Author Topic: V11 sport drive shaft  (Read 3177 times)
Offline nsmith
« on: October 14, 2026, 03:38:52 PM »
2000 V11 sport, changing rear tire so I figure its U-joint lube time. How the hell do I get the shaft out? Looks like the whole swing arm has to come with it.
Neil formally from South Dakota now living it up in Arkansas
Online 2dogs
Re: V11 sport drive shaft
« Reply #1 on: October 14, 2026, 04:07:28 PM »
Yep, my advice would be to join the hive at V11lemans.com
Offline nsmith
« Reply #2 on: October 14, 2026, 05:48:21 PM »
the "hive" at V11 LaMans  didn't help
Offline Motormike
« Reply #3 on: October 14, 2026, 06:06:19 PM »
The V11 I used to own had zerk fittings on both universal joints, plus the slide coupling.  The front one was a pain to get to. Had to remove the wheel and used a rigid grease extension.
« Last Edit: October 14, 2026, 06:07:24 PM by Motormike »
Offline Littlefield
« Reply #4 on: October 14, 2026, 08:59:23 PM »
I Googled ‘remove v11 sport driveshaft’ and quite a bit of stuff came up.
« Reply #5 on: October 15, 2026, 09:44:36 AM »
You must have done something wrong. I searched driveshaft on V11lemans.com and got 657 results. As far as I know, there is not a V11 sport problem that hasn't been solved there.
Offline Motormike
« Reply #6 on: October 15, 2026, 02:42:29 PM »
Still not sure why you want to remove the shaft.  Doesn't your V11 drive shaft have grease fittings like the one I owned did.  Never once pulled the shaft on mine and I greased the u-joints several times.  Like I said, that front one was a PITA to get to, but could be done with the rear wheel off so you could reach it from the rear of the bike.
Online john fish
« Reply #7 on: October 15, 2026, 04:40:22 PM »
No need to remove the drive shaft.  Use this for the forward grease fitting:
https://www.walmart.com/ip/CARBYNE-4-inch-Grease-Gun-Needle-Nozzle-Adapter/586753940?classType=REGULAR&adsRedirect=true
Or a bent one:
https://tinyurl.com/Bent-needle-thingy-link
It can spin out a lot of grease if you're messy.  IIRC (I sold my 2000 V11 Sport a while ago), some people will put some duct tape around the guard to check the grease.  I could be wrong about that.  :)
On a positive note, the V11 Sport was the last Truly Great Goofy Guzzi.  The last one designed in Mandello, I think.
He lost the run of himself.
Offline Motormike
« Reply #8 on: October 15, 2026, 07:02:19 PM »
On occasion, I miss mine.  But I was totally over the whole nylon fuel tank/ethanol gas thing.
« Reply #9 on: October 16, 2026, 10:27:28 AM »
Nope. You can't grease the front without pulling the driveshaft on the 2000 V11S.
The Kid said he couldn't do it on his Greenie at the time, so I tacked it with a grin. After all, I had done it on the 02 Scura many times.
I couldn't do it either.  :smiley:
Online john fish
« Reply #10 on: October 16, 2026, 09:58:28 PM »
Nope.  I've done it.
Offline Aldo
« Reply #11 on: October 20, 2026, 07:29:41 AM »
I have done it successfully without removing the driveshaft on both 00' V11 Sports I've owned.
« Last Edit: October 20, 2026, 07:31:13 AM by Aldo »
MGNOC Lifetime Member
1973 Eldorado 850
1971 Ambassador 1000 Automatic
1960 Gilera Giubileo 98
1967 Benelli Sprite 125
Online pressureangle
« Reply #12 on: October 21, 2026, 09:26:28 PM »
I didn't see any query there.
V11lemans.com
There are 2 bolts on each end yoke securing them to the splined shafts. Remove them with a straight 6mm allen, evenly rather than one all at a time. When they go back in, you have to be very careful to start the threads correctly; they're fine thread, hard to reach, and easy to cross-thread. Be certain the joint phasing is aligned after separating the halves and lubing the splines- the zerk doesn't do a good job alone. iirc they torque to ~35 lbs-ft, but verify that. There are a number of driveshaft-related threads on the V11 forum.
Offline Roman Hordan
« Reply #13 on: October 22, 2026, 06:34:25 AM »
Neil, you can lube that front joint without pulling the shaft, but it's fiddly. Aldo and John have both done it on their 2000 V11 Sports. Pull the rear wheel (you're already doing the tire) and use a long needle-nose or bent grease fitting adapter to reach the forward zerk from the back. Go slowly with the gun, because it will push grease out if you overdo it.
If you'd rather pull the shaft anyway, pressureangle's steps above are right. Just be careful starting the fine threads on those end yoke bolts, and check the joint phasing when you put it back together. While it's apart you can lube the splines properly too, which a zerk alone doesn't do well.
