Author Topic: Slow leak...driving me nuts.  (Read 37448 times)
Offline ken farr
« on: January 01, 2015, 03:00:08 PM »
Hello all:
  I have had my current rear tire for @ 3,000 mi. and have had a slow leak ever since.  I have changed the valve core, valve stem and using water I cannot find the leak.
  Nothing in the tread area, no sign of a leak along the circumference, but it is leaking, now @ 5+ lbs. a day.
  I am thinking of trying a new tire, however I am open to suggestions......
 Tubless tire-wheel on 06 B1100.
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Re: Slow leak...driving me nuts.
« Reply #1 on: January 01, 2015, 03:09:50 PM »
Ken , have you tried checking the rim with the water test ?
Offline ken farr
« Reply #2 on: January 01, 2015, 03:47:03 PM »
Yep.
Can't see any bubbles......and I wait a while.
( maybe not long enough...... :BEER:)
I will probably take the tire off on Sat., inspect the rim very carefully, and if I can't find anything, I'll try a new tire.
I was hoping against all common sense that someone had a secret silver bullet fix.
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Offline Vagrant
« Reply #3 on: January 01, 2015, 04:29:27 PM »
I suspect you nicked the bead when installing. fill it with slime carry a compressor and ride it.
« Reply #4 on: January 01, 2015, 05:29:53 PM »
Offline pressureangle
« Reply #5 on: January 01, 2015, 06:01:39 PM »
use dishsoap and water in a spray bottle. Fill the tire to max recommended pressure and spray everything. If you don't find it that way, dismount the rim and remove the wheel bearings, check in the bearing bore. I saw a Suzuki wheel once that had a crack in it between a spoke and the hub that leaked out through the bearings. It had been crashed a few times, so it seems unlikely yours would be that way but soap don't lie.
Offline amamet
« Reply #6 on: January 01, 2015, 06:26:18 PM »
Reminds me of an old slow leak I had years ago.  Had a hyperdermic needle broken off in the tire. Talk about slow leak. Ask me how I found it...better yet ask the mechanic who found it as he ran his hand along the inside of the tire.  Ah, old New York city
Online lucian
« Reply #7 on: January 01, 2015, 06:56:15 PM »
Nothing  a tube wont fix. Is it a tubeless spoke rim?
Online Wayne Orwig
« Reply #8 on: January 01, 2015, 07:25:41 PM »
Are you using winter air?
Offline Robert
« Reply #9 on: January 01, 2015, 07:31:47 PM »
I had a Michelin car tire (set of 4 actually) that leaked at the bead due to a not smooth mold seam (radial orientation).
Tire shop painted a little glue on that area when seating.  Fixed it.
Then, when I would have a flat fixed, I would say they needed to put some glue on the bead.  Nope, you're wrong, etc.
Till it bubbled soap at the rim and they would unmount and add glue.
Got Toyos next.
Offline ken farr
« Reply #10 on: January 01, 2015, 07:37:24 PM »
 :bow
The Silver Bullet fix I was hoping for.
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Offline Moto Fugazzi
    • Griso
« Reply #11 on: January 01, 2015, 08:09:52 PM »
I just used NAPA bead sealer on my front wheel that leaked. Thread here: http://wildguzzi.com/forum/index.php?topic=73466.0
Monkey Grip also makes a can of it as well for under $10.
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
Offline tris
« Reply #12 on: January 02, 2015, 02:27:30 AM »
Worst case - is the rim cracked?
A mate of mine had a car tyre that kept going flat and eventually found by X-ray a crack propagating between the wheel nut holes
1993 TW125 "POS" - Resting
Doppelgaenger
« Reply #13 on: January 02, 2015, 03:45:32 AM »
« Last Edit: January 02, 2015, 03:46:25 AM by Doppelgaenger »
« Reply #14 on: January 02, 2015, 07:38:28 AM »
Riding on the Lower East Side?
Offline normzone
« Reply #15 on: January 02, 2015, 12:14:19 PM »
This pirate walks into a bar with a big ship's wheel down his pants.
The bartender says "Excuse me, but do you know you have a ship's wheel down the front of your pants?"
And the pirate says...
Offline ken farr
« Reply #16 on: January 04, 2015, 07:01:10 PM »
...found the leak.
Dunk tank didn't show anything.
Spray bottle/soapy water showed 3 spots on one side of the bead wasn't sealed.
Bought some bead sealer from the local mom-pop auto parts store...and all is good.
Life is good again, birds are chirping and flowers are blooming.
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Offline normzone
« Reply #17 on: January 04, 2015, 07:26:10 PM »
"Aarrr...it's driving me nuts."
Offline Jim Rich
« Reply #18 on: January 04, 2015, 09:16:26 PM »
Are you sure you weren't nuts before all this tire stuff got started?
Offline EvanM
« Reply #19 on: January 04, 2015, 09:24:02 PM »
Change out the valves. Mine leaked 15lbs/week, and after changing to a valve that has 2 o-rings, instead of the single one the stockers use, I'm only losing about 5lbs/month.
2007 Breva 1100
