Author Topic: rev-limiter setting  (Read 12920 times)
Orange Guzzi
rev-limiter setting
« on: April 30, 2009, 09:51:30 PM »
my 03' aluminum hits the rev limiter at the 6,900 rpm mark.  the red line is 8,000.  is this the normal range?
i have a pc3 on the bike.  i guess it only controls the fuel.  i did not see anything in the instructions regarding the engine timing or rev settings.
Wayne Orwig
Re: rev-limiter setting
« Reply #1 on: April 30, 2009, 10:46:18 PM »
I would say that your tachometer is off. That 15M is closer to 7800 RPM of so.
I don't know any practical way around it.
Offline gfritzmeier
« Reply #2 on: September 16, 2014, 04:03:47 PM »
I've also got a 2003 Aluminum and I hit mine at about 6500. I'm wondering what did you do to correct the problem.  My problem just began about a month ago. Was first told it was fuel filter but know it looks like rev limiter. Anybody??
Ya don't have to believe everything ya think!
Ride All Day,Play All Night!
Offline bad Chad
« Reply #3 on: September 16, 2014, 04:37:59 PM »
Your tach has to be off.
« Reply #4 on: September 16, 2014, 05:56:25 PM »
Maybe the sidestand is bouncing on the switch.
Adjust it if needed.
Offline Moto Fugazzi
    • Griso
« Reply #5 on: September 16, 2014, 09:19:49 PM »
The rev limiter just doesn't change on its own. Guzzidiag measures your RPM's, and at least you could verify your tach at idle. You can also change your rev limiter rpm with GD, but I don't recommend that.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
Offline gfritzmeier
« Reply #6 on: September 18, 2014, 11:17:48 PM »
Could be that I just noticed it recently. I may not of let it wind up like that previously. Anyway I was wondering if maybe it kicks in when it does because of the hydraulic valves?
Offline Stormtruck2
  • AKA Scotch and Cigars
  • Geese Fly in a Proper V
« Reply #7 on: September 18, 2014, 11:23:40 PM »
Are you gentleman implying that the Vegulia gauges could be inaccurate??   That could never be!  ::) ;)
μολὼν λαβέ-molṑn labĂ©
« Reply #8 on: September 19, 2014, 08:26:23 AM »
I don't believe the 2003 Aluminum has Veglia instruments. They are probably ITI, which is WORSE.  :o
« Reply #9 on: September 19, 2014, 08:28:18 AM »
No, the hydraulic lifter did not change the rev limit.
Check that switch if it is actually cutting out.
Offline gfritzmeier
« Reply #10 on: September 19, 2014, 09:57:35 AM »
Wayne,  I guess what I'm trying to ask is, Is it possible that the rev limiter is set(from factory) as lower rpm's because of the hydraulic valves. Just a thought as it is my understanding that with hydraulic is they run better at a little lower rpm's.    What say you?  The switch seems to be OK
« Reply #11 on: September 19, 2014, 10:20:45 AM »
No, my 2004 hits the limiter somewhere near the redline as expected.
Offline gfritzmeier
« Reply #12 on: September 23, 2014, 01:23:54 PM »
 >:(  Previously I thought I was hitting the rev limiter because that's what it felt like.  I first noticed it after I put on some higher flowing mufflers so today thinking it might have something to do with the mufflers I put the originals back on and now rather than feeling like I hit the rev limiter the engine just stops. I turn off the key, only sit for about 10 to 15 seconds and the bike starts right up.
Now this baffles me and I'm hoping it doesn't for some of you.
Any ideas ??????
andrewdonald1
« Reply #13 on: September 23, 2014, 01:30:46 PM »
I am sure someone probably said this, but what about a problem with a fuel filter if you have one.
After you shut it down, maybe it allows enough reduced gas flow (like a buffer tank) to restart.
Offline gfritzmeier
« Reply #14 on: September 23, 2014, 01:44:37 PM »
That's what I was wondering.
« Reply #15 on: September 23, 2014, 01:45:18 PM »
Not to rule anything out, as it could be anything, but it sounds electrical with the sudden cut off.
I would try replacing, and swapping, the relays.
And it still sounds like a sidestand switch.
Orange Guzzi
« Reply #16 on: September 24, 2014, 05:02:21 PM »
I had made another post regarding tachometers.  On my Sport 1100, the engine would shut off suddenly at high rpms.  A thought maybe that is how the rev limiter worked on the bike.  I disconnect the oem tachometer and the bike did not shut down at high rpms in the same way.  It was more of a stuttering.  You can disconnect the tach and see if that make a difference.
Offline gfritzmeier
« Reply #17 on: September 30, 2014, 10:58:09 PM »
 :bike   I think I figured mine out but it's even baffling as to why what I did makes sense.  I probably should have mentioned some of the changes I did to my bike before this started. I opened up my air box lid by cutting off the snorkels and drilling large holes in the lid..having never had a Guzzi previously not being able to short shift without shuddering bugged me. Allowing more air into intake gives the bike more low RPM power. I could now pull smoothly from 1500(approx) in 3rd gear. Then as I said previously I put on mufflers that flowed freely.  Stutters with after market muffler and stops with OEM muffler.  So I reasoned that maybe because it took in so much are that it needed to get more air out faster so I put on some megaphones and now it will run up to red line. Runs great so I'm happy.  Doesn't necessarily make sense but I'm not going to waste time trying to figure out why it works but it does.
Offline gfritzmeier
« Reply #18 on: March 25, 2016, 02:23:03 PM »
Now to bring this issue up again 1 1/2 years later.  Late last fall my Alum. will run great up to 6500 rpm and then start cutting out. I don't know what to do. ReMap maybe or any suggestions you guys have. I'm not sure if a power commander is the answer. Got my confused. Not that it's a problem for riding but it something that's not right and I'd like to get it cured.   ?????????????
« Reply #19 on: March 25, 2016, 05:34:17 PM »
get GD and check the acuracy of your tach.
assume you check out the sidestand cut out switch, right? do you have an electric fuel tap and is it opening all the way?
Offline flip
« Reply #20 on: March 25, 2016, 05:52:35 PM »
A couple of years ago, I picked up a used Shiver. After riding for a little while, it would suddenly refuse to rev past 6000 rpms. After a couple of trips back to a dealership with them contacting the factory, it turned out to be an O2 sensor that apparantly was going bad and would show some strange readings. A new O2 sensor fixed the problem.
Could this be it?
North Carolina
« Reply #21 on: March 25, 2016, 08:26:28 PM »
Could this be it?
Since a 2003 Aluminum does not have such a thing, no.
Offline flip
« Reply #22 on: March 25, 2016, 09:03:47 PM »
Ok, I just break them. I don't know how to fix them.
North Carolina
Offline gfritzmeier
« Reply #23 on: March 25, 2016, 10:30:28 PM »
OMG---thanks for your reply as I was dragging out a workshop manual to try to find what I didn't think I had.
Offline Groover
    • Scooteropolis
« Reply #24 on: March 26, 2016, 12:06:12 AM »
^ ageed with the rodekyll'spost above. Limiters are typically set at the ECU. PC3's override the fuel maps, but not the RPM limiter. To remove that limit in bikes I've had in the past, the ECU required a flash/firmware update to a performance type map, then you can tweak with the PC3.
PC3's enable easy access to the maps, and that's a pro and a con. I'd also say take that out and start from the bottom up, then put it back in once sorted.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline gfritzmeier
« Reply #25 on: March 26, 2016, 03:59:16 PM »
Be happy to remove the PCIII but I don't have one on the bike.
Offline gfritzmeier
« Reply #26 on: March 26, 2016, 10:27:28 PM »
 Now to tell you something about my mechanical abilities. Until I retired if something were wrong with my bikes I would bring them to a shop to get fixed. I've driven Triumphs mostly and haven't had one that needed much since the 60's. In other words I've did nothing other than oil changes for years. Well as this is my first Guzzi and I'm retired I do most of the work or try. Well when I was looking at my workshop manual today I thought crap I think I put the ECU in backwards last year. Out to my garage and sure enough I had. I corrected that and reattached it. I then started bike and then revved it up to red line without a problem. In a couple days the weather should be good enough to get it out and see what it's like on the road.
Offline gfritzmeier
« Reply #27 on: March 27, 2016, 04:46:16 PM »
I've got about the same mechanical potential as that except for the taking it to a shop part.  I haven't done that yet.  That said, the only part of your post that I understood was where you revved it to redline, apparently on the stand.  Maybe someone who does this for a living will correct me, but I don't think you should be redlining an unloaded engine.  the other part -- installing the (15M) ecu backwards -- How is that possible?
Rodekyll,,,,, Very easily. By looking at the manual I could see that the flat part of ECU was to face out and I had the fins facing out. Also it states that the ground cable belongs on the upper left corner of the ECU. Now I don't know if that particular corner makes a difference but it did then I had it connected wrong because I had the ECU turned around.
Offline gfritzmeier
« Reply #28 on: March 29, 2016, 08:53:08 PM »
I don't have a Pc3 on my bike but I will shortly. I have no idea if what's actually happening is rev limiter or is running lean because of the modifications I've made. Hopefully this works.
« Reply #29 on: March 29, 2016, 10:14:43 PM »
Do you have the Guzzi Diagnostics software and cable.
It is so cheap, it is foolish to NOT have it. You can then get a much better idea what the REAL revs are. You can see if the injectors are being cut off, or if the TPS value is going nuts. Or you can speculate for a few more weeks/months/years about it.
« Last Edit: March 29, 2016, 10:15:08 PM by OMG »
