Author Topic: Heated Grip problem V85TT  (Read 880 times)
Offline kennneee
« on: October 22, 2026, 05:16:28 PM »
Hi All- When I bought my 2025 V85 TT I bought the Oxford Pro Touring grips. I like that they have a button on the left hand grip which makes it easier to control instead of looking at the screen. I was also under the impression that they got hotter than the OEM version. I had BMW OEM grips on a few bikes and they got quite a bit warmer than the Oxfords. Fast forward 18 months and 17,000 miles and the right side grip has died. Just did 2,000 miles down to San Diego from Canada with a cold right hand (poor me:)). Anyway, Oxford has not been  helpful in getting a replacement right side grip even though they are supposed to be available. I know a lot of guys have had good luck with Oxford so I can't write them off completly but am I throwing good money after bad only getting 18 months out of them? At this point I am thinking of starting from scratch and shit canning the Oxfords and perhaps trying the Koso or? Any input appreciated. Ken
Offline n3303j
  • Ron Cichowski
Re: Heated Grip problem V85TT
« Reply #1 on: October 22, 2026, 05:48:43 PM »
I'm a fan of these heaters that are bonded to the left bar and the right throttle. $60 give or take depending. Have never burned out a set. Hi/Low switch. Low is warm, high is hot.
https://www.partzilla.com/product/aftermarket/3YK4-SYMTEC-210019RR?gad_source=1&gad_campaignid=21773042827&gbraid=0AAAAADro4Hv1_IuumzwJRpFMV2o9MLgEu&gclid=Cj0KCQjw6ObWBhDDARIsAFdfcUiYX2OeFQG01tklxgSB3EB7yfTE8t1MDcS7FzgmAWMuMPbeDyu2GIwaAkEvEALw_wcB
I install these units with leads facing outward. I file a notch in the end of the left bar and double the lead back on itself and into the bar, then out a hole midpoint in the bottom of the bar. The twist grip gets the same notch but that bar end gets a wide notch to clear the lead as the throttle is rotated. Wire is loose inside bar and throttle rotation hasn't hurt it yet. Makes for a clean looking install
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online Dr. Enzo Toma
« Reply #2 on: October 22, 2026, 06:21:41 PM »
I've had Oxford, Koso, OEM Ducati, OEM Honda, and now OEM Moto Guzzi grips on various bikes.
The only one I had serious quality issues with (so far) was the OEM Honda ones, which vary based on the bike, but it was the generic-type ones they repackage for a few bikes. The button failed and the grips didn't get hot enough. The others get hot enough with me accepting that at a point you just need hand guards, Hippo Hands, or insulated gloves to be comfortable. My Oxford Heaterz have probably seen the most use and are without issue other than that the left side one regularly comes unglued, which is a pattern for all except the OEM heated grips. For the Koso ones on my V7 Stone (installed by a dealership) the left grip cable pulled out of the backside of its plug (broke) and I ended up buying a whole new kit and replacing the whole setup, properly trimming the throttle tube to my liking with a Dremel on the second install. I would recommend checking the wires to see if any pulled apart. When I install heated grips I always tried to leave slack at various points in the cable run, especially some near the steering neck of the bike so it could be fed back to the grips for their removal, unlike many of the dealer installs I've seen where all the extra cabling just gets bundled up next to the battery. At times I've noticed limited availability of both Oxfords and Koso grips. When I bought that last set of Koso grips I actually bought them on eBay because I couldn't find any online parts stores with them in stock at the time. For another bike I wanted to install the Oxford Pros, but couldn't find them in the USA soon after their release so went with Koso instead.
I think many of the reviews you'll find of the Oxfords will be of the older units with the separate control panel, it's entirely possible that the updated ones with integrated button are a different level of quality.
2027 Moto Guzzi V7 Sport
MGNOC Member
Offline kennneee
« Reply #3 on: October 22, 2026, 10:17:13 PM »
Is there a control box for the Koso grips?  I see that there is a button on the left grip to set the temps but is there any other box involved? The Oxford grips have everything integrated in the grip. Wondering how much space the Koso grips need if there is a secondary box?
« Reply #4 on: October 23, 2026, 12:16:00 AM »
No control box on the Koso Apollos I have on my V7 (Part number 205332) but IIRC there are some slightly bulky spots on the cabling around the connections and the fuse. I was able to do all the wiring with the fuel tank lifted up and setting on a scrap of two-by-four, without fully removing or disconnecting the tank.
I suspect that if you search YouTube there may be some install videos of the Koso Apollo that show it better than the product sales pages.
MGNOC Member
Offline kennneee
« Reply #5 on: October 23, 2026, 08:37:28 AM »
I went on the Revzilla sight to see if there were any reviews on the Oxford Pro grips. Turns out there were around 4 reviews and they all had the right hand grip fail. One mentioned the lack of customer support from Oxford on this issue. I would advise giving this model of heated grip a pass.
Offline CanonVanagon
« Reply #6 on: October 26, 2026, 01:52:47 PM »
I installed the Oxford Pros on my 22 V7 in the fall of 2024 I believe. I had to order them from a place in Canada because I couldn't find them in the USA. I haven't had any issues with them. I would like them to have a little more heat but if I wear the right gloves they work fine.
Now I need to figure out what to put on my 25 V85tt. I installed the MIA device and the heated seat last week. The seat seems to put out a lot of heat.
22 V7 850 Stone
25 V85TT
Offline kennneee
« Reply #7 on: November 02, 2026, 08:23:33 AM »
Yes, that heated seat really cranks the heat. I never go above the 1 setting. Any higher and my butt will catch fire:).
Offline ridingron
« Reply #8 on: November 04, 2026, 11:58:22 PM »
Thanms for that link!
