Author Topic: Three Guzzis in an enclosed 6x10 trailer?  (Read 668 times)
Offline Denis
« on: November 05, 2026, 09:11:37 AM »
Soon I'm picking up three Guzzis and a load of parts. One Guzzi is mostly disassembled so I can bring it in the back of my truck with the camper shell on. all the parts will also go in that.
I have a Leonard enclosed V-nose single axle 6x10 trailer with a rear ramp door and a right front side door.
The inside is set up with e track on the floor in such I way I can carry a single bike in the middle or two bikes (one forward on the left and the other sightly behind it on the right. I've carried two Indians this way in the trailer before.
I wonder if the third Guzzi will fit in between the other two if I put it in backwards.
Anyone carry three Guzzis in a 6x10 before?
« Last Edit: November 05, 2026, 09:13:08 AM by Denis »
'87 SPII
'74 Eldorado
'85 LeMans
'91 California big valve
'61 Falcone Turismo,
'41 Indian 841
'40 Indian Model 640B ex-Canadian Army
'40 Indian Chief 340B
Online PeteS
Re: Three Guzzis in an enclosed 6x10 trailer?
« Reply #1 on: November 05, 2026, 09:25:32 AM »
I haven’t tried it but would think the two near the sides should be put in backwards and the last one in the center, forward. Assuming the floor is plywood, screw in short 2x4s either side of the front wheel to keep them from shifting and use tie downs between the walls and each bike to keep them apart.
When I have carried that many bikes I had a bigger trailer.
Offline Aldo
« Reply #2 on: November 05, 2026, 10:52:06 AM »
This is a u haul 6x12...had an Eldo, Convert and 850T stuffed in it with various parts. Worked ok for me; bit of a tight fit towards the front.
MGNOC Lifetime Member
1973 Eldorado 850
1971 Ambassador 1000 Automatic
1960 Gilera Giubileo 98
1967 Benelli Sprite 125
Offline Denis
« Reply #3 on: November 05, 2026, 11:11:56 AM »
How did you chock the bikes and tie them down. Do those U-Hauls have all the necessary d rings, etc?
'87 SPII
'74 Eldorado
'85 LeMans
'41 Indian 841
Offline Aldo
« Reply #4 on: November 05, 2026, 11:33:20 AM »
I used the front wall to lock the wheels on the two forward bikes; no chocks.  All bikes on centerstands.  I can't recall for sure, but I'm pretty sure there were some existing tie down points (this was awhile ago).  Strapped them down well enough that they didn't budge the whole 1000 mile trip back home.
1973 Eldorado 850
Offline Oca Grassa
« Reply #5 on: November 05, 2026, 12:26:42 PM »
I’m gonna say yeah, it can be done. I have a 6x10 enclosed trailer that we used to haul 3 bikes across country from California to Indy and back for the 1st GP there.
I did not however, haul any Guzzi’s. My Mille R, GSXR600 and my buddies Hayabusa all fit without issue and plenty of room.
I set my trailer up with hard mounting points in the floor, through the frame work underneath. To those mounting points, I bolted through axle stands. Kept a cordless impact driver with me to facilitate easy on/off stand operations.
Stands were arranged in a staggered form with the Mille R front wheel forward in the middle and the Busa & GSXR behind one front wheel forward with the other rear wheel forward. The two in the back were staggered by roughly 12-18” to put the bars clear of the other’s tail.
This worked flawlessly from California to Indianapolis and back. It did however require some pre-trip planning and fabrication of the stands for it to work that way. YMMV
My garage:
Online Matteo
« Reply #6 on: November 05, 2026, 03:33:59 PM »
I have a 6x10 Wells Cargo trailer and towed my V85 and V7 facing forward and my Stornello 125 in the middle (with room to spare) facing the ramp from AK to NY this summer with good results.
Offline Tony F
« Reply #7 on: November 05, 2026, 06:41:37 PM »
Check the weight limit of the trailer and the max hitch weight on your tow vehicle. You dont say how long the tow will be but are the trailer tyres in good shape for such a trip?
Tony
'79 SP1000
KTM Duke 890R
MV Agusta F4 (x2)
Online Motormike
« Reply #8 on: November 05, 2026, 07:41:59 PM »
U-Haul enclosed trailers never have any tie down points that I've ever seen!  Just the rub rails along the sides.  The only time I ever used one for hauling a motorcycle (had no real choice) I got so pissed I broke out my drill and made my own tie down mounting in the floor.  Then removed them before I turned the trailer in...no one noticed.  :evil: I will say their open motorcycle-specific trailer is very good, if heavy.
