Author Topic: Rear end venting?  (Read 5709 times)
motogodie
Rear end venting?
« on: April 28, 2014, 09:26:26 AM »
I took my 98 Cali out for a ride today to heat up engine and rear drive for an oil change.I drained the engine oil then started taking the drain plug out of rear drive.I didn't take out the fill screw and when I had the bottom(drain) plug almost out the oil came out like it was under pressure(it was) and made a loud hiss!Is this unit supposed to be vented or is it OK to build up pressure like this?Also Ill be sure to take out the fill plug first in the future to let this pressure off! Thanks
Offline Perazzimx14
Re: Rear end venting?
« Reply #1 on: April 28, 2014, 09:43:13 AM »
Some are vented, some are not. It doesn't hurt to vent them. One way to do it is drill a hole in the top of the fill plug. Tap it for a 10mm banjo bolt. The buy a SS braided brake line with only one banjo fitting on it and extend it up under the seat or tank. Anyplace that is dry and out of the way. It wouldn't hurt to install a small filter (think small fuel fuel) filter to keep dust from entering.
« Last Edit: April 28, 2014, 09:44:50 AM by Perazzimx14 »
Offline L.A.kevin
« Reply #2 on: April 28, 2014, 09:47:06 AM »
An alternative to venting is to burp it. When you change the rear drive oil, take it on a good long drive to heat it up. Then, stop somewhere and quickly get off the bike and release the pressure. It will then have a vacuum when you put the cap back on and let it cool.
« Reply #3 on: April 28, 2014, 04:51:08 PM »
  This is MC related, right?
« Reply #4 on: April 28, 2014, 04:55:11 PM »
I was gonna give you another hour or two before asking the same question  ;D We used to have a very talented blues band here " Michael James and the blue flames" , any relation Jim ? :D
motogodie
« Reply #5 on: April 28, 2014, 06:11:20 PM »
I guess I could have worded the title a little different but you got the drift of it anyway!Thanks for the ideas on venting it. ;D
Offline Markcarovilli
« Reply #6 on: April 28, 2014, 06:57:49 PM »
So we got -rear end venting - rear end oil -
Can't wait for the next instalment.......
Mark
« Reply #7 on: April 28, 2014, 06:59:51 PM »
this
Offline Rotten Ralph
« Reply #8 on: April 28, 2014, 08:02:31 PM »
Mark
I believe we had that already with Rocker's "prison lovers" comments. ;D ;D ;D ;D
Never trust a dog to guard your food
03 HD RK / TLE car
65 BMW R69S
60 BSA Gold Star
13 Moto Guzzi V7 Special
Offline Crusty
« Reply #9 on: April 28, 2014, 08:27:40 PM »
Rear end venting?
Just pull my finger...
'07 Norge
« Reply #10 on: April 28, 2014, 09:10:36 PM »
 No but back in the seventies in Oregon, there used to be an old time rock & roll band called "Buzz Farts and the boppa dips".
 They were pretty good too.
« Reply #11 on: April 28, 2014, 09:45:11 PM »
Burping the fller plug works.
Offcamber1
« Reply #12 on: April 28, 2014, 10:03:58 PM »
Hmmm.  We have a local Blues band out of Terre Haute that goes by "Dicky James and the Blue Flames."
Also talented.
« Reply #13 on: April 28, 2014, 10:17:13 PM »
Also talented.
3rd cousins on their father's mother's daughter's uncle's nephew's side . 'sup Kip ?
Offline Yeahoo Whoyah
« Reply #14 on: April 28, 2014, 10:44:25 PM »
 wouldn't rear drive pressure cause lubricant to be forced out and then fling onto tire and wheel?
Greg Tillitson
El Dorado Hills Calif.
« Reply #15 on: April 28, 2014, 10:45:52 PM »
No.
Offline Robert
« Reply #16 on: July 26, 2016, 05:25:08 PM »
My 2007 Calvin had its rear end oozing and dripping on the rear tire and rim as it sat from Spring to Summer in the increasing heat.
I pulled out the level check plug, and it whooshed air out, and about 1 teaspoon of lube.
I would think the pressure made it leak.
So I found this thread.  I assume my (motorcycle's) rear end is not vented.  I'll ride it some (was waiting for new 'improved' tail light bracket which is now installed), and monitor things.  Maybe try burping, and then venting, depending???
Offline normzone
« Reply #17 on: July 26, 2016, 05:39:42 PM »
Don't you just despise people responsible for thread drift ?
" That's the last time I play this shit, I'm going to England "
https://en.wikipedia.org/wiki/Jimmy_James_and_the_Blue_Flames
Offline twhitaker
« Reply #18 on: July 26, 2016, 07:37:24 PM »
The rear drive is supposed to vent through the transmission.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
