Author Topic: Nasty piece of metal on engine oil drainage  (Read 15363 times)
Offline Mike Tashjian
Re: Nasty piece of metal on engine oil drainage
« Reply #30 on: August 09, 2014, 04:15:58 PM »
I would not sleep well without looking everywhere.  I would have to verify everything is still good.  That just seems like some pretty big swarf to be making it's way through your motor.  Mike
Offline twhitaker
« Reply #31 on: August 09, 2014, 05:25:17 PM »
Is that chip magnetic? There was a thread within the last several months that had a piece quite similar to that. It was an extruded piece of a con rod bearing shell.  :o
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
Offline dan_s
    • http://www.world-designs.co.uk/forum/member.php?u=128
« Reply #32 on: August 09, 2014, 11:05:36 PM »
Thank you all for the advice.
Offline Stevex
« Reply #33 on: August 10, 2014, 04:30:21 PM »
When I initially stripped my LM2 engine this came out, never did find out where from.
These were the cam followers, I believe they're the originals, after 34K miles. Replaced all 4.
Offline dan_s
« Reply #34 on: August 28, 2015, 04:02:49 PM »
Yet more gunk on oil change, black magnetic type, the sump was full with it, oil in the rockers area was clean.  To make it short, it  came from the oil collector box. Tappets, rockers and camshaft are good.
« Reply #35 on: August 28, 2015, 04:06:38 PM »
  What kind of oil are you running , and have you put a magnet to this gook ?
« Reply #36 on: August 28, 2015, 04:47:48 PM »
Are you sure it isn't the oil pan magnet itself? They've been known to self destruct.
Edit:
didn't see the scale down there. Looks like more than a magnet..
« Last Edit: August 28, 2015, 04:49:26 PM by Chuck in Indiana »
« Reply #37 on: August 28, 2015, 05:22:17 PM »
That looks like one peened end of the "distributor" drive gear pin.
« Last Edit: August 28, 2015, 05:22:58 PM by Antietam Classic Cycle »
Offline dan_s
« Reply #38 on: August 29, 2015, 06:01:22 AM »
Its magnetic rust
