Author Topic: Seal Mate tool worked - No more leaking fork seal  (Read 8618 times)
Offline willowstreetguzziguy
« on: October 18, 2014, 09:02:22 PM »
Someone here suggested trying the Seal Mate tool to fix a leaking fork seal on my 1200 Sport before replacing the fork seal. For ~$5 it was worth a try.  So I purchased one and followed the directions, cleaned the fork seal several times with the tool and pumped the forks afterward to re-seat.
Today I went on a beautiful 165 mile ride, enough to re-seat the fork seal.  After the ride, I checked the fork tube for oil. NO OIL residue!  The Seal Mate worked and saved me a lot of $$$. Thanks for suggesting Seal Mate.
2008 Guzzi 1200 Sport
Offline Rich A
Re: Seal Mate tool worked - No more leaking fork seal
« Reply #1 on: October 18, 2014, 09:24:20 PM »
Never heard of these. I figure it's worth a few bucks to try. Thanks for the heads up.
Rich A
Offline drw916
« Reply #2 on: October 19, 2014, 12:20:07 AM »
Worked on my Stelvio.  A must have for every tool box.
2022 Triumph Tiger Sport 660
1969 Honda 90 (CM91)
Online PeteS
« Reply #3 on: October 19, 2014, 07:26:01 AM »
I cut one out from a plastic milk bottle. First time it worked. Months later it didn't so I had to change the seal. Worthwhile tool in any case.
« Reply #4 on: October 19, 2014, 03:01:46 PM »
I used a feeler gauge to do the same to my Honda.  Worked.
jwh20
« Reply #5 on: October 19, 2014, 03:07:51 PM »
I'll just second that also.  Yes, you can make your own but Seal-Mates come in designer colors and I couldn't resist.  Took a couple of tries on my Kawasaki ZRX but it stopped the leak.  Worth trying before replacing the seals.
andrewdonald1
« Reply #6 on: October 20, 2014, 01:24:41 PM »
Good to know.  My seal doctor arrived this weekend, but didn't have the time to try it.
I'll try it next weekend.
thanks for the feedback!!
Offline quota
« Reply #7 on: October 20, 2014, 10:00:24 PM »
Seal Mate has worked well for me and saved me having to change a seal.
Offline Rich A
« Reply #8 on: March 24, 2015, 10:09:07 AM »
Bump.
I used a Sealmate on seal that was leaking on my Jackal. Seems to have worked, tho it did get bent in the process. Still, money well spent.
Rich A
Offline Tony/CT
« Reply #9 on: March 24, 2015, 01:49:47 PM »
Two just arrived in the mail today!! :)
Offline nowgrn4
  • It's not how fast you go, it's how little you slow
« Reply #10 on: March 24, 2015, 03:34:33 PM »
Very old school. An old 35mm slide negative cut at an angle right through the middle of a sprocket hole works great. The little sprocket hole snags the debris. Good idea to change old dirty oil afterwards.
00' Quota
00' Miata
 "To add speed,add lightness"
                       Colin Chapman
Online Chuck in Indiana
« Reply #11 on: March 24, 2015, 04:44:19 PM »
Oh.. I like that one..  ;-T
Offline papatom
« Reply #12 on: March 24, 2015, 08:27:22 PM »
the corner of a paper business card will also work to dislodge any dirt on the seal lip.
jomarti3
« Reply #13 on: March 24, 2015, 09:14:00 PM »
Thanks to a good friend's suggestion I tried the 35mm film trick on a Buell Ulysses and it worked there to clean out some debris, saved a time consuming disassembly and repair.  My guess is there have been lots of seals replaced over the years that just had dirt or bug remnants creating a path for oil to escape.
LaGrasta
« Reply #14 on: March 26, 2015, 03:22:22 PM »
great review, so glad I read about this. I don't have the need at this time, but I'm sure one day …and I'll be ready!
