Author Topic: Which Sta-bil?  (Read 673 times)
Offline Hope 4 V7
Which Sta-bil?
« on: November 17, 2026, 01:32:48 PM »
“Marine Sta-Bil, when added to even a partial tank of fuel, creates a vapor that protects the rest of the tank, even the part not covered by gas, from rust.” (From 2017)
Hi, Lannis.
There’s a couple of different Sta-Bil Marine 360’s on the market. I was just curious about which one you used to protect your tank.
Thanks,
Jim
2017 Triumph Bonneville T120
Online AJ Huff
Re: Which Sta-bil?
« Reply #1 on: November 17, 2026, 02:03:33 PM »
Lannis is no longer here but I am sure we have enough experts here to get a non definitive recommendation.LOL. I too would like to know.
-AJ
Hi, Lannis.
Thanks,
Jim
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
Re: Which Sta-bil?
« Reply #2 on: November 17, 2026, 02:43:21 PM »
Straight from the horse's.................. .................mo uth.
https://www.goldeagle.com/product/sta-bil-360-marine/
Offline Perazzimx14
Re: Which Sta-bil?
« Reply #3 on: November 17, 2026, 02:43:26 PM »
What are you trying to achieve? If it's overwintering the bike any fuel elixir will do, or you can skip it and the bike and fuel system will be fine especially if its fuel injected. If it's a carb'ed bike turn off the petcocks and drain the bowls and forget about the bike until spring. Fuel elixir optional. FWIW 99% of the fuelI have access to is E-10.
« Last Edit: November 17, 2026, 04:05:15 PM by Perazzimx14 »
Online MikeP996
Re: Which Sta-bil?
« Reply #4 on: November 17, 2026, 03:25:21 PM »
Stabil Storage.  Been using if for many years and it has stabilized E-10 that sat for over 2 years in my Norton Commando's fiberglass (!) tank.  Bike started as if it had been running yesterday.  I use it in all bikes and cars, some sit for four months, some for eight, some for 11!
Just finished using it/winterizing our UK vehicles - Mini Cooper, Wife's Honda NCT750, my V7 and my '76 Honda CB400F.
« Last Edit: November 17, 2026, 03:29:17 PM by MikeP996 »
2021 Moto Guzzi V7 850 Special (UK)
1976 Honda CB400F (UK)
2017 BMW R1200RS (TX)
'73 Norton Commando (Mexico
2015 BMW R9T (Mexico)
(Wife's bikes:
2015 Ducati Diavel (TX)
2019 Honda Africa Twin  (Mexico)
2021 Honda NC750  (UK)
Online bad Chad
Re: Which Sta-bil?
« Reply #5 on: November 17, 2026, 04:55:08 PM »
Make sure you check the date on your SAT-bil bottle.  I bought the extra big bottle a few years back thinking I'd save some cash in the long run.  Then I noticed the product has a use by date, don't recall exactly how long but it was but it certainly wasn't long enough to use the bottle up!
1988 YX600 Radian
Offline Perazzimx14
Re: Which Sta-bil?
« Reply #6 on: November 17, 2026, 06:24:42 PM »
Should have put some StaBIL in it  :shocked:
Offline SIR REAL ED
  • uh.... it's personal....
Re: Which Sta-bil?
« Reply #7 on: November 17, 2026, 07:06:04 PM »
Are you sure?  Mixing StaBil and Sat-bil might not be a good idea.  Hopefully wiser minds will chime in!
« Last Edit: November 17, 2026, 07:06:31 PM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
Offline SIR REAL ED
Re: Which Sta-bil?
« Reply #8 on: November 17, 2026, 07:08:34 PM »
Honda also markets their own version of Sta-Bil, and it is a very pretty red color.  Which seems like a more appropriate color match for a lot of Moto Guzzi paint jobs.  Just sayin....
2002 MZ Skorpion
1994 DR Skorpion
Online MikeP996
Re: Which Sta-bil?
« Reply #9 on: November 18, 2026, 01:20:45 AM »
Stabil Storage is red!  :)
(Wife's bikes:
Offline Roman Hordan
Re: Which Sta-bil?
« Reply #10 on: November 18, 2026, 03:47:27 AM »
Pretty sure the one you're after is the regular Sta-Bil 360 Marine, the one that says it protects against ethanol damage and corrosion. Lannis's 2017 quote was about the vapor corrosion protection in a partly full tank, and that's the marine formula's main selling point over the red Storage bottle.
That said, for a bike that's just sitting over winter, I'd go with what Perazzi said: fill the tank so there's less air in it, add whatever stabilizer you trust, run it for a few minutes so it gets through the fuel system, and you're good. Marine is a bit overkill unless you're storing it somewhere damp or it's going to sit for a year or more.
Online MikeP996
(Wife's bikes:
Online Bulldog9
Re: Which Sta-bil?
« Reply #12 on: November 18, 2026, 08:34:37 AM »
Use Seafoam............ ......... One stop shop. I've had issues with Stabil, Red (Marine) or Blue (STD) with buildup and goo. Marine/360 is better than the STD, but growing up with boats and salt air on Long Island, and having to winterize, I remember years and years of having to clean and correct when using Stabil over time.
Cleans, stabilizes up to a year (have gone as long as 18 months without issue), helps with moisture in the tank, even some lubrication for fuel pumps (for FI).
40 years of using it, and not a single fuel system issue, fuel injected or carburated.
Two particular examples.
1. Bought my Yamaha XS1100 in 1986 and rode it over 120K miles, storing for the winter and sometimes years between running. When I bought it the Mikuni CV carbs were all clogged up from sitting from the PO. Took it to a shop, they ceaned and adjusted, and they have NEVER been opened since........... Not once. I credit Seafoam use while running (probably monthly) and storage.
2. Restored a Porsche 912 from 2010-2015 and installed Dellorto DRLA carbs. Put the car on the road and have driven about 15K miles over the last 10-11 years. The car has sat sometimes up to 2 years. This last year I decided I wanted to drive the car more. Tank is completely rust free, pulled the carbs to check for buildup and they looked NEW no issues whatsoever, in fuel bow, jets, etc etc. the looked as good/new as when I installed them. I once again credit Seafoam for this. 1 Can every Fill up (20 gallons). It kept the fuel stabil, kept things clean and clear and rust free.
I've tried others, Lucas, Techtron (a great cleaner) but overall find Seafoam is my one stop shop do it all in every vehicle. Placebo, snake oil? possibly, but it has performed and works flawlessly. I could say the same with my 25 year old Honda lawnmower, or other power tools (blower, chainsaw, trimmer) most of which are completely abused and neglected, but all over 10+ years old with NO maintenance other than putting gas in them and they all run perfectly with no fuel related issues.
YMMV.
« Last Edit: November 18, 2026, 08:37:53 AM by Bulldog9 »
MGNOC#23231
Online danomar
Re: Which Sta-bil?
« Reply #13 on: November 18, 2026, 06:55:43 PM »
What about the StaBil In-Season treatment?
https://www.goldeagle.com/product/sta-bil-in-season-protection/
Has anyone use this flavor?
My issue is with plastic fuel tanks reacting to ethanol and expanding. I am going to try non-ethanol gasoline, but finding it is inconvenient and the octane level is only 87. I got some Lucas octane booster but would welcome other solutions.
Online Dr. Enzo Toma
Re: Which Sta-bil?
« Reply #14 on: November 18, 2026, 07:12:06 PM »
I wish octane boosters worked as one would think they do, but they don't. Read the label carefully and the difference between octane numbers and octane points. If you're targeting 91 octane for example, Lucas Octane Booster cannot be used to achieve that from 87 octane. For vintage plastic and fiberglass tanks I have used Caswell epoxy liner. So far they've held up.
2027 Moto Guzzi V7 Sport
MGNOC Member
Offline SIR REAL ED
Re: Which Sta-bil?
« Reply #15 on: November 19, 2026, 05:39:08 AM »
Orange STA-BIL?
This may help in the search for Ethanol Free gas:  https://www.pure-gas.org/
2002 MZ Skorpion
1994 DR Skorpion
Online MikeP996
Re: Which Sta-bil?
« Reply #16 on: November 19, 2026, 06:48:05 AM »
I have been MEANING To carry a small container of Stabil Storage and add it whenever I fill up because, as it turns out, sometimes I sometimes end up not riding a moto for quite a while even though I had intended to ride it more.  I just finished adding Stabil Storage to three of my motorcycles that had been sitting for about two months.  If I added the Stabil at each fill-up, there would be no need to "winterize" as far as the fuel is concerned, it would always be "winterized" ;)
FWIW - here's a review of stabilizers...  https://www.youtube.com/watch?v=OHXYWxMkhog
« Last Edit: November 19, 2026, 07:21:17 AM by MikeP996 »
(Wife's bikes:
Re: Which Sta-bil?
« Reply #17 on: November 19, 2026, 07:46:38 AM »
I do that every fall. I buy a big bottle of Stabil (these days, in the past I've used SeaFoam, StarTron, and others). And I have a bunch of small bottles. I put a few ounces of the Stabil in each of the small bottles and carry it on the bike, adding before any refill. This way I know all of the fuel systems are treated when the first snow/salt event arrives.
Ironically with regards to this conversation, I happen to have picked up Marine Stabil this season, but I'm not all that picky.
I don't know which comparison you posted a link to, but the last one I bothered to follow was a long term test on small engines and Stabil was among the better performing. That said, I don't particularly worry about it, because usually my winter storage only equals a few months, maybe 4 at the outside.
I'd be far more worried if I was placing something into LONG term storage (measured in years and not months).
FWIW, EFI systems are MORE resistant to gumming from fuel evaporation, but they are NOT immune. I have seen some that required pump, injector, and/or pressure regulator replacement after improper longer term storage. For instance, I think Mark Etheridge recently encountered this with a Heron Head smallblock that came through his shop.
Offline Perazzimx14
Re: Which Sta-bil?
« Reply #18 on: November 19, 2026, 11:02:26 AM »
It looks like you can get whatever Sta-BIL formula you like in 8oz bottles making it easy to bring along.
Offline Hope 4 V7
Re: Which Sta-bil?
« Reply #19 on: November 20, 2026, 01:18:56 PM »
I just wanted to take a minute and thank you all for your help in trying to find a stabilizer that works. My biggest problem is that I don’t have a completely full tank of gas. I might be down a gallon or so. Not sure on a 5.5 gallon tank if I need it to come all the way up to just under the neck or not. That’s why I was looking. The Marine 360 seems like the way to go, but I have a finished garage and always use Premium 91 (required) non-ethanol gas. I haven’t had to use ethanol-blended gas yet. (Don’t know what the dealer used before shipping it to me.)
Maybe I’m overthinking the whole thing!
Jim
Online michaell32
Re: Which Sta-bil?
« Reply #20 on: November 20, 2026, 01:34:49 PM »
Project farm did a test on fuel stabilizers and stabil came out on top. Only the regular stabil was tested though. If it will sit for less than a year I think any type would probably work.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
Online Bulldog9
Re: Which Sta-bil?
« Reply #21 on: November 20, 2026, 05:54:53 PM »
I'm not much of a 'youtuber' but there are a few guys who are pretty solid and he is one of them.
As said above, I've Been a Seafoam user for many years. I can't say that I've ever seen the corrosion he demonstrated, and for a FACT have left cars and motorcycles sit with a full tank of gas for up to 18 months, and started right up, so maybe volume makes a difference?
Either Way, Stabil definitely out performed, and I'll be looking for some. To be fair, the days of Stabil was back when I was a kid and in High School for our lawn mowers and outboard motors. The Stabil would goo things up. Marine was much better. But this was back in the day with leaded and non ethanol lower additive fuels, so things have obviously changed.
Thanks for sharing the video.
MGNOC#23231
Offline Stevex
Re: Which Sta-bil?
« Reply #22 on: Today at 10:32:33 AM »
I've got 5 bikes in the garage, 4 are FI, the LM2 carbed. Two of the 4 FI bikes have nylon petrol tanks. I use Pro Honda fuel stabiliser on them all. I drain the tanks as far as possible, then add a couple of litres of treated petrol, run the engines to allow the treated petrol to get through the fuel system, then leave it at that. I have a jerry can of E5 with stab in it as I aim to run the bikes at least once each about half way through their lay up.
