Author Topic: Norge idle anomaly  (Read 459 times)
Offline Huzo
Norge idle anomaly
« on: November 18, 2026, 03:56:34 PM »
This one has just started to occur.
Does not happen all the time, but mostly when coming fully up to temperature, can still happen though even after continuous riding.
You can be riding along with no ill effects at all, plenty of power, smooth, no hesitation in throttle response, but as you roll off to come down from cruising speed on full trailing throttle, the engine can occasionally cut out when you pull the clutch at the stop. Sometimes the starter will auto engage and fire the bike back up again with no rider intervention.
It can also occur that as you’re coasting to come to a stop, clutch out and throttle fully closed, the engine will act exactly as if you’ve switched off the key (but you haven’t), and a small throttle opening will bring it back to life immediately.
The TB’s are well balanced with Mercury tube manometers.
TPS is spot on @ 4.6
CO trim is at +4
Strangely too, if you’re riding at highway speed, you can close the throttle, pull in the clutch and the revs will drop to a nice 1150 rpm idle, but the motor does not quit.
That is a confusing one..
I will accept that the bike has done a LOT of work and the TB’s are probably worn, but they are not the originals and seem to be in nice condition.
I cannot vouch for the Sacred Screw position, as they were given to me in a molested condition, but I have restored it as good as possible in the absence of a control set to recalibrate the setting.
I am suspecting a stepper motor issue, but that does not account for the high speed example that I gave.
Hmmmm….
Offline Tkelly
Re: Norge idle anomaly
« Reply #1 on: November 18, 2026, 04:13:07 PM »
Time for a new old Norge,fly to the US ,plenty for sale cheap,tour the USA and Canada !
Offline Pescatore
« Reply #2 on: November 18, 2026, 04:17:48 PM »
Sounds like an electrical problem, maybe coils or stepper as you mentioned.
The highway different behavior might be air cooling the coils.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline Huzo
« Reply #3 on: November 18, 2026, 04:23:48 PM »
Thanks for the input P.
I will hook up Guzzi Diag and see if there are any codes.
Online PJPR01
« Reply #4 on: November 18, 2026, 04:49:38 PM »
Cam sensor the most likely offender…secondarily could be the clutch sensor (cable with electrical connection).
When if ever were either replaced?
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline Huzo
« Reply #5 on: November 18, 2026, 05:00:42 PM »
Clutch lockout switch has been gone for 10 years. Never an issue.
Cam sensor ?
Only happens after trailing throttle when dropping to idle, fires up instantly.
May be looseness in the throttle plate/s, but never cuts out when idling.
ONLY…after trailing throttle.
Online PJPR01
« Reply #6 on: November 18, 2026, 06:08:13 PM »
Yup…can sensor.  A little research will show the same symptoms. If it’s never been replaced it could be the issue…they do degrade.  If the replacement fails at least you’ll know you have a fresh one.
Paul R
2008 Silver Norge
2002 V11 Scura
Offline Huzo
« Reply #7 on: November 19, 2026, 01:45:48 PM »
No codes….
Offline pressureangle
« Reply #8 on: November 19, 2026, 02:14:34 PM »
Dirty unbalanced injectors for $40, Alex.
Typically (which means I don't know at all for the Norge) fuel injection systems cut fuel entirely under coast-down conditions, strictly as a conservation measure. They usually cut back in about 500rpm above idle. This gives an extended 'dry run', emptying any charge from the cylinders; when you get to the cut-in rpm at idle, if your idle is a bit lean, which usually means lean on one cylinder- it can be too lean to catch. On the highway pulling in the clutch, the amount of time in coastdown zero fueling is minimal or zero- the systems I've reviewed don't cut fuel for a specified period of time, 2-5 tenths of a second which isn't served by the highway clutch scenario.
If you've never had the injectors serviced, perhaps it's time.
Offline SemperVee
  • USMC Retired
« Reply #9 on: November 19, 2026, 03:50:30 PM »
   I'd say electrical also Peter...  **Need another LOW miles compared to yours Norge?  Remember that visit to America you were *Gonna take>>>   JK-ing.. :^)
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
« Reply #10 on: November 19, 2026, 04:13:33 PM »
What!
This almost makes it sound electrical. Like water in the handlebar switches around the kill switch and starter button.
Can the starter be engaging and make you think the engine is cutting out?
Weird stuff.
Offline Huzo
« Reply #11 on: November 19, 2026, 06:58:09 PM »
It’s just had brand new ones from PJRP01 and they are great, they have been in a fair while with zero issues. This has just started, but I admit I am open to any thoughts.
What you say does carry some credence in my opinion.
« Last Edit: November 19, 2026, 07:01:50 PM by Huzo »
Offline Huzo
« Reply #12 on: November 19, 2026, 07:00:22 PM »
 :laugh:
:laugh:
Yeah I was and I flipped a coin to decide between USA and Europe, I had to flip it three times to get it to come down Europe.
Offline Huzo
« Reply #13 on: November 19, 2026, 07:02:52 PM »
What!
Weird stuff.
The scenario is just a bit too repeatable to be so random, but I’m listening…
« Last Edit: November 19, 2026, 07:03:35 PM by Huzo »
Offline Bulldog9
« Reply #14 on: November 21, 2026, 10:47:59 AM »
Huzo, did you go deep in the bush and draw an aboriginal curse?
« Last Edit: November 21, 2026, 10:48:32 AM by Bulldog9 »
MGNOC#23231
Offline Bulldog9
« Reply #15 on: November 21, 2026, 10:50:15 AM »
:laugh: :laugh:
Your loss...... Remember, the USA was built and made by the most adventurous and optimistic of Europe.....
MGNOC#23231
