Author Topic: 1980 Convert Tire Size (s?)  (Read 802 times)
Offline n3303j
  • Ron Cichowski
« on: November 06, 2026, 03:26:45 PM »
So here I am in between work sessions on the new to me Convert filling the time by actually reading the Owner's Manual.
It told me how to change gear range while underway. All the responding Convert owners told me that was a good way for Guzzi to sell more two speed transmissions. So I decided to follow user knowledge and only change range while stationary.
So I get to a different spot in this Blue Covered Wonder and it says that both wheels should be fitted with 110-90/18 tires. I'm thinking, marvelous, if  the Avon Road Rider that fits both front and rear ever comes back to market then I can buy one spare to cover both positions!
So today I pulled the front wheel to make it tubeless. It was a tight fit between finger and fender to catch the 10 millimeter nut off the back of the bolt that secures the metal brake lines. Then I go to remove the tire and notice that it is a 100-90/18 which is the same combination as my '77 850T3 uses front & rear. I don't think a 110-90/18 would even fit in the existing fender.
So what TIRE SIZES are people running up front in their Converts? Is the Owner's Manual wrong again?
Thanks, Ron
« Last Edit: November 06, 2026, 05:08:04 PM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online Bulldog9
Re: 1980 Convert Tire Size (s?)
« Reply #1 on: November 06, 2026, 03:51:51 PM »
 My convert is a 1976.
When I bought the convert it had a set of old bridgestone 41s or 45s? that were dry rotted. I changed them out to pirelli route 66 and I've been extremely happy with them.
They're grippy solid as a rock in the corners and so far are wearing very well. I've put about 8,000 mi on them and they still look new. I don't remember having to do any juggling around to get the stock tire sizes.
MGNOC#23231
Offline n3303j
  • Ron Cichowski
« Reply #2 on: November 06, 2026, 04:59:58 PM »
So your front and rear are both 110-90/18 ?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline frozengoose
  • To eaches his onus...
    • smiles from nowhere
« Reply #3 on: November 06, 2026, 06:04:23 PM »
I was also curious why the convert has a bigger front tire recommendation than a T/T3, so it Googled it up. I know there's many on here who eschew the wisdom found there, and I'm not here to convert anyone, just thought it's an interesting reply. YRMV (I tried to attach the PDF but wound up copying it instead)
The Moto Guzzi V1000 Convert Overview on Autoevolution details the specifications for
the 1980 Moto Guzzi V1000 Convert (also referred to as the
Hydroconvert):
autoevolution
Engine & Performance
(1980
One of many motorcycles in Moto
Guzzi's range was the Moto Guzz…
V1000 Convert. It debuted in 1975
and was intended for the Americ... autoevolution
Engine Type: Air-cooled, 4-stroke, transverse 90° V-twin, OHV, 2 valves per cylinder
Displacement: 949 cc (57.9 cu in)
Bore x Stroke: 88 mm x 78 mm (3.46 in x 3.07 in)
MOTO GUZZI V1000 Convert
(1979-1980) Specs, Performance …
Photos - autoevolution Moto Guzzi V1000 Convert (1979-
1980): Touring motorcycle…
featuring round headlight, tall
Show all
Compression Ratio: 9.2:1
Horsepower: 71 hp (52 kW) @ 6,500 rpm
Fuel System: Twin 36 mm Dell'Orto VHB carburetors
Wikipedia +2
Transmission & Drivetrain
Gearbox: Automatic torque converter with a 2-speed manual-clutch override (built by
Sachs)
Clutch: Wet multi-disc, manual
Final Drive: Shaft drive
autoevolution +2
Chassis & Brakes
Frame: Tubular steel frame
Front Suspension: Hydraulic telescopic forks
Rear Suspension: Swinging fork with dual side-mounted shock absorbers
Front Brakes: Dual 300 mm discs with hydraulic calipers
Rear Brakes: Single 242 mm disc
Tires: 4.10-18 (front and rear)
autoevolution +1
Dimensions & Weight
Fuel Capacity: 6.6 US gallons (25 liters)
Dry Weight: Approx. 527 lbs (239 kg) to 562 lbs (255 kg) depending on configuration
Top Speed: Around 110–115 mph
autoevolution +2
If you are working on a specific restoration project, carburetor tune-up, or fluid
change for the V1000 Convert, let me know and I can share torque specs or service
guidelines.
why does it have bigger front tires than the T/T3 series since
they're about the same size, weight, configuration
The decision to put a wider 4.10-18 tire on the front of the V1000 Convert—compared to
the narrower 3.50-18 (or 100/90-18) standard on the 850 T and T3 series—comes down
to a distinct shift in the bike’s intended operational role, market demographics, and
police requirements.
Gutsibits +1
While they share the same Tonti frame, basic configuration, and overall architecture, the
Convert was deliberately optimized differently than the T3 for several key reasons:
Heavy-Duty Touring and Payload Capacity
The Convert was engineered from the ground up as a premier long-distance heavy tourer
and escort machine. It was heavily targeted toward police fleets (including LAPD and
various European police departments) and the civilian tourer market.
Equipped Weight: While the bare frames and basic parts weigh the same, the Convert
was almost universally delivered or outfitted with massive windshields, heavy fiberglass
or leather saddlebags, and crash bars.
Front-End Bias: This extra fairing equipment and equipment load significantly
increased the weight pressing down on the front axle compared to a bare T3. The wider
4.10 front tire provided a higher load index to safely carry that touring gear without
overheating or blowing out.
The Heavy Torque Converter Affects Dynamics
The Sachs hydraulic torque converter adds unique physical traits to the drivetrain:
Engine Braking Behavior: Unlike the manual T3, rolling off the throttle on a Convert
does not provide immediate, aggressive compression braking because the fluid
coupling handles the power transmission.
Braking Load Shift: As a result, riders rely much more aggressively on the integrated
Brembo triple-disc linked braking system to slow the bike down. When you step on the
foot pedal, a massive amount of kinetic energy transfers forward. The larger footprint
of the 4.10 tire prevents the front tire from breaking traction or "skidding" under sudden
heavy braking forces.
Stability vs. Quick Steering
A classic trade-off in motorcycle engineering is handling agility versus straight-line
stability:
The T3 Approach: The T3 was designed to be an agile sport-tourer. Guzzi owners often
notice that dropping from a 100/90 down to a 90/90 front tire on a T3 noticeably
"quickens" the steering.
The Convert Approach: The Convert was built to go dead-straight down a highway for
hours with maximum stability, minimizing rider fatigue. The wider, flatter profile of a
4.10-18 tire slows down steering transitions but tracks beautifully over highway grooves,
asphalt seams, and uneven road surfaces. It acts as an additional dampening layer for
the front end.
Interchangeability for Fleet Maintenance
For police departments operating large fleets of these big-block Guzzis, having identical
4.10-18 tires on both the front and rear wheels simplified logistics immensely. Mechanics
could order one type of tire in bulk and swap them onto either axle, streamlining fleet
maintenance overhead.
Are you trying to decide which tire sizes to buy for a replacement set, or are you
troubleshooting a handling issue like low-speed heaviness or high-speed headshake on a
Convert?
Facebook · Moto Guzzi Le Man…
Very nice indeed ! In my opinion ,
STILL the most beautiful ...
Sep 9, 2025 — The 18-inch cast
FPS wheels were as before, as…
were the integrated Brembo disc
brakes. 18-inch cast FPS wheels
Gutsibits
and Brembo brakes w...
Gutsibits Moto Guzzi Spares & Accessories
Front tyre: 3.5 x 18 | Rear tyre: 3.5 x 18,
1450mm wheelbase, weighs 214kg…
Manufactured 1969 to 1976. Power Output
26.2 BHP @ 4800...
Show all
If I were putting a new set of tires on a 1980 Moto Guzzi Convert today, I would choose
the modern metric sizes: 100/90-18 for the front and 110/90-18 for the rear.
While the factory original setup used thick 4.10-18 inch-designated tires on both ends,
modern tire technology and profiles have changed significantly. Going with the staggered
metric pairing strikes the perfect balance between preserving the bike's classic high-
speed stability and curing the heavy, sluggish low-speed steering that plagues standard
Converts.
Here is how the trade-offs break down depending on what you value most for your
ride:
Option 1: The Modern Performance Stagger (My Top Pick)
Front Size: 100/90-18
Rear Size: 110/90-18
Why it wins: This is the setup most seasoned Tonti-frame Guzzi riders switch to. A
modern 100/90 front tire is slightly narrower and has a more rounded profile than an old-
school 4.10. It dramatically lightens the steering, making the bike feel 50 pounds lighter
when maneuvering in parking lots or tipping into tight corners. The 110/90 rear maintains
an excellent contact patch for the torque converter's power delivery and fits perfectly
within the rear swingarm without any clearance issues.
Option 2: The Pure Factory Fleet Setup (For Authenticity)
Front Size: 4.10-18 (or a wide 110/90-18)
Rear Size: 4.10-18 (or 110/90-18)
Why choose it: Go this route if you are performing a highly accurate police/civilian
restoration or if you exclusively ride long, straight interstate miles and want absolute
"freight-train" tracking.
The Catch: Running a wide tire on the front creates a heavier steering effort and
causes the bike to "tramline" (follow grooves and cracks in the road) more noticeably
than a 100/90 front tire.
Recommended Tire Models for Big-Block Guzzis
Vintage big-block Moto Guzzis are heavy and carry a lot of weight on the rear wheel. You
need a stiff carcass that can handle the load. I highly recommend looking at these specific
classic/touring lines which are readily available in these dimensions:
Avon Roadrider MKII
$159.99
Summit Racing & more
· 4.1 (909)
Excellent longevity, very stiff sidewalls that handle heavy touring loads perfectly, and
superb wet-weather grip.
Bridgestone Battlax BT46
$166.88
rockymountainatvmc. com & more
· 4.3 (3.9K)
The gold standard for upgrading vintage metric bikes. It provides a highly predictable turn-
in and breathes new handling life into heavy frames.
Metzeler Lasertec
$191.51
Dennis Kirk & more
· 4.2 (1K)
Offers a very period-correct tread appearance while utilizing modern rubber compounds
for mileage.
To help narrow down the choice, what kind of riding do you plan to do most (e.g., casual
weekend cruising, highway touring, or twisted backroads), and are you looking for a
period-correct classic tread style or the highest possible modern grip
performance? For the lighter steering and improved handling of the modern
performance setup, some recommended 100/90-18 front
tires.
Big Jon
Jerry Zee
« Reply #4 on: November 06, 2026, 06:09:12 PM »
I'll actually answer the question. I run a 100/90 front and 120/90 rear. I like the quicker turn-in of the 100/90 vs. a 110/90, with the 120/90 the speedo is dead on, and it's slightly easier to get on the centerstand.
« Last Edit: November 06, 2026, 06:09:46 PM by Antietam Classic Cycle »
Offline n3303j
  • Ron Cichowski
« Reply #5 on: November 06, 2026, 06:25:36 PM »
100-90X18 will fit in the fender with about 1/3" clearance.
I'm pretty sure 110-90X18 would come close to dragging on the inside lip of the fender.
So I guess I'll leave it at 100-90X18 (Shinko) currently installed.
As far as usage goes, the bike is being cleaned up and made reliable to serve as a daily rider. I have no delusions about concourse restoration at my age (81) or purpose. I'd rather ride than clean. I'd rather ride than wrench (although I really like making things right). The 3 machines I currently own have all passed 100,000 under my usage and care. Don't know if I have time enough to get a 14K mile Convert up to 100K miles. I'll give it a try though.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline theoneandonlymin
« Reply #6 on: November 07, 2026, 08:28:16 AM »
I've put approximately put 35 pairs of tyres on my G5.
The ones that  consistently worked best was the 100/90 110/90 combo.
Tried 110/90 up front didn't like it. I've run 4.00 on the back which just felt weird as the height increased due to no aspect ratio.
Don't mess about, just use the 100/110 combo.
Then the tyre thread starts as to what to use......
Offline n3303j
  • Ron Cichowski
« Reply #7 on: November 07, 2026, 08:34:47 AM »
Kind of what I thought 100 front & 110 rear just like my T3.
Just thought it odd that the owners manual specified a size that might actually interfere with the front fender. It's a challenge pulling the brake line mounts on the fender with a 100 in place. My smallest finger barely fits in between the tire and the fender. Can't imagine getting a nut in place with a 110 installed unless I pulled the fender as part of the tire install procedure.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Aldo
« Reply #8 on: November 07, 2026, 10:07:44 AM »
Albeit not really a Convert, my Ambo-vert sports a complete Convert drive line, as well as rear and front end. I use a 100/90 up front and a 110/90 rear. The same as I do for my '73 Eldo. Those are my preference.
MGNOC Lifetime Member
1973 Eldorado 850
1971 Ambassador 1000 Automatic
1960 Gilera Giubileo 98
1967 Benelli Sprite 125
Online Bulldog9
« Reply #9 on: November 07, 2026, 11:46:37 AM »
No, just checked.
I went with 100/90-18 for the front and 110/90-18 for the rear.  The rear tire Initially just scraped the pavement when on center stand.
I don't think they make the MT66 anymore. CRAZY that was 6 years ago......
MGNOC#23231
Online chuck peterson
« Reply #10 on: November 07, 2026, 03:00:23 PM »
10mm nut goes on fine with the tire removed…  :thumb:
As to your question..
With a Windjammer?
With the longer later G5 springs?
My 78 Barco lounger was equipped this way and did 90k with 110/90 front rear
BUTT…..
The g5 set up put more distance between top to bottom in the front
Rendering the centerstand useless
The Guzziology solution was to raise the forks in the triple
Making the 110/90 act quicker
This Convert had a Windjammer with too many tools loaded into the front pockets
A humongous tank bag
Two DB bags that slept 6 on both sides and gear for 4 weeks
Altogether i was overly ambitious at filling them to capacity.
 fronts 110/90 38 psi
Now if you stripped all the sh//t off, not so..which kind of Barcolounger, I mean Convert are you making? Fat traveler or a sleeper slow fast one?
Yours is an 80?,  they might have changed the fork springs AND the centerstand at the factory. Change in part numbers
It’s funny but whenever i see a picture of a Vert with the original shorter forks it looks great, real brutal looking grunt face. Lower frontal face
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline n3303j
  • Ron Cichowski
« Reply #11 on: November 07, 2026, 06:54:01 PM »
[SNIP]
10 MM nut goes on after front calipers are mounted.
Front calipers go on after the front wheel is mounted.
That's why I install the brake line tie down 6 MM bolt & nut last.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #12 on: November 08, 2026, 06:45:43 AM »
Visual difference in front fork internals…i wish i could find head one fotos. The original looked like a brute
Original Vert fork internal
Upgraded G5 fork internals, I believe this might be the incredible Greg Bender restoration. Dual spring rate from the factory
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline n3303j
  • Ron Cichowski
« Reply #13 on: November 08, 2026, 07:25:18 AM »
Odd thing about the your pictures is that my (manufactured late 1979) 1980 has the brake line mounting so close to the front slider that the socket wrench touches the slider on disassembly. Evidently Guzzi went to a shorter steel line. Don't know about the flexible line. Your images match my (manufactured  late 1976) '77 T3 for the anchor of the steel brake line.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline TOMB
« Reply #14 on: November 08, 2026, 08:55:10 PM »
Here's mine.
To answer your question on tire size , I run Avon Roadrunner ,tire size both front and rear is as follows.110/90/18
Enjoy
TOMB
« Last Edit: November 08, 2026, 08:56:39 PM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
« Reply #15 on: November 09, 2026, 02:50:55 AM »
No, just checked.
The tyre on the ground will be more to do with your centre stand stop plate and/or wear on the feet .
