Author Topic: Guzzi App, does it actually connect?  (Read 462 times)
Online bad Chad
« on: November 05, 2026, 04:57:19 PM »
I have had my 25  TT for over a year, and decided to try and connect the Guzzi App to the  the bike today.  I had no more luck than I did last year.  I have the most current version of the app, but I still can't figure out what I'm supposed to do?   I know it's been a problem for lots of folks, just wondering if anyone has figured it out?   I'm using the app in a iPhone 16 if that helps.
1988 YX600 Radian
Online Dr. Enzo Toma
Re: Guzzi App, does it actually connect?
« Reply #1 on: November 05, 2026, 05:56:19 PM »
Do you have the physical MIA accessory kit installed?
If so, instructions for that can be found here:
https://www.motoguzzi.com/en_EN/app/manual/
And in the owner's manual: https://cadrecycle.com/wp-content/uploads/2024/08/V85TT-V85TT-Travel-V85TT-Strada-E5Plus-EU_en.pdf
Which step is the hangup?
2027 Moto Guzzi V7 Sport
MGNOC Member
Online Bulldog9
« Reply #2 on: November 05, 2026, 10:28:51 PM »
You have to have the multimedia module installed in your bike. Do you have menu options for the MIA on the dash of the bike? Also, The module should communicate by Bluetooth. Open up your Bluetooth settings on your phone, then turn the key on your bike and look for Mia or mgmp or something like that.
I have the older MGMP on my stornello, but the MGX21 had the multimedia controls. I could never get it to pair up and work properly. When I brought the bike in for the brake master cylinder inspection I had them sorted out and it worked. Of course I sold the bike 2 months later 🤣
The MGMP app isn't even available anymore, I had to side load it  But when the key is on it shows up in my Bluetooth device list as PMP. So when I have the MGMP app open and the key on I select the PMP module and it communicates with the app.
There's no multimedia functionality but it gives you some riding and driving data. Unfortunately no engine/oil temp data.
Android Auto/Carplay it is not......
MGNOC#23231
Online bad Chad
« Reply #3 on: November 05, 2026, 11:02:23 PM »
Yes, I have the MIA installed, my blue tooth doesn’t pick up the bike when I turn on the ignition.  I know the mia kid getting juice because I had to install it to have the capability to use the heated seat.  I’m somewhat familiar as I had a earlier gen MIA on my V9  , but this is a different app than the one for the v9.
1988 YX600 Radian
Offline Roman Hordan
« Reply #4 on: November 06, 2026, 02:47:24 AM »
Since the MIA is getting power (heated seat works), the next thing I'd check is whether the bike is actually advertising. On the V85TT the MIA usually only shows up for pairing when you start the pairing from the bike side, not just from the phone's Bluetooth list. Go into the dash menu, find the MIA/Bluetooth settings, and put it into pairing mode with the bike on, then scan on the phone.
Also worth deleting any old Guzzi/MIA entries from your iPhone's Bluetooth list and force-closing the app first. If you tried this last year, a stale pairing can block the bike from showing up again. If the dash has no pairing option at all, I'd have the dealer check the MIA's connection to the bike. Power to the unit doesn't always mean the data side is talking.
Offline CanonVanagon
« Reply #5 on: November 09, 2026, 10:54:10 AM »
I installed the MIA device and paired my iPhone a few weeks ago with out issues on my 25 V85. If I remember right you put the bike in pairing mode through the menu on the bike and then open the app on your phone. Select the bike model your are trying to pair and it goes though some genetic instructions. The short 30min ride I used it on, the Nav, music controls and calling worked pretty well. I just wish the app would use google maps for greater flexibility. Also you there is like a Music mode and Nav mode that you have to toggle between depending on what you are wanting to see on the screen. To toggle between the modes hold down the right arrow on the control.
22 V7 850 Stone
25 V85TT
