Author Topic: 09 Stelvio - Service message and Red triangle are on  (Read 15346 times)
vrybl
« on: April 07, 2014, 02:07:40 PM »
I have bought this bike with 8K miles about 2 month ago, I have replaced leaking oil sender sensor and resealed leaking crankshaft position sensor, but now after riding in a bit of rain for 10 minutes I noticed the speedometer jumping rapidly from 0 to 90 mi/hr.  At this point the "Service!" message and red triangle are on, and I can't seem to enter any other menus to look up failure codes on the dash except for heated grips.  Is this normal not to be able to enter system menu with "Service!" message on.
All ideas on what is going on with teh menu or speedometer are welcome.
Cheers,
Vlad.
Offline rdbandkab
Re: 09 Stelvio - Service message and Red triangle are on
« Reply #1 on: April 07, 2014, 02:18:59 PM »
Didn't the 09's come with a flakey(when wet) wheel speed sensor?
If so, it can be dried out and sealed..
I'm sure someone with more knowledge of the subject will be around soon.
Possible link for more info:  http://wildguzzi.com/forum/index.php?topic=54559.0
« Last Edit: April 07, 2014, 02:20:42 PM by rdbandkab »
biking sailor
« Reply #2 on: April 07, 2014, 02:44:15 PM »
I've heard defective plug wires will make the dash go nutty also. I would try the turn off, wait, and then turn key back on to see it it clears.
Are you broken down on the road?
Offline samfrank
« Reply #3 on: April 07, 2014, 03:09:01 PM »
Red warning light on, eh?  Welcome to the club!!
1973 Eldorado
2013 Norge - moving to Arizona to live with John.
2015 Yamaha FJR1300
Offline samfrank
« Reply #4 on: April 07, 2014, 03:10:34 PM »
The red warning light has been coming on and off intermittently for close to three years on my "07 Norge. Still runs without a hiccup, however!
1973 Eldorado
2015 Yamaha FJR1300
Offline Scott of the Sahara
« Reply #5 on: April 07, 2014, 06:48:58 PM »
08 Norge. Service light came on yesterday when I started it up. I rode for about a mile and a half and stopped the bike. When I started it up the light was out. This is the second time. Once about this time last year, same thing.
Offline ChuckH
« Reply #6 on: April 07, 2014, 06:52:49 PM »
09 Stelvio - Service message and Red triangle are on...Vlad.
On my '12 Stelvio the Service Interval Icon (a small wrench image on the screen) appears every 6000 miles, since that is the recommended service interval.  I can remove it by toggling through the screens with the left Control Button to the "Menu" screen.  There is no science to this, sometimes it is a real PITA, I just have to keep trying.  From the "Menu" screen I go to "Diagnostics".  I input my code -- frequently it is "10695".  Then I go to "Remove Service Interval", toggle to "Yes" and remove it.
I caution you here.  Your '09 is the earlier model, my '12 is the later model.  There may be differences in how to handle this change on your model bike.
Last, I have no knowledge of how to handle the Red Triangle.  Sorry.
Re:
« Reply #7 on: April 07, 2014, 09:23:22 PM »
My 09 and many others did this. The rain water gets into the speed sensor and kills it. You may be able to dry it out and seal it. Or just replace it. They were upgraded in about 2010 and the new ones are good.
Sent from my SCH-I545 using Tapatalk
Re:
« Reply #8 on: April 07, 2014, 11:51:55 PM »
My '09 did exactly the same.   Speedo goes nuts, red triangle comes on and scares me half to death ... find out that's what happens when the speedo sensor on the back wheel gets wet, no harm to ride it like that.
Take speedo sensor off, dry it out good, seal it up with silicone to prevent water incursion down where the wire goes into the box, buy another one for $70 in case your fixed one fails again, new one still sitting on the shelf 3 years later .... !
vrybl
« Reply #9 on: April 08, 2014, 07:13:53 AM »
Thank you all for the input.  I will start addressing the speedo sensor.  Is the idea that the "Service!" message and the red triangle go away once the speedo is sorted out?
« Reply #10 on: April 08, 2014, 11:39:08 AM »
Yes, the service message and red triangle pop up when the dashboard realizes that you are in gear, clutch out, high revs, but zero speed.
Offline Dilliw
« Reply #11 on: April 08, 2014, 11:56:14 AM »
Well you could be in one of those Daytona bike week burnout pits  ;-T
George Westbury
Austin, TX
« Reply #12 on: April 08, 2014, 11:58:36 AM »
I first thought that, but then realized that the speedo sensor is detecting rear wheel revolutions, so a burnout wouldn't spook the dash.
A completely trashed clutch, broken transmission, or broken universal joint would do it though .....
vrybl
« Reply #13 on: April 09, 2014, 10:51:05 PM »
Well, the problem was almost with speedometer sensor.  As suggested here and elsewhere the wires/connector under the seat leading to the speedo sensor had bent pins, once pins were straightened out and reconnected, the "Service!" message disappeared.   I had the speedo sensor sealed anyway as suggested.
Much Much Much Thanks,
Vlad.
« Reply #14 on: April 10, 2014, 05:35:17 AM »
Vlad.
Speedy service from WG, as usual.. ;-T
bmacneil2008
« Reply #15 on: December 31, 2014, 05:50:02 PM »
Have to love this forum, has helped me more than a few times. Even donated. Yes, 100% same issue, 4 hour ride in the rain yesterday and now after a good cleaning, red light, no MPH. So where is the sensor?
« Reply #16 on: December 31, 2014, 05:58:21 PM »
Rear wheel on the 09.
You will see the wire tied to the rear brake line.
bmacneil2008
« Reply #17 on: January 01, 2015, 11:48:25 AM »
Yes, took the rear wheel off and thought I could open the sensor and use a blow drier but seems sealed. I can see where water gets in by the wire leading into the box. I will just have patience and wait a few days and see if all ok then will apply sealant around the wire. So when is all dry, the red light and service alert does not show? Or do I have to put the tire back on and spin it so the sensor responds before the dashboard resets?
Offline Spuddy
« Reply #18 on: October 16, 2023, 12:17:59 PM »
My '13 NTX has an intermittent Service Triangle for 36,000 miles. Dealer and importer have no idea. No speedo issues but I'm gunna look there anyway. Like others, the Triangle has not identified any issues.
Spud
'13 Stelvio NTX
'07 California Vintage
'01 W650
Offline Huzo
« Reply #19 on: October 16, 2023, 03:43:21 PM »
Oil pressure sensor.
Offline Huzo
« Reply #20 on: October 16, 2023, 03:47:52 PM »
Spud
Can’t you bring up stored fault codes ?
