Author Topic: Those crappy Grisos!  (Read 74530 times)
« on: November 19, 2014, 12:23:56 AM »
This one, an early A5, had the full complement of factory screw ups. What a POS!
What a terrible thing these new bikes are, despite the fact that it took me really only about 1/2 an hour more to get to this point on a Griso than it would on a Mk V LeMans. Can't see what anyone sees in them........
Offline pete mcgee
Re: Those crappy Grisos!
« Reply #1 on: November 19, 2014, 12:57:15 AM »
And here I thought you were the converted one.
So what did enzo do on the friday arvo special that has raised your ire?
crc
« Reply #2 on: November 19, 2014, 01:00:09 AM »
I thought you said late model bikes were 100% reliable?
« Reply #3 on: November 19, 2014, 01:11:54 AM »
No problem. Just took six years for the problems to manifest themselves. Never happened thirty years ago, ever.....
Obviously we need a sarcasm emoticon.  ::)
Offline Waterbottle
« Reply #4 on: November 19, 2014, 02:19:06 AM »
Well I just love Em  :-*
I would be sleeping with mine,  :drool, but it's Metric and I'm Imperial :'(
2015 Griso SE Rosso
2012 Stelvio 8V
2009 Griso R  Track only
76 GT 750 Suzuki
Offline jacksonracingcomau
« Reply #5 on: November 19, 2014, 02:53:17 AM »
This one of just serviced cam failures ? mileage ?
If it's getting correct length bolts for bearing flange at same time, that took awhile to show, shame, would've been warranty claim if it'd been used new.
Did it eat it's carc bearings too ?
What other factory screw ups are there, apart from mapping which we know you're now happy with aftermarket fix ?
POS indeed, predictable when Piaggio took control, everything de tomasso was accused of now taking place, actually his years were the glory ones.
V7 series excluded of course, someone bright was in charge of that project, haven't heard of problem there.
SB's may be Guzzi's forever bike, Chuck's drone engine (or a 4V) with 6-7" travel would be a very wise move IMHO, priced to sell
« Reply #6 on: November 19, 2014, 04:14:13 AM »
Yes Martin, whatever you say.
lawries
« Reply #7 on: November 19, 2014, 05:45:51 AM »
LOL, go for it guys  :pop
Offline lucian
« Reply #8 on: November 19, 2014, 11:14:32 AM »
Oh no , It's a white 09 just like mine. Hope I can shake that visual soon. Like a fricken horror movie. Thanks Pete.
« Reply #9 on: November 19, 2014, 11:18:21 AM »
And let it be noted Pete does all his work on a HF lift!   Mine should last forever!
« Reply #10 on: November 19, 2014, 11:31:44 AM »
Actually that is my secondary and far the least favourite bench. I bought it as an experiment and it's really pretty horrible. My primary bench is currently full of a dead Norge with no rear shock though so I can't move it! Bloody Australia Post lost the shock on its way back to Albury for a warranty rebuild so I've been condemned to working on this bit of shit for the time being. It's OK but it's narrow and flimsy. I don't entirely trust it. Any port in a storm though.....
Offline rboe
« Reply #11 on: November 19, 2014, 03:35:37 PM »
Well, it's only POS Griso on the HF lift, it's not like you have a good bike at risk.....  ::)
<sarcasism off>
Phoenix, AZ
2008 Honda XR650L
2012 Griso SE
2013 Honda CB1100
Offline pebra
« Reply #12 on: November 19, 2014, 03:50:06 PM »
Hmmm
I have a white 09.
Climate here is definitely cold(ish) and wet(ish)
Maybe I should give swapping to roller tappets another thought?
2009 Griso 8V "Weißgerät"
Morizzi
« Reply #13 on: November 19, 2014, 06:35:53 PM »
Can't you make a 'mock' shock using a piece of steel strap/bar/quad/angle with a whole at each end and a couple of bolts?  ???
I know it will be a rigid frame but so is a wheelbarrow.  ;-T
Rod
« Reply #14 on: November 19, 2014, 09:18:18 PM »
I could. I can't be arsed though! ;D
« Reply #15 on: November 19, 2014, 10:23:06 PM »
Hmmm
I have a white 09.
As long as you have a full service history it shouldn't be a problem. If they go tits you *Should* get a kit from the factory BUT it is dependent on a final decision from there.
I bought my own kit, it wasn't cheap, so far I haven't felt the need to install it, my bike is running so superbly at the moment I can't see any reason to pull it to bits.
If your bike doesn't have a FSH it might be worth considering replacing them on spec simply because of the damage that may be caused by the disintegrating tappets.
« Reply #16 on: November 20, 2014, 12:18:40 AM »
Well this terrible thing is nearly back together,
I got waylaid by a bloke who was passing through who had had his bike serviced at another place and they'd tried to lower the idle speed with the throttle stop screw so it was running like a POS. Luckily they hadn't re-set the TPS, (Apparently they plugged in the box that goes 'Ping' and gawped at it for a few minutes and then unplugged it and said everything was rosy and didn't adjust anything, thank God!) so I was able to un-screw it up easily. He was charged $700 dollars for the privilege of having these monkeys damage his bike! No worries, all good but it ate into the rear main replacement time. I charged him a pineapple and then bought him a beer. I think he was happy enough with that.  ;D
The White Lightning should be all done and dusted early tomorrow. Nice bike, an early A5 like mine but nowhere near as noisy, mind you it's only done 30,000. Mines up at 80! :D
Offline lucky phil
« Reply #17 on: November 20, 2014, 05:00:46 AM »
Rookie mistake Pete:)
Ciao
« Reply #18 on: November 20, 2014, 05:13:14 AM »
Flaking chrome bores anyone?
« Last Edit: November 20, 2014, 05:13:33 AM by jas67 »
Offline MotoG5
« Reply #19 on: November 20, 2014, 05:59:30 AM »
Grooved transmission input drive gear splines (clutch lockup).
Misaligned transmission to engine bell housings.
Rear drive failures.
U-Joint and carrier bearing failures.
Timing chain tensioner guide blocks coming apart.
Torque converter center hub cracking and failure.
Porous engine block casting leaks.
Fading paint, general flaking chrome trim and crappy short side stands.
Aha yes, the glory days.  ;)
Nebraska MGNOC State Rep
« Reply #20 on: November 20, 2014, 11:36:10 AM »
Crownwheel bolts jumping ship.
Sebac fork dampers that blew as they rolled the bike off the end of the production line.
Too short speedo cables that only lasted a few weeks.
Self-immolating switchgear!
Crappily shimmed selector drums.
Snapping gear change return springs.
And more recently;
Gearboxes that filled up with water flung off the rear wheel.
Oil starvation!
Timing chest covers that crack if the bike falls off its stand.
Cracking gearbox mounts.
Un-tightenable exhaust balance pipes.
The list is endless! Compared to some of the older bikes the 8V is a paragon of Swiss-watch like reliability! ;D
« Reply #21 on: November 21, 2014, 02:40:41 AM »
Wow
I bought a good one, obviously
Must've dodged a bullet, 37 years ago, took me round the world, still my everyday transport.
Fork dampers and timing chain were stupid, switchgear & wiring a bit howsyerfather, rest awesome. Fixed without thought
To some, Carc disintegrating, fuel mapping needing expertise, oil flying out behind clutch and cam doing what it does is better, choice, a good thing.
Not going into why you need a van if it rains, still can't quite get that bit, never will, only an idiot would ride a Griso in rain apparently, are they cleverer with sun shining ?
« Reply #22 on: November 21, 2014, 02:56:45 AM »
Yup. Not everyone needs to be a needy masochist. Get well soon.
beetle
« Reply #23 on: November 21, 2014, 03:17:13 AM »
There's no curing a troll Pete. It's best just to ignore them.
Online steffen
« Reply #24 on: November 21, 2014, 03:19:36 AM »
 ;-T
« Reply #25 on: November 21, 2014, 03:21:46 AM »
Yeah, but I don't use 'Ignore' buttons and I've always been drawn like a moth to the flame by know it all's.
It all reminds me a bit of the opening scenes of Jurasic Park with the mosquitoes trapped in Amber.
 :D
« Reply #26 on: November 21, 2014, 03:37:14 AM »
Not often I take offence but I have, many motorcycling friends of mine are actually female , not macho or masochist, motorcycling is a form of transport, enjoyable rain or shine
Offline Tazturtle
« Reply #27 on: November 21, 2014, 03:45:03 AM »
Masochist = enjoying pain, often self inflicted (as in S&M and old motorbikes!)
2022 V85TT Evocative
2012 1200 Sport 8V Corsa SE
2011 V7 Racer #749
beetle
« Reply #28 on: November 21, 2014, 04:25:49 AM »
Yeah, but you know what they say about arguing with idiots. :D
« Reply #29 on: November 21, 2014, 04:27:04 AM »
Ok, I think we've learnt something here.
Sorry Martin. Look after yourself.
