Author Topic: 1967 V700 barn find  (Read 126487 times)
Offline C5Performance
    • C5 Performance Inc
1967 V700 barn find
« on: November 26, 2014, 08:38:36 AM »
I will be bringing this crusty 1967 V700 home in the next week or two. A friend of mine owned it for many years, and we've worked out a deal for me to purchase. Most of you know the '67 was the first year of the V engine.
The sheet metal (except fuel tank) had been previously stripped for a repaint. I'm sure the bike will need plenty of elbow grease to get it road worthy.
My goal is to leave the fuel tank alone, and try to clean it up without taking away too much patina.
I thought some of you might enjoy seeing a "first year V-engine" be saved from a slow death via corrosion in a dirt floor shed.
The bike will be on display at our C5 Ignition booth at Midwest rallies, and used to develop a new ignition for older MG models, but also I'll be riding it as much as I can. The bike has 25,000 miles on it and I fully expect to add plenty more.
This is my FIRST Moto Guzzi and I'm very excited!!!
Offline Tony/CT
Re: 1967 V700 barn find
« Reply #1 on: November 26, 2014, 08:48:17 AM »
Excellent! It's always nice to see the old loops put back on the road! ;-T
« Reply #2 on: November 26, 2014, 08:52:44 AM »
You've got your work cut out for you, but it will be worth it IMO. The only Loop Guzzi I haven't owned, though my '69 Ambo is very close.
If it still has the original chrome bores, I wouldn't even attempt to crank it over. Gilardoni hasn't made V700 kits for years, so replating or sleeves might be the best way to go. Ambassador cylinders can be modified to work as well.
Offline leafman60
« Reply #3 on: November 26, 2014, 09:54:53 AM »
I notice that it has the square-slide carbs instead of the SS1s that were fitted to the '67 models.  This may be a '68 or else someone swapped them out.
I suggest that you go to Greg Bender's site and research possible ways to identify production dates.  That is difficult to do with these early V700s.
http://www.thisoldtractor.com/moto_guzzi.html
Those are fine bikes. I had one until recently and I liked its handling and 4-speed transmission performance better than the later Loops I've owned.
You got some work ahead of you.
Offline steven c
« Reply #4 on: November 26, 2014, 09:59:32 AM »
 Nice project. A little wash and shine, and a healthy credit card………. ;-T
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline Groover
    • Scooteropolis
« Reply #5 on: November 26, 2014, 10:20:44 AM »
Congrats, and looking forward to the next stage!
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline Don G
« Reply #6 on: November 26, 2014, 10:57:46 AM »
Pull the engine out of that sucker and clean the sludge trap! It will be full of mung, it will need a few other things as well while your there most likely.  DonG
Offline kevdog3019
« Reply #7 on: November 26, 2014, 11:03:11 AM »
I thought '66 was the first year of the "V"?  Lots of work ahead of you, but good of you to care for it.
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
Offline smdl
« Reply #8 on: November 26, 2014, 11:16:18 AM »
Looks like a nice project!  Please keep us posted on progress.
Cheers,
Shaun
'61 Galletto
'74 Eldorado Civilian
'22 V85TT Guardia D'Onore
'24 Stelvio
Offline EvanM
« Reply #9 on: November 26, 2014, 11:23:41 AM »
Glad to see you finally got a Guzzi Paul!
Good luck on it!
2007 Breva 1100
Offline Yeahoo Whoyah
« Reply #10 on: November 26, 2014, 11:48:31 AM »
Nice find, treasure recovery is exciting.  Do you have much riding experience with left foot brakes - right foot shift?  I've been away from that set-up for such a long time the idea of re-adjusting scares me.
Greg Tillitson
El Dorado Hills Calif.
« Reply #11 on: November 26, 2014, 11:54:51 AM »
Our V700 was involved in the infamous crash and burn from the fuel line crossover failing, but it was Dorcia's favorite Guzzi. Soft ride, comfortable, gave you the feeling it would just continue to run forever.  ;-T
Offline Groover
    • Scooteropolis
« Reply #12 on: November 26, 2014, 12:01:15 PM »
Is this how these are? I thought they were 4 speed, just opposite (up vs down for 1st gear)
1980 Vespa SI Moped
« Reply #13 on: November 26, 2014, 12:09:54 PM »
V700s and early Ambassadors were left foot brake, right foot shift, with a "backwards" pattern. I don't find it too hard to adjust when hopping from a "normal" bike onto the Ambo. It's like when my butt hits the Ambo seat, my brain clicks into a different mode. It helps that I've put 70k miles on the Ambo with it that way. I'll be building my sidecar tug Ambo the same way.
Offline Rusty goose
« Reply #14 on: November 26, 2014, 12:42:00 PM »
Great looking project! We seem to be in the same boat, albeit, my boat might sitting higher in the water!  I have mine torn down to the frame, the bores are, well,what was expected. The final drive is toast and the tank was lined, poorly and will need to be redone. Bit my chromeis aa tad better, maybe..
Rusty
" A situation is never so bad that it can't get just a little bit worse."
Offline v7john
    • The Racing Rhino
« Reply #15 on: November 26, 2014, 01:44:51 PM »
Looks like hours of fun.
I wouldn't worry too much about the sludge trap. At 26K miles it should be ok and that's one thing that won't have got worse for standing. I would look at the state of the bores though. It's being left standing that kills these. If it had been used everyday, likely it would be fine. I've got the same to come having recently bought a V7 myself. It's come from Italy but has had less than 200Km use in the last 2 years.
1954 BSA M33 500cc.
Offline V7BRIAN
« Reply #16 on: November 26, 2014, 02:27:31 PM »
 ;-T   nice project.  I just got a 67 two months ago.  I sent you an email.  BRian in NJ
Offline jacksonracingcomau
« Reply #17 on: November 26, 2014, 07:36:33 PM »
I've bought one recently too but kind of opposite, mine missing loads but $5K miles looks to be genuine
rear drive gears & splines absolutely like new, box apart for coating and seals, then going on my Tonti for now
But the pinion carrier is different from any I've seen, has no oil holes for feed and return or matching cut outs in casting.
I've fitted later pinion carrier (big bearings-- spaced for Tonti and O ring seals) and modded box  but I'm interested in where yours failed, did pinion gear / bearings fail ?
I'll get into 4 speed box soon, I'm betting that's perfect inside too, I'll never know why it got dismantled but bores off prob a clue, heads completely virgin.
OP-- Chuck with Aero engine needs magic sparks box to run with his trigger, look at Aero thread for pics, maybe you can help ?
« Reply #18 on: November 27, 2014, 12:11:27 AM »
Good luck on it!
Evan will you be at the National rally again this year? I'd love to show you the bike in person.
« Reply #19 on: November 27, 2014, 12:13:24 AM »
No I honestly have ridden bikes like that but never owned one. Promise not to laugh if you see me practicing on my lawn  :BEER:
Offline EvanM
« Reply #20 on: November 27, 2014, 01:46:12 AM »
Unfortunately not, as I will still be in school then. I may have all of August off this year though, so I will be doing a large trip then. If I'm in the area, I'll give you a call, assuming the number you gave me at the rally is still accurate?
2007 Breva 1100
« Reply #21 on: November 27, 2014, 10:24:53 AM »
Yes, 920-810-0946 or 920-403-0555 (both end up at my cell phone).
I would like to offer you a free place to stay, with awesome food and drink.
Whatever your journey, ride safe and we'll meet again soon.
Offline Don G
« Reply #22 on: November 27, 2014, 10:56:55 AM »
WELL SOME PEOPLE CAN WORRY OR NOT ABOUT THE SLUDGE TRAP, I RECENTLY TOOK A PLUG OUT OF ONE THAT HAD 17,000 MILES ON THE CLOCK, IT WAS MORE THAN 3/4 FULL, DO AS YOU LIKE. DonG ;-T
« Reply #23 on: November 27, 2014, 11:10:10 AM »
I will be cleaning the sludge trap.
My friend Stephen from Restoration Werks, and Curtis Harper both contacted me with suggestions. Both agreed it would be my best course of action to pull the engine at least partially apart before attempting a test run. Corrosion from sitting in a dirt floor shed was the main concern.
Next week I'll have the bike in my shop, and I can soak it all down. I am not doing a complete restoration, but certainly don't want to harm the bike in any way.
Feed back from this forum is greatly appreciated!!
Happy Thanksgiving everyone.
« Reply #24 on: November 27, 2014, 11:21:55 AM »
When I took the "Monte Carlo" Guzzi apart, I had to drill out the sludge trap.  ;D Of course, it had been running on failed cylinders, and had a heater hose hooked to the breather so the blow by could go aft beyond the license plate.  ::)  ;D
Offline EvanM
« Reply #25 on: November 27, 2014, 11:31:02 AM »
Thanks for the generous offer!
Hopefully I'll be able to take you up on it!
2007 Breva 1100
« Reply #26 on: November 27, 2014, 02:15:13 PM »
You should consider submitting your bike's VIN to the loop list here: http://www.thisoldtractor.com/moto_guzzi_loopframe_loop_list.php
Greg Tillitson
« Reply #27 on: November 27, 2014, 02:44:12 PM »
I will once it comes home (next week). Gotta keep track of these, right?
Offline Hahnda
    • Scrambler Cycle
« Reply #28 on: November 27, 2014, 10:25:51 PM »
If you have plans to clean out the sludge trap you will pretty much be doing a complete engine teardown to get at it.
I agree. If its been sitting on a dirt floor in Wisconsin for ?? years at a very minimum you need to pull those heads. I would be willing to bet you have some flaking chrome going on.
So get to work and have it done in time for the WI rally.
1949 GTV - 1948 Airone
www.scramblercycle. com
« Reply #29 on: November 27, 2014, 11:08:13 PM »
Is that an invitation to help? LOL
I'll have it ready and you can take for a spin if you like.
