Author Topic: B11/Norge Startus Interruptus-the MPH Solution  (Read 83311 times)
Offline mphcycles
Re: B11/Norge Startus Interruptus-the MPH Solution
« Reply #30 on: August 19, 2011, 06:34:59 PM »
 We will have a batch of 8 ready to ship on Monday of the version with no relay.  I had to upgrade my used bikes dept first!
  25 bux shipped in the CONUS.
 I have more components on order and we will make more when they arrive next week.  It was a test  balloon,  and I see you guys want  it.  So we will do it,  and ship them out as ASAP.
 The relay does serve a purpose, my bike would get the relay because of the voltage drop noted.
Several guys have already done the mods as posted before. The idea here is to make it  as easy and not scary as it can be made.  If you are OK with wiring mods, you don't need this, if you don't relish  cutting wire on your bike , you can use it.  Its not rocket surgery but it does work.
Mike Haven
MPH Cycles
16510 Park Row
Houston, Texas 77084
832 557 7214
www.mphcycles.com
 (Please just email me ,  I dont PM)
Frank Smith
« Reply #31 on: August 19, 2011, 07:43:58 PM »
We want to see rocket surgery!  Dammit!
Offline ken farr
« Reply #32 on: August 19, 2011, 09:44:54 PM »
Yeah, well Rocket Surgery ain't nothin' compared to Brain Science.
( or something like that )
 ;D
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Offline Crusty
« Reply #33 on: August 20, 2011, 04:32:43 AM »
I can't decide whether I want to be a Brain Surgeon or a Soda Jerk.  Jethro on The Beverly Hillbillies ca. 1964
'07 Norge
Offline PICKLEKOOKEN
  • 74 ELDO ( MOTHER GOOSE) 2007 NORGY
« Reply #34 on: August 20, 2011, 09:30:07 PM »
Ill take one too Mike left me know when you get downto my name Pic.
So many curves. so little time!
Brian UK
« Reply #35 on: August 21, 2011, 03:47:35 AM »
  After some peer review I have modified the  part to eliminate the relay.  I put it there because of the low Kl.15 voltage  I measured  on all the bikes. I have seen as much as a 6V drop on this circuit.  Maybe I am over thinking it a bit.  I hate voltage drops on anything.
  It seems that Wayne's fixes have not seen any other effects of that low voltage, and this new set up simply addresses the low voltage to the start relay and not  supplementing  the whole bikes Kl 15 , ignition on circuit.  This is much simpler to make and uses less parts, so we can offer it for less $$ .  its gets you the same result of a reliable starter operation, but wont have any effect on anything else.
I suspect that when you put this version in place, you won't see the voltage drop on the other part of the ignition circuit. I believe the drop was caused by the high current required by the starter solenoid being routed through the ignition switch, which this latest version avoids.
Offline mphcycles
« Reply #36 on: August 21, 2011, 05:11:43 AM »
 The simple version will be the only one  offerred.  Simple is good, 20 bux US shipped in CONUS.  Should start going out next week.
Mike Haven
MPH Cycles
16510 Park Row
832 557 7214
www.mphcycles.com
Offline blackbuell
« Reply #37 on: August 21, 2011, 06:36:08 AM »
Mike,
You should have my address and card on record. Please send me one.
Jon Hastings
Offline old head
« Reply #38 on: August 21, 2011, 08:20:46 AM »
Mike,
I'll take one also,
Old Head
06 Breva 1100
Hepco-Becker crash bars
Givi A620 screen
Garmin GPS
Offline Crusty
« Reply #39 on: August 21, 2011, 11:19:33 AM »
Mike; I tried calling on Friday evening, but I think you were already closed. I was going to call you yesterday, but Terri and I went out for a ride, and by the time I got home, it was too late. I don't know if you're open on Mondays, but I'll try then.
'07 Norge
Offline jdgretz
  • Proud Owner of a Red Norge
« Reply #40 on: August 21, 2011, 01:41:01 PM »
Sounds like a great addition.  I'll take one as well.
jdg
1999 Honda Helix - Zippy
2008 Honda Goldwing
Offline Crusty
« Reply #41 on: August 22, 2011, 09:33:41 AM »
Hey; I got through and ordered one! Now all you have to do is figure out how to pronounce Leominster.  ;)
'07 Norge
« Reply #42 on: August 22, 2011, 10:31:00 AM »
Phone hiccup
« Last Edit: August 22, 2011, 10:42:18 AM by Kev m »
murphy
« Reply #43 on: August 22, 2011, 10:47:17 AM »
Count me in too Mike. Thanks for putting this together.
Murphy
Offline HDGoose
« Reply #44 on: August 22, 2011, 11:32:15 AM »
pretty much the same solution I had to do on my Electra Glide.
kitze2
« Reply #45 on: August 22, 2011, 11:53:09 AM »
Ordered one today. Along with a couple of gaskets and a T-Shirt.
Offline Eric
« Reply #46 on: August 22, 2011, 05:32:52 PM »
I'm really sorry to ask this but I've been away from the board for a while and I couldn't find anything with the search feature. What problems does this solve?
07 Norge
15 BMW F 800 R (Lori's bike)
2016 Ural Patrol
13 Triumph Bonnie w/sidecar
Moorhead, Minnesota
Gone: 2005 Ural, 2011 Ural, 2003 EV, 2005 750 Breva
DanR
« Reply #47 on: August 22, 2011, 06:47:59 PM »
Start here
http://wildguzzi.com/forum/index.php?topic=43725.0
This
http://wildguzzi.com/forum/index.php?topic=46270.0
Offline Eric
« Reply #48 on: August 22, 2011, 07:18:47 PM »
Thanks!
07 Norge
2016 Ural Patrol
Moorhead, Minnesota
Offline Eric
« Reply #49 on: August 23, 2011, 07:53:42 AM »
How incredibly wierd. I have never had this problem in the years that I've owned the Norge. Yesterday I read this thread and this morning I press the starter on the Norge, the light show finishes, I press the starter and a loud click and the dash goes dark. Conicidence? Or does Guzzi not give you trials greater than the board's strength to deal with it?
07 Norge
2016 Ural Patrol
Moorhead, Minnesota
« Reply #50 on: August 23, 2011, 08:05:47 AM »
;D That's pretty much it..
Offline jreagan
« Reply #51 on: August 23, 2011, 08:14:57 AM »
Dash goes dark?  That is a little different.  Check the battery connections and the ground by the starter.
"Loud Valves Save Lives"
2004 Triumph Bonneville T100
2006 Breva 1100 (red)
Nicholasville KY USA
DanR
« Reply #52 on: August 23, 2011, 09:02:35 AM »
Original Battery ? could have went belly up
Offline Dean Rose
    • Twin Valley Riders
« Reply #53 on: August 23, 2011, 09:09:41 AM »
Batteries are like the weather. You never know when they'll go bad. I seen new ones go bad in days.
Dean
Magnolia '02 EV
Sophia '06 Breva 1100
Offline Eric
« Reply #54 on: August 23, 2011, 09:25:54 AM »
Hmm.  I'll have to look into those possibilities.  Yes, the dash goes dark and all is dead. It's the original battery. I had to ride the Ural into work today. Sad thing when your Ural becomes your reliable bike....
07 Norge
2016 Ural Patrol
Moorhead, Minnesota
Offline Crusty
« Reply #55 on: August 23, 2011, 10:37:38 AM »
Eric; I had the same thing happen to my Norge. One of the bolts for the terminals was loose.I tightened it and all was well again.
'07 Norge
toddhaven
« Reply #56 on: August 31, 2011, 11:40:21 AM »
First batch is ready to ship.
$20 shipped in US.
Overseas shipping at cost. An addition $25 to most of the world.
Paypal to todd@mphcycles.com
Those of you for whom I have CCs on file and who have put your hands up will ship first.
Nick, BC, kitze, will ship today.
Offline jdgretz
« Reply #57 on: August 31, 2011, 12:29:47 PM »
PayPal sent.
Thanks,
jdg
2008 Honda Goldwing
« Reply #58 on: August 31, 2011, 12:38:17 PM »
$20 shipped in US.
Thanks.
Offline Crusty
« Reply #59 on: August 31, 2011, 03:02:43 PM »
Well; Since I called and spoke to you, and gave you my credit card #, I'll assume that I'm one of the fortunate ones.
Yahoo!
'07 Norge
