Author Topic: Can I Fit Tubeless Tires to Factory Cast Wheels?  (Read 24398 times)
dilligaf
Re: Can I Fit Tubeless Tires to Factory Cast Wheels?
« Reply #30 on: January 21, 2014, 09:02:27 PM »
mtiberio wrote:  Yes, but at speed, centrifugal force is keeping the tank valve in....   8^))
Sir, you got me.  I  have a high school education and I graduated very near the bottom of my class.  :BEER:
Matt
Offline Guido Valvole
« Reply #31 on: January 21, 2014, 09:10:34 PM »
The original poster asked about the Harper's valves. I just went tubeless with them last week, Avon Roadriders on a V50 Monza. There is a rubber (maybe neoprene) seal on the inside that forms to the very curved center section of the skinny smallblock wheels just fine. I noticed a little pressure loss, more likely because it was 70º when the tires were mounted and 45º Saturday morning. Same amount of pressure decrease in the V50, which has the same tires with tubes.
They work. Roadrider front gloms into rain grooves almost as badly as a Metzler Lasertec but there aren't many other choices for skinny old alloy rims.
cr
V50 II
V50 Monza
Le Mans 1000 (IV)
Martinez, CA
« Reply #32 on: January 22, 2014, 08:24:57 AM »
cr,  if they have the right size try Sport Demons.  I also have few choices with my 16" rims.
Online Wayne Orwig
« Reply #33 on: January 22, 2014, 08:52:27 AM »
Bearing in mind the concave shape of the internal surface of the Guzzi wheel,
does the rubber seal sit nicely in place without the nuts being done up excessively tight?
Some of them, like the one in the photo above, seal on the OUTER surface of the rim.
« Reply #34 on: January 22, 2014, 09:45:29 AM »
The stem thingy's I have use rubber washers on the inside and outside.
Offline Stevex
« Reply #35 on: January 22, 2014, 12:03:47 PM »
But I'm not talking about the one in the photo, If you'd quoted my upper two lines you'd see I was talking about the Harper's item in which the seal is on the INNER surface of the rim.
However, I am considering making up a spacer that fits the concave inner rim surface and provides a flat surface for the nut, so I can indeed fit the racing valve stem in the photo  ;D
« Last Edit: January 22, 2014, 12:06:51 PM by Stevex »
Offline Guzzi_Don
« Reply #36 on: January 22, 2014, 02:04:30 PM »
cr
Thanks CR for the detailed description of your conversion. I will email Harper's as I doubt these valves are available here in Australia.
Cheers
Don
1981 Moto Guzzi 850-T4
1977 Suzuki GS550/700
1991 Suzuki VX800
Offline Guzzi_Don
« Reply #37 on: January 22, 2014, 02:07:01 PM »
Charlie thanks for the recommendation on the Sport Demons as this is the other half of the job to be done after the valves are replaced.
Sport Demons are tubeless?
Cheers
Don
1991 Suzuki VX800
dilligaf
« Reply #38 on: January 22, 2014, 02:25:12 PM »
I believe the Guzzi part number for 8.3mm tubeless valve stems for my 87 Le Mans is 28617760.  Why not give Pete a call?   :BEER:
Matt
Offline Curtis Harper
    • Harpers Moto Guzzi
« Reply #39 on: January 22, 2014, 03:25:43 PM »
Can someone from Harpers contribute to this thread and verify that the valve they are advertising will fit and do the job?
Yes these stems will work in the Guzzi wheel. Have been using them for years without issue. the rubber will conform to the concave part of the rim and seal fine.
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
dilligaf
« Reply #40 on: January 22, 2014, 03:50:54 PM »
Well there you go.  Simple and safe.  ;-T  :BEER:
Matt
Offline Greg Field
  • The Signs Foretell the Rise of a Guzzi Lama . . .
« Reply #41 on: January 22, 2014, 05:40:23 PM »
What Curtis says is true, but be careful to not over-torque the nut on the i.d. of the wheel's rim, or it can crack the shoulder on the valve's stem, and then it will leak. Ask me how I learned this . . .
« Last Edit: January 22, 2014, 05:41:18 PM by Greg Field »
« Reply #42 on: January 22, 2014, 05:54:18 PM »
Yes, they are.  I use a Sport Demon on the front and cheap Shinko's on the back (the rear Sport Demon only went about 6k miles, the front went well over 10k).
« Reply #43 on: January 22, 2014, 06:03:45 PM »
This is what I've been using on the Lario to good effect.
Offline Guzzi_Don
« Reply #44 on: January 22, 2014, 06:42:06 PM »
Thanks Curtis,
MUCH Appreciated
Cheers
Don
1991 Suzuki VX800
Offline Guzzi_Don
« Reply #45 on: January 22, 2014, 06:43:34 PM »
AND . . . Thanks Greg for that valuable information.
Cheers
Don
1991 Suzuki VX800
« Reply #46 on: April 20, 2016, 02:49:22 PM »
FWIW I have been running tubeless on my California II for several years, I used regular tubeless stems, I had to file a flat on the inside and outside to take the seals. Tank valves are probably a better way to go.
I'm also running tubeless on my 72 Eldorado and that has spokes. I have had a bit of trouble with these leaking around the spoke nipples but they have never gone down as fast as a tube puncture can and never left me stranded.
« Last Edit: April 20, 2016, 02:52:08 PM by Kiwi_Roy »
