Author Topic: Nasty piece of metal on engine oil drainage  (Read 15439 times)
Offline dan_s
    • http://www.world-designs.co.uk/forum/member.php?u=128
« on: May 31, 2014, 06:58:05 AM »
Found this piece of steel attached to the engine oil drain plug magnet. ~1000km ago I replaced the camshaft and tappets. The motor runs great. Drained oil looks clean with no metal flakes.
From distributor/camshaft gear?
Online Chuck in Indiana
Re: Nasty piece of metal on engine oil drainage
« Reply #1 on: May 31, 2014, 07:18:39 AM »
I wouldn't think so, but I'm clueless as to what it is..
Offline raul
« Reply #2 on: May 31, 2014, 07:44:39 AM »
Could it have been lodged somewhere and only just now moved around enough to catch on the magnet?  As black as it is, it appears to me to have been in there a while through a lot of heat cycles.
Offline acogoff
« Reply #3 on: May 31, 2014, 07:58:56 AM »
    Looks like a piece of schrapnel. Rocket attack on the oil bottling facility gets my vote.
Marshall County Minnesota USA
Offline kevdog3019
« Reply #4 on: May 31, 2014, 08:22:35 AM »
Looks like one of Luigi's long fingernails to me.  :P
K
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
sonicboom
« Reply #5 on: May 31, 2014, 08:30:50 AM »
Almost looks like a peeling from bearing contact area or bearing peel itself. It would be off a large one, not anything small. Turning black it was cooked and not by oil heat cycles that was cooked by friction.
First impression.
Offline bobdar
« Reply #6 on: May 31, 2014, 09:09:07 AM »
It would be about 6 mm in diameter if it started out as circular.
« Last Edit: May 31, 2014, 09:09:40 AM by bobdar »
bob darcey
lakewood, colorado
'75 850T
'56 Matchless G80
« Reply #7 on: May 31, 2014, 09:10:34 AM »
It looks like a typical lathe or milling machine chip.  I wonder if it was stuck on something when the engine was originally assembled and finally fell off, or something similar.
« Last Edit: May 31, 2014, 09:11:45 AM by Triple Jim »
Offline dan_s
« Reply #8 on: May 31, 2014, 09:24:28 AM »
I'd really like to blame Luigi but the last person to drop the sump was me. The new cam was a regrind with some king of black coating. could be a gear tooth. Will have to open things to know more.
Offline Yeahoo Whoyah
« Reply #9 on: May 31, 2014, 09:27:17 AM »
Which model and year Moto Guzzi are we talking about here?
Greg Tillitson
El Dorado Hills Calif.
Offline dan_s
« Reply #10 on: May 31, 2014, 09:57:40 AM »
1980 LM 2. Reground cam to B10 spec.
Offline ItsForrest
  • Ugly Bag of Mostly Water
« Reply #11 on: May 31, 2014, 12:05:02 PM »
My guess would be lathe or milling chips as suggested previously. I have found the same in a Guzzi engine.
When I bought bought my last new Guzzi, a 96 Sport 1100, one of the guys at Moto International suggested I check things out carefully when I did my first valve adjust. Sure enough, I found significant amounts of metal chips left over from manufacturing inside the oil passages to the valve gear.
It would not surprise me in the slightest if that was hiding in a corner of the engine since birth and you somehow dislodged it when doing the cam work.
The urge to buy terrorizes!
Offline dan_s
« Reply #12 on: May 31, 2014, 12:53:24 PM »
This photo is from the guzzipower.com website
Online Wayne Orwig
« Reply #13 on: May 31, 2014, 02:16:32 PM »
Have you looked at the cam lobes up through the sump?
It is magnetic, right?
« Reply #14 on: May 31, 2014, 06:49:12 PM »
I've made a few chips in my day.  ;D For a machined chip to look like this, it needs a long uninterrupted stroke like a shaper. I'm sure there's no manufacturing machining operation on Guzzis that use one. Oh, you could make something like this on a lathe, but without a chip breaker on the tool it would just wind around the chuck and make a mess. Not likely, IMHO.
« Reply #15 on: May 31, 2014, 06:56:39 PM »
I was really thinking of something like a large end mill.  A fairly heavy cut with a 1" cutter could make a chip something like that, but I'm not sure what piece of steel in a Guzzi engine would be big enough for a machining operation like that.
Edit:  Maybe a rough cut on the crankshaft, and a chip got stuck in it?  Agreed that it sounds unlikely, but I'm not sure the real answer will sound very likely either.   :)
« Last Edit: May 31, 2014, 07:00:07 PM by Triple Jim »
Rough Edge racing
« Reply #16 on: May 31, 2014, 07:47:06 PM »
  Hmm The sump cover if off?  take a close look inside with a bright light.
Offline lucky phil
« Reply #17 on: May 31, 2014, 09:36:39 PM »
Or it's an unrelated foreign object off the garage floor or caught in a rag you used when you had the engine apart for the cam and lifter replacement?
Seems the more likely
Ciao
Offline dan_s
« Reply #18 on: June 01, 2014, 01:24:54 AM »
I haven't gotten to looking inside, tired of fixing things (although small things). I  just want to ride now, fortunately I have another bike.
I'll post to write what I found.
Offline jacksonracingcomau
« Reply #19 on: June 01, 2014, 01:43:23 AM »
I reckon that is nearly brilliant guess, here's mine
The strap under the cap on the oil bottle, like what wraps around wine corks .
A/ there're still metal caps on oil containers in Israel
2/ Bottle of wine was opened during the oil fill procedure
Either way it didn't come from the engine, it got put there, good use of magnet
Offline dan_s
« Reply #20 on: June 01, 2014, 09:49:21 AM »
Israel is not THAT exotic
Offline mtiberio
    • TiberioRacing
« Reply #21 on: June 01, 2014, 04:39:49 PM »
From breather box. Rusts and flakes
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline dguzzi
« Reply #22 on: June 01, 2014, 06:03:41 PM »
Possibly an outer seal piece? Did you find any seals that were toasted? Odd that it would be in the sump unless as suggested a manufacturing 'error'.
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Offline dan_s
« Reply #23 on: August 09, 2014, 11:01:21 AM »
Update. The distributor and cam gear were fine. Took off sump to find a couple of dozens of black steel flakes lying on the bottom, about 1mm each. Not a pretty sight. I couldn't leave it at that. Further on, the friction areas on the rockers seemed to have almost lost their hardened layer.
I gave the rockers for filling with metal powder and regrinding and one valve for grinding the tip of the stem. Then polished the friction areas with 1500 grade sand paper.
The tappets, just ~1500 km's old, had unacceptable pitting on the cam contact area. That would explain the tiny steel flakes but not the big ugly one. I bought the tappets from Stein_Dinse on 4.2013. I sent them the photos and spoke with customer service there, their person told me he knew about issues with that certain make of tappets and sent me four replacement items which, he claimed, should be fine. The replacement tappets were sent free of charge.
I didn't pull the cam out but looking from the tappet channels, the lobes look unharmed.
I didn't open the timing cover since i can't think of something there that could produce such flakes (the timing chain?)
So now everything is back in place. I even bothered to smear molykote G-N assembly paste on the tappets surfaces.
Spun the engine with the starter, with no fuel and the spark plugs out.
A question: Before I start the motor, does anyone have any advice on camshaft/tappets running in?
Offline normzone
« Reply #24 on: August 09, 2014, 11:57:50 AM »
Fascinating. I can't help with your question, but I want to thank you for the detailed images and post. You might have noticed that I'm pursuing an unexplained sound in my engine, and your work here gives me confidence in the solveability of the matter.
Offline dan_s
« Reply #25 on: August 09, 2014, 12:17:34 PM »
Glad it helps.
« Reply #26 on: August 09, 2014, 12:24:46 PM »
The general advice usually given to break in new automotive cam/lifters is coat with assembly lube, start, and immediately get to around 3,000 rpm.  Then vary the speed between 1,500 and 3,000 for 20 minutes or so.  Most important is to avoid slow running, including extended cranking during starting.
Offline Tobit
« Reply #27 on: August 09, 2014, 12:46:26 PM »
Fwiw, when I pulled the lifters out of my LeMans IV in '87 (was having other work done) they were worse off than yours.  Probably had around 10,000 miles on them.  The camshaft looked fine.
Tobit
Roman, '86 LM IV
Online Wayne Orwig
« Reply #28 on: August 09, 2014, 12:56:56 PM »
Most cam makers recommend initial run in with a high level of ZDDP in the oil.
No idea if it really helps, but it can't hurt to add some.
Still curious where that big bit came from.
Uzidzit
« Reply #29 on: August 09, 2014, 02:52:21 PM »
it is a chip from machining, off something,  probably been hiding out since new.  I would not loose much sleep over it,  get a bottle of crane cams assy lube to dose the followers on the start up the stuff for non rollers, it works well.  cranes are soft cams and need careful break in, high zinc oils will not hurt anything in your bike it does not have o2 sensors, or a cat,  and those are what zinc kills quickly
