oil, 30w motor oil and 80w90 and they all work well. Never tried ATF,
Online Perazzimx14
« Reply #5 on: September 17, 2026, 04:19:31 AM »
ATF is reported to be equal to 10w so it'll be light in this application.
