Author Topic: guzzidiag reader not connecting  (Read 18563 times)
vij
« on: December 13, 2014, 03:01:02 AM »
I have a small issue. it is not a guzzi, sorry it is a ducati. Guzzidiag connects good to the bike but when I try the 5x reader it does not connect. To make it more complicated it is a 59m not a 5am ECU but afaik 5x reader should work on 59m too. Any one having and experience of this.
As additional information ducatidiag works and I can read the map with that one so my caable and ftdi should be good I think. It also passes the cable test. Any suggestions.
Jocke..............
Offline pauldaytona
    • Paul's fast Guzzi Page
Re: guzzidiag reader not connecting
« Reply #1 on: December 13, 2014, 04:28:41 AM »
best to contact:  guzzidiag at gmail .com
Paul
Daytona 1225, Stelvio 1151
vij
« Reply #2 on: December 13, 2014, 12:03:15 PM »
Will do. Thanks Paul
AndySaki
« Reply #3 on: January 16, 2015, 11:52:03 AM »
Did you resolve your Reader connection problems?
Like you, I can connect to my IAW5SM based MV Brutale 910 but the reader fails and the log captured shows that comms were established, baud rates successfully re-negotiated and then a fail with "-2" as the error report repeats 4 or 5 times and then aborts. IAWDiag (and GuzziDiag) connect and monitor flawlessly, and also TPS and CO adjustments work perfectly. Seems curious that the reader can't...
AndySaki
« Reply #4 on: January 17, 2015, 12:01:26 PM »
Log file from a connection attempt.
    1540ms Fast init
    2046ms Init Ok
    2371ms Drawing: 8019BRU52
    2372ms Hardware: IAW5SMHW400
    2372ms Omologation:
    2372ms Software:
    2372ms Tester: WLoad1040
    2372ms Date: 2007.03.23
    2372ms IAW5SM detected
    2572ms Diagnostic started
    2796ms Diagnostic 2 started
    2927ms Baudrate switched
    3534ms 57 20 57 21
    3535ms 35 68 69 27
    3784ms Login Ok
    4038ms RequestUpload: -2
    4283ms RequestUpload: -2
    4527ms RequestUpload: -2
    4773ms RequestUpload: -2
    5018ms RequestUpload: -2
There's been quite a bit of dialog about connection troubles here, or would I be better contacting GuzziDiag directly?
vij
« Reply #5 on: January 17, 2015, 12:58:11 PM »
I contacted Bernd with regards to this. I also sent him an old , partly broken 59m ECU so he could play with. When I tried the readout from this ECU it did not work. When Bernd tried it he could not get it to fail.
He had some ideas and sent me an test version of the reader with some revised parameters to test for him and it worked. I guess that he will implement the updates in the next release of the reader. I don't know if or when the new version is coming but I would guess that he wants to try it him self to make sure that the updates did not add any new problems. We will just have to wait, see and hope for the best. Bernd is very clever and is working very hard so I am sure that it will work soon.
Jocke...........
« Last Edit: January 18, 2015, 06:16:33 AM by vij »
Offline pauldaytona
« Reply #6 on: January 17, 2015, 04:06:56 PM »
were you the one I made the xdf for?
I do have some 59m xdf.
For AndySaki, contact guzzidiag direct about reading the 5sm.
Paul
AndySaki
« Reply #7 on: January 17, 2015, 05:22:08 PM »
PaulDaytona - struggling to find any contact details for GuzziDiag. Any pointers? Sorry for so many questions!
Offline pauldaytona
« Reply #8 on: January 18, 2015, 03:15:26 AM »
six posts up from me:
Paul
vij
« Reply #9 on: January 18, 2015, 06:21:31 AM »
No it was not me but if you have a 59m xdf I would be very happy to try if you have some. The one I have has very limited functionality. If you can post it my address is j_virdung at hotmail .com
Jocke...........
Offline pauldaytona
« Reply #10 on: January 18, 2015, 06:44:29 AM »
Jocke...........
what is your map id? is st4s?
Paul
vij
« Reply #11 on: January 23, 2015, 02:14:40 AM »
Sorry for late reply. Been away skiing for a few days. Will send you the details tomorrow I hope. It is a 2002 monster S4
Jocke........
