Author Topic: Givi Maxia top box, backrest.  (Read 36590 times)
Offline injundave
« on: January 03, 2015, 09:25:43 PM »
I recently bought a Givi E50 Maxia top box. It was second-hand when I bought it. It came fitted with an accessory back rest which is slightly damaged. Does anyone have one surplus to requirements or know of something I may be able to repair it with? It seems to be made of high density rubber foam.
« Last Edit: January 03, 2015, 10:44:42 PM by injundave »
1975 850 T3
2019 V85TT
Re: Givi Maxia top box, backrest.
« Reply #1 on: January 03, 2015, 10:24:22 PM »
Can't you just glue some vinyl on it nice and tight?
Offline Scott DeRoss
« Reply #2 on: January 03, 2015, 10:58:56 PM »
Couldn't you go to the Givi USA web site or ebay and get a replacement?
2007 Vintage (Vinnie)
2017 V9 Roamer (Sunny)
1-76 & 3-78 Robins
1975 Honda CT90
1979 Beneli G2 moped
75 850t wifes (Plum Crazy)
79 Honda Ct70 (restored)
MGNOC L-661
Never take life so serious you won't get out of it alive
Offline injundave
« Reply #3 on: January 04, 2015, 01:45:58 AM »
Apparently the one I need is an E83N, which has been discontinued. I'm not sure about the stretched vinyl idea but there is an auto-upholsterer nearby and I will consult him, but I would prefer the genuine article if I can find one.
1975 850 T3
2019 V85TT
Offline Waltr
    • Europa Macchina
« Reply #4 on: January 04, 2015, 08:12:35 AM »
I assume it has a type of backing plate where it screws into the box. I would bring it to an upholstery shop and have them cut away the tore up foam, replace it with new foam and fashion a vinyl cover to match your saddle.  This is what is usually done by custom saddle people like Russell and Mayer.
www.motoguzzipa.com
2012 Norge
« Reply #5 on: January 04, 2015, 08:23:56 AM »
When you see the price of the simple block of foam, you will take it to the upholsterer.
Offline Spuddy
« Reply #6 on: January 04, 2015, 05:42:45 PM »
A couple of coats or GE Silicone seal should make a serviceable repair. And if you're good it can look okay.
Spuddy
'13 Stelvio NTX
'07 California Vintage
'01 W650
