Author Topic: Spring in oil pan of V7 850  (Read 1244 times)
Offline GeorgeG
  • It's decease I tell you!
    • Desert Moto Rentals
« on: November 13, 2026, 12:00:23 PM »
 Hi Gang,
Doing an oil change and found this spring in the pan! Anybody know what this is?
Happy owner of '76 Convert, '83 SP,  '96 and '97 1100 Sports, and '14 & '17 1400 California Touring's, and '01 V7's.
The other 15 bikes aren't that important!
Online Bulldog9
Re: Spring in oil pan of V7 850
« Reply #1 on: November 13, 2026, 12:06:27 PM »
That looks to be the Cam Chain Tensioner Spring, a guy in the V85 threads had a similar issue. I'd get it looked at before riding much more.
MGNOC#23231
Offline Ed / AF1 Racing
« Reply #2 on: November 13, 2026, 12:22:06 PM »
yes, it does look exactly like that
Stein has some more pics of it, https://www.stein-dinse.com/en/item-1-1444427.html
« Last Edit: November 13, 2026, 12:23:05 PM by Ed / AF1 Racing »
« Reply #3 on: November 13, 2026, 03:03:30 PM »
That’s what it is.
« Last Edit: November 13, 2026, 03:06:35 PM by Huzo »
Offline Stretch
« Reply #4 on: November 14, 2026, 07:11:18 AM »
Half of it, anyway...
Ain't that a revoltin' development. :cry:
I'd get the other half out before riding it
much more, myself.
                                          -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Offline guzziart
« Reply #5 on: November 14, 2026, 07:35:26 AM »
Sorry to see that but at least you may have caught the problem before it got worse.  I was wondering how you came across your discovery.  Was the spring stuck to the magnetic drain plug (I don't recall if they have a mag DP or not.).  Or did you have the pan off?  If you had the pan off, why?
Thanks,
Art
Online Bulldog9
« Reply #6 on: November 14, 2026, 08:24:11 AM »
This makes me wonder about all the noise some are complaining about on the newer 850 motors, not just the Variable Cam models. May be worth it to drop the sump to check?  This is the second I've seen, but between here, ADV and the Book of Faces, it seems to me that there have been a rash of V85 (or 850) engine issues from total failures to weird noises, and well, you know how GOOD our MG community of dealership wrenches are. Other than a select few, are a bunch of shaved apes.
MGNOC#23231
Offline ridingron
« Reply #7 on: November 16, 2026, 12:35:53 AM »
Sorry to say, looks like there is a new cam chain tensioner in your future.
Offline Roman Hordan
« Reply #8 on: November 16, 2026, 03:32:12 AM »
Agree with Stretch, that's only half a spring, so the other half is probably still in there somewhere. If the tensioner spring let go, the plunger can collapse and the chain gets slack, which is how you end up with timing problems. I'd drop the sump and go looking for the missing piece (check the pickup screen and the bottom of the pan) before you fire it up again.
While you're in there, pull the tensioner and compare it to a new one. And if you ever do start it, listen for any rattle at idle that wasn't there before. George, did it make any new noises before you found this?
Offline wirespokes
« Reply #9 on: November 16, 2026, 03:04:40 PM »
The other part of the spring is probably still attached to the upper hook of the tensioner. It's not a difficult job getting to the timing chain.
Online PeteS
« Reply #10 on: November 16, 2026, 03:52:40 PM »
If you count the turns (~26) it appears it broke right at the 90 degree bend which would be the weakest point.
Not great news for everyone else if all these springs have the same defect.
Online Bulldog9
« Reply #11 on: November 16, 2026, 04:13:45 PM »
Assuming you dropped the sump? Having a hard time picturing this coming out the drain hole.
MGNOC#23231
Online n3303j
  • Ron Cichowski
« Reply #12 on: November 16, 2026, 07:26:39 PM »
Can't figure how looped end got off the dowel???
Meanwhile 40+ years ago when I was a Copier Tech (who was really detail oriented) I had a trainer drop a spring into the base pan of the machine I was almost done reassembling. I spent about 45 minutes trying to figure where it belonged before the trainer informed me of his subterfuge.
You don't by any chance happen to have any "friends" like that?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #13 on: November 16, 2026, 07:57:10 PM »
It’s probably gotten loose because the dowell came out or broke.
The tension on those springs is severe, I had two made (I still have a spare), that was about 8 mm longer.
This reduced the tension somewhat and that was a LONG time ago, the bike has done 150,000 km since it went in and was still ok when I installed the Caruso timing gears…(which I later removed), the longer spring went back in with the new shoe.
Also..
The spring flexes where it rubs against a part of the casting, I relieved it at that point to reduce the loads.
Online DaSwami
« Reply #14 on: November 17, 2026, 09:02:52 PM »
Is this possibly affecting all years V7-850 or just certain years.
I recall the V7III had a batch of engines that had a defective part that allowed the crank (?) to walk back into the block and shave the casting, or something like that.  But it only affected one year it seemed (2016?) and then ceased to be a problem.
« Reply #15 on: November 17, 2026, 09:10:27 PM »
It was the V7II, and I believe only a short run of 2016 models that came to NA. Though to be clear, the V7II only came to NA for one year, 2016.
The "defective part" was a batch of crankshafts that were machined undersized.
Online DaSwami
« Reply #16 on: November 17, 2026, 10:09:07 PM »
Death, taxes, and a snide reply from Kev M that doesn't actually answer the question.  :rolleyes:
The first sentence was the question, and the second portion was the historical empirical evidence that I just tried to recall to justify asking the question in the first place.  I got the year right, but the model wrong.  Shoot me.
And, I thought it was a thrust washer or bearing, but whatever.
As someone who is actively working to buy a pre-'26 850, I was curious what the collective knew about this.
Thanks....
« Reply #17 on: November 18, 2026, 04:28:31 AM »
Thanks....
No snide-ness intended. I was clarifying what I could should someone unfamiliar with it reading this thread look to buy a V7II or III in the future.
Sorry I can't answer the question on the 850.
And, in the interest of sharing information, the thrust washer was a symptom and not the cause (the later having been the pervasive rumor). The undersized crankshaft allowed the thrust washer to eventually come out of position and become damaged, which is what allowed the crankshaft to start chewing the block. The scary thing about it is I still see some ultra low mileage V7IIs out there that could potentially be effected, which is again the only reason I mentioned it. One was listed for sale on this site this fall.
Online DaSwami
« Reply #18 on: November 18, 2026, 05:30:12 AM »
That was the perfect reply, Kev.  Thank you.
Offline red stripeguz
« Reply #19 on: November 18, 2026, 11:16:29 AM »
I wish the OP would come back and say whether it came out the drain hole or if he dropped the pan
2023 V7 Special
2007 Norge
Online n3303j
  • Ron Cichowski
« Reply #20 on: November 18, 2026, 11:54:34 AM »
He found it in the pan.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online Bulldog9
« Reply #21 on: November 18, 2026, 02:34:19 PM »
I'm starting to think that maybe it's time to start a tracker.
I just saw another one. 2025 v85 with the same problem.
I haven't been keeping track exactly but my impression is these are all the later or newer models. Not some of the first or second generations but I'd have to go back and start tracking to be sure.
What you're remembering on the V7 motor related to a single batch of v7ii motors. The problem poked its head up pretty early as the crank ground its way into the engine case causing the need to continually readjust the clutch. I forget if it was a thrust spacer put in backwards or one missing.
MGNOC#23231
« Reply #22 on: November 18, 2026, 02:54:12 PM »
Jim Hamlin showed Cam and I a few motors he'd disassembled and inspected, which was how he discovered the crankshafts were machined undersized just enough to allow the thrust washers to come out of position early in service and get chewed up. Others who didn't look as closely assumed the washers were never installed or installed improperly, but those scenarios would have been much more grossly negligent of the factory. The slightly out of spec crankshafts make much more sense, especially in how the factory didn't seem to be able to pinpoint the affected VINs ...
« Last Edit: November 19, 2026, 05:31:22 AM by Kev m »
Online DaSwami
« Reply #23 on: November 18, 2026, 08:19:05 PM »
Another tidbit, if you look at exploded diagrams of the 2021-25 engines and 26-27 engines, the chain tensioner looks like a different design.  At least in appearance.  Hmmm
Online Moparnut72
« Reply #24 on: November 19, 2026, 07:54:07 AM »
I may be all wet but this thread has gotten my mind wandering. My '26 Special ran so badly that I finally dumped it for a Triumph. And come to think of it, it made quite a bit of noise on startup. For some reason I was thinking due to my past experiences with Harleys that I thought it had to build oil pressure for the tensioner to become effective. Of course MGs don't work this way. As I said my mind wanders at times, old age?🤫 So could a loose chain also contribute to mild surging at moderate speeds which I also experienced. I blamed everything on fueling resulting from a redesign of the throttle body, from two to one, complete exhaust design and cam change. I don't have a decent dealership within hundreds of miles, probably a thousand or more, to look into my problem. Thoughts?
kk
Edit: If I had known about the spring problem I would have pulled the pan.
« Last Edit: November 19, 2026, 08:25:13 AM by Moparnut72 »
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
