Author Topic: Single Plate Clutch  (Read 1749 times)
Offline wirespokes
Single Plate Clutch
« on: October 27, 2026, 12:25:04 PM »
I'm wondering if a fix was ever developed for the single plate clutch. I've done minimal reading on the issue so wonder what the problem was - weak hub? BMWs have run a single plate clutch forever - what did Guzzi do differently? Why did they fail?
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Single Plate Clutch
« Reply #1 on: October 27, 2026, 01:01:52 PM »
Big blocks? Small blocks continue to use a single.
« Last Edit: October 27, 2026, 01:11:27 PM by Dirk_S »
Online SemperVee
  • USMC Retired
« Reply #2 on: October 27, 2026, 03:25:17 PM »
My 03 EV was updated to a extra thick single plate but with double the thickness of the original one.  That is what the fix was about.  Don't know more than that.  Quite happy with it. If you pull off the rubber plug on the RH side and look you can tell which one it is.
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Offline wirespokes
« Reply #3 on: October 27, 2026, 03:47:26 PM »
Yes, it's a big block - 2003 Stone, hydro. And yes, it's got the single plate clutch.
SemperVee - is the thicker clutch disc an OEM part? What's the story? How many miles on it now?
Online SemperVee
  • USMC Retired
« Reply #4 on: October 27, 2026, 04:40:41 PM »
Was updated under warranty when purchased and yes OEM part.
« Last Edit: October 27, 2026, 04:47:49 PM by SemperVee »
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
« Reply #5 on: October 28, 2026, 07:48:57 AM »
As far as I know, it was just a friction material issue. I believe Greg Field had some made with a better friction material.
Offline wirespokes
« Reply #6 on: October 28, 2026, 08:16:55 AM »
Thanks SemperVee and Wayne. That's good news. it's too bad Guzzi went back to the dual plate system.
Offline leafman60
« Reply #7 on: November 05, 2026, 07:59:38 PM »
I had a 2002 V11 Scura with the single plate clutch.  It was the best feeling clutch of any that I've known on a motorcycle.  The take-up was linear with a light action and it had such a good feel to it.
From what I remember, the problem with those bikes was not so much the clutch as it was the aluminum flywheel that was installed with it. Catastrophic pictures were plastered on the internet showing exploded cases from a disintegrating flywheel and clutch.
The pictures I've seen indicated that the bolts that held the flywheel to the crank appeared to loosen and wobble around in the bolt holes of the flywheel. Small stress cracks would be initiated and, like a rock ding on a windshield, those cracks would migrate out through the flywheel until such time that the flywheel came apart in pieces.
I rode mine for several years and put respectable miles on it with no problem.  I always felt that the way to deal with the problem would be to access the flywheel and install flat washers on those bolts to spread the stress and re-torque them with some thread locker.
Of course, that may have just been my dream and such may not have fixed the problem.  For most people, if they're going to the trouble to pull the flywheel, they're not going to risk having to do it again so they replace the aluminum flywheel and go back to the tried and true dual plate clutch.
Another less severe problem with those bikes is the transmission shift return springs could break so many people, me included, replaced the stock spring. While I was doing that, I readjusted the shift mechanism to put everything to shop manual specs and I filled the gearbox with some super slick oil. Not only did that Scura have the finest clutch of any bike of mine before or since, it shifted better than any other motorcycle of any brand that I have ever ridden and that includes my new V100 Mandello S.
An interesting thing about the Scura that I still remember is that I could take it out on a relatively level roadway, get it into 6th gear and take my hand off the throttle and let it coast down to idle- in 6th gear.  It would hang there in 6th at idle speed and chug down the road with no snatching or protest of any sort.  I could then gently open the throttle a small amount to initiate a gentle acceleration and keep easily opening the throttle until the bike would clear just over 140 MPH. I've never had any bike of any brand that I could do that as cleanly as that V11 would do.
With Gallaseti high pipe exhaust-
« Last Edit: November 05, 2026, 09:17:10 PM by leafman60 »
Offline wirespokes
« Reply #8 on: November 06, 2026, 09:58:24 AM »
Thank you LeafMan. The aluminum flywheel was an aspect of the problem I hadn't considered. Thank you for the data.
If the flywheel was getting loose, what would be the indicators? How could I tell without taking it all apart?
Offline leafman60
« Reply #9 on: November 06, 2026, 08:08:38 PM »
Yes, I contemplated that question back then. I would think you would notice some sort of sound or feel but I'm not sure. A Moto Guzzi drivetrain makes a lot of extraneous noise even whenever thing is correct. I was aware of the problem and I was always paying attention to any unusual noise that might show up with mine but I never noticed such. I wonder if you could gain access to the flywheel by removing the starter motor and gear assembly to see if the flywheel could be moved back and forth to indicate severe looseness.
« Last Edit: November 06, 2026, 08:15:14 PM by leafman60 »
Offline wirespokes
« Reply #10 on: November 07, 2026, 10:59:48 AM »
Good idea. Remove the starter, pull in the clutch and try wiggling the flywheel. Maybe I wouldn't even need to pull in the clutch.
Offline drdwb
    • backfeelsgreat.com
« Reply #11 on: November 07, 2026, 11:03:49 AM »
The clutch plate on my wife’s 04 Stone Touring, had the signal plate that disintegrated at about 8000 miles, totally disintegrated, dust and fragments when switched it out to new flywheel and double plates like my 03 EV. 2 years later one of the clutch plates on my EV also disintegrated, the theory at the time was some of the double plates were defective.
But I think it was partially my fault because I started hauling a pop up camper behind the EV, I haven’t seen a lot of reports on other California’s with double plates going, but it does happen, and it’s very possible there was a batch of plates that were defective. And on both bikes there was no indication they were going, the day the Stones went we were on our way home from the Mn rally, my wife noticed the shifting was getting more difficult, but still rideable, but it finally went about 50 miles from home, we had rode 250 miles that day before it went while driving on the freeway for the last leg of the trip. When the EVs went no noise rattle or vibration it just disintegrated and that was that, no go. Fortunately I was not pulling the trailer at the time and I was a couple miles from home.
The fix was relatively easy but time consuming. Fortunately the experts on this site had documented the process and allowed me to save a lot of money and do the job myself. Oh it also helped that Foto Guzzi lent me the special clutch tool to fix the Stone, I had a local friend machinist copy Foto’s tool so I had it to fix the EV.
The EV now has a Vetter Teraplane sidecar attached, I haven’t noticed any clutch issues yet, but it did blow out the front wheel right side bearing, while driving, not a fun experience. Removing and replacing the bearing pieces was a real pain as we were traveling and I didn’t have all the tools necessary. But we managed.
« Last Edit: November 07, 2026, 11:29:40 AM by drdwb »
« Reply #12 on: November 07, 2026, 12:11:07 PM »
I cured my clutch problems by using a ten spring clutch from an injected Sport. An eight spring would work if I didn’t have the extra weight of a sidecar and the extra power of throttle bodies from a Sport with Mike Rich ported and dual plug heads and cam. An eight spring unit would slip on a hard pull in third unless it was fairly new but I’ve had no problems with a ten spring. You’ll want to add a hydraulic actuator unless you milked cows by hand as a kid.
Edit. Mike Rich told me they were using a ten spring clutch in their race bike and it holds up really well , twenty years ago . I’ve heard that a clutch from a 1400 fits but I’ve never even seen one of those .
« Last Edit: November 08, 2026, 12:28:03 AM by John A »
« Reply #13 on: November 07, 2026, 01:05:10 PM »
My single plate 2004 EV started to slip before 1000 miles. As far as I could tell the friction material was just too wimpy (or springs too weak). My 1994 California and my 2004 EV with dual plate upgrade had the 'flex plates' on the actual clutch plates fail. I helped a number of people replace those plates in the late 1990s because the metal fractured around the rivets.
Offline wirespokes
« Reply #14 on: November 07, 2026, 07:51:21 PM »
That was something I learned when I first got into Guzzis almost ten years ago. Clutch problems. For some reason Guzzis have been plagued with all sorts of issues in that department. And just about every Guzzi I've owned has had something in there that required crabbing the frame -- rusty splines, grabby plates, notchy splines, rusted clutch (went through Hurricane Sandy), and variations of anything that can go wrong in there. Now I've got this O3 Stone with a single plate clutch. I did some reading and some of the spine frames had an issue with the aluminum flywheels grenading. From what I gather, those were thinner racing flywheels and not really ever intended to last a long time. Thinner than the California flywheels. But I'm still thinking it might be a good idea to swap out the aluminum flywheel. I do wonder why, if the clutch works so well otherwise, a stronger steel version manufactured?
Offline Mr Revhead
« Reply #15 on: November 08, 2026, 08:38:46 PM »
I have an 03 EV and a Scura so am well versed with these clutch issues.  :shocked:
First up they are not the same set up. Probably interchangeable,  but not the same
The Scura aluminium flywheel WILL fail. Ive just pulled mine out at about 80ks and its got several scary cracks. And its not from loose bolts, it appears to originate from where the metal plate used reinforce the hub ends.
It is definitely possible to make a steel copy, i looked at getting a chromoly one made and with 3 or more takers it would have been relatively cheap.
The problem is all the rest of the clutch parts including the hub wear and pretty much all parts are NLA. So you would need to get a clutch plate made etc.
Ram clutches also seem to be NLA with no stock worldwide and no ETA.
I converted my Scura to twinplate using an early Griso 10 spring unit.
My EV got a brand new twin plate under factory recall when it was new
« Last Edit: November 08, 2026, 08:39:46 PM by Mr Revhead »
Offline wirespokes
« Reply #16 on: November 09, 2026, 03:16:38 PM »
I've heard the clutch wasn't under warranty. Is that incorrect data?
I'm awaiting word from the dealer right now when the hydro kit arrives. They checked the vin, so will be handling that. I'd have thought they'd say something about the clutch at the same time. Maybe I should ask about that too.
You make a good point about availability of parts. No point converting if parts are NLA. That's too bad since it seems like a better system.
Does the Cali single plate clutch need a special hub like the Scura and Teni? Even so, shortening a standard hub shouldn't be a big stop. So what else is there? Pressure plate should be the same. Right? Is it only the clutch disc that's different?
Offline Mr Revhead
« Reply #17 on: November 09, 2026, 03:27:48 PM »
So you're talking California?  Dont mix the Cali and V11 clutches up, they share no parts.
I don't know what the California single plate hub was, they will be extremely rare as they were only fitted for about a year and almost all will be replaced by now. The hub to suit the twin plate is the same from the early/mid 80s until 2010.
The single and twin plate clutches including flywheels are all different parts.
« Last Edit: November 09, 2026, 03:28:23 PM by Mr Revhead »
Offline Turin
« Reply #18 on: November 09, 2026, 07:56:23 PM »
If I remember correctly, the single plate clutches on the V11 sport special edition models (Scura, rosso mandello etc) used a copy of the RAM clutch Flywheel. It's the guzzi made aluminum flywheel that cracks. I believe an aluminum RAM cutch can be swapped in. The Aluminum RAM clutches never had this issue. I have one in my Cal III and they are pretty nice
1985 Sidlow Guzzi
Offline Mr Revhead
« Reply #19 on: November 09, 2026, 09:35:52 PM »
RAM clutches are currently unavailable and quite likely not being made again
Offline Frenchfrog
« Reply #20 on: November 10, 2026, 03:05:42 AM »
Offline Mr Revhead
« Reply #21 on: November 10, 2026, 04:13:13 AM »
I'd be snapping that up fast if you're wanting one then
Offline huub
« Reply #22 on: November 10, 2026, 06:33:50 AM »
i was offered a -slipping- single disk clutch ,
it started slipping after just a couple of thousand miles.
the clutch disk was the same thickness as a dual disk clutch plate.
 i can have the disk redone locally , but knowing the correct thickness would help.
Offline wirespokes
« Reply #23 on: November 11, 2026, 01:19:42 PM »
That would be great if someone can provide the thickness.
Thank you for the link Frenchfrog!  :thumb:
Online Road Scholar
« Reply #24 on: November 20, 2026, 07:14:37 PM »
Is this a single or a dual?  2004 California.  Thanks!
« Last Edit: November 21, 2026, 05:54:03 AM by Road Scholar »
« Reply #25 on: November 21, 2026, 08:11:12 AM »
Bad picture angle. Single I'm pretty sure.
Rotate the motor a touch and do more pictures like those.
« Last Edit: November 21, 2026, 08:13:41 AM by Wayne Orwig »
