Author Topic: Before I replace my steering bearings  (Read 54 times)
Offline nwguy
    • Jim Gallant's home page
« on: November 22, 2026, 09:17:08 PM »
on my 99' Bassa, a couple of questions. I read the manual and various posts on techniques for replacing the steering bearings, but I'm unclear on a couple of things. To dismantle the steering assembly, should I remove the instrument cluster via the two bolts shown in red here? Or can I leave it attached to the top triple clamp when I remove it?
To allow the top triple clamp to separate from the bottom equivalent, should I loosen the bolts at the top or the bottom (or both) of the vertical pieces that connect them?
Online Perazzimx14
Re: Before I replace my steering bearings
« Reply #1 on: Today at 03:40:01 AM »
I guess the biggest question is do the bearings need replaced? If the current ones are still operating smoothly what is the advantage of replacing them.
I would say yes, the instrument cluster needs to be separated from the top triple. I would also say that anything that is tying the top and bottom triple together like the headlight bracket will also need to be removed.
