Author Topic: Advice on fork servicing  (Read 415 times)
Offline nwguy
    • Jim Gallant's home page
« on: November 12, 2026, 12:49:48 PM »
I'm in talks with my local Guzzi dealer (Optimum Performance Motorsports Seattle) about servicing my 99' Bassa's forks. It has about 70k miles on it. I've only owned it for the past 4k miles and don't know the service history. Their service guy is currently checking on parts availability. Someone here said the seals might be hard to find, we'll see. I plan on getting new rear shocks for it this winter. In spirited riding on curvy/bumpy roads it gets pretty wonky in the turns. So, I'm wondering how far to go with fork servicing. I bought it for $1k and have sunk about $2,500 into so far. Absolutely love the bike. Given the low cost of the bike, what makes sense for the servicing?
Oil and seals - yes
Different weight oil? (I weigh about 220 lbs and do not ride 2 up, but often am loaded for prolonged rides)
Different springs? If so, progressive?
Revalving or cartridges? Looks pricey, not needed or appropriate for my situation?
Anything else I should consider?
I'm going to pull the forks and bring them in separate from the bike.
Online bigbikerrick
Re: Advice on fork servicing
« Reply #1 on: November 12, 2026, 12:56:43 PM »
If the seals are not leaking, why replace them...You can change the oil yourself, and improve the ride,as well as experiment with different weights oil/and add a spacer for increased pre load if necessary. They are a pretty simple design, and easy to service yourself. I did the forks on a Cali aluminum I had, and thats what I did, with good results. The oil that came out with 30K miles was pretty nasty. MG cycle should have the seals if needed.
Rick.
« Last Edit: November 12, 2026, 12:59:25 PM by bigbikerrick »
Online Michael_A
    • Penguin Video Productions
« Reply #2 on: November 12, 2026, 01:07:40 PM »
I recently did the forks on my 1999 Bassa. Went in to replace the upper fork tubes because the original ones were pitted and would never seal. Did a full strip and rebuild. The seals are available, and I recommend spending a few extra $$ and getting the OEM seals. They work and seem to last. Aftermarket ones, in my experience, don't seal very well or last as long. Some parts are NLA... namely the slider bushings though NOS ones do pop up from time to time. When I inspected mine they were fine, so as long as the forks haven't been run dry yours will likely be OK. There was a lot of "mud" in the forks, even though the PO had done regular changes. It just builds up in there. Did increase the preload on the springs a bit, but other than that went back stock. Haven't experienced any wallowing or weird handling, so I'm pretty impressed with how the stock setup (with a bit more preload) seems to work. For me, the experience really world not benefit from doing more fork mods ($$$), and you may be surprised how well basically stock, cleaned up, refilled forks work for you.
Offline Perazzimx14
« Reply #3 on: November 12, 2026, 02:26:26 PM »
Are they damper rods forks? If so, if the seales aren't leaking there is very little to be gained from servicing them. Even then it dump out the old fork oil swish around a bit of Acetone then dump that  and new refill with cheapest ATF you can find. Then expect the foks to feel just like before.
Unless you are adding different springs and/or some sort of valving (if available) I'd leave the forks alone until there's a reason to open them up.
Offline Huzo
« Reply #4 on: November 12, 2026, 02:31:09 PM »
Worth noting that altering the preload will change the ride height but not materially effect the quality of the ride.
Offline Alfetta
« Reply #5 on: November 12, 2026, 02:43:41 PM »
If you change the oil....   don't use 3-in-1   it will blow past your seals first big hit.  I tried it on a dirt bike in a quest for a thinner oil. i ended up wrapping the fork with shop rags to finish the race.
Offline nwguy
« Reply #6 on: November 12, 2026, 03:02:21 PM »
« Reply #7 on: November 12, 2026, 04:50:10 PM »
Try it and see if they fit.  We got some for a Norge that were supposed to fit but didn't.
Bushings have three dimensions.  If off by even a time bit it's no go.
Online SIR REAL ED
  • uh.... it's personal....
« Reply #8 on: November 12, 2026, 06:04:46 PM »
I for one would like you to present the science that supports that assertion.....
2002 MZ Skorpion
1994 DR Skorpion
Offline marcdavo
« Reply #9 on: November 12, 2026, 06:41:04 PM »
I think he meant it doesn't change the stiffness of the spring. Just raises or lowers the height of the bike as it sits on the spring. The spring itself will still be what it is in terms of its spring rate.
 https://www.penskeshocks.com/blog/motorcycle-spring-preload-what-it-does-and-why-we-would-adjust-it
« Reply #10 on: November 12, 2026, 07:23:31 PM »
Offline Huzo
« Reply #11 on: November 12, 2026, 07:56:31 PM »
No worries SRE…
If your fork spring is at half preload and you load it with 125 kg, then hop off and alter the preload, and then hop back on, you still have 125 kg on the spring, you have not altered the weight that the spring is supporting.
(Not 125 kg + or - the applied preload).
You have just altered the position of the slider on the stem…
But I think you knew that…😉
Offline wirespokes
« Reply #12 on: November 14, 2026, 07:28:38 PM »
Preload doesn't change spring rate. What it does do is change where in the suspension travel the bike stays at rest. You want the suspension to be about 1/3 of the way into the shocks with you sitting on the bike. If it's less than that, lighter springs are needed. Too far, add preload.
