Author Topic: Centre Stand Question  (Read 24636 times)
Offline tris
« on: January 07, 2015, 01:25:05 AM »
Morning All
As part of my winter "fettling" programme I pulled the centre stand of the bike to give it a coat of paint and a bit of lube!
2 questions
1) When re-installing it should the bolts be pulled up tight so that the stand rotates about the bush or left only just tight so that the bushes still can rotate? I only ask as I had one of each  ;)
2) Should there be one or 2 wavy washers?
Cheers
Tris
« Last Edit: January 07, 2015, 01:27:55 AM by tris »
1993 TW125 "POS" - Resting
Offline jacksonracingcomau
Re: Centre Stand Question
« Reply #1 on: January 07, 2015, 02:09:21 AM »
Morning All
2 questions
Cheers
Tris
1/Tight, so stand rotates around bushes , VERY IMPORTANT as loose flogs out plates that make stop for stand
2/ 1 washer each side, just stops stand moving side to side
Offline tris
« Reply #2 on: January 07, 2015, 02:20:26 AM »
Brilliant and thanks
Just need to track down a M18 DIN 137B wavy washer then!!!
So far I can only find boxes of 200 over here!!
« Reply #3 on: January 07, 2015, 02:51:48 AM »
M10 or 3/8" spring washer should work, prob ok to just have one side too, not a biggie in scheme of things, but Gutsibits will have wavy washers in singles
Offline tris
« Reply #4 on: January 07, 2015, 03:13:56 AM »
I thought Gutsibits would have them too - but they don't!
I agree though - not a huge issue so if I find one I'll fit it and if I don't I wont  ;)
Offline Late to the party
  • 1987 1000 SP2
« Reply #5 on: January 07, 2015, 03:58:00 PM »
Had the same question a while back. Tighten those bolts up and the center stand wouldn't move. The cause? Aluminum bushings were frozen tight in the center stand. Solution? Drill them out (a little bit) and put slightly longer bushings within the original bushings. Greased it up and put it back together. The center stand is now tighter (no side-to-side motion) and much easier to use.
Lateness.
Offline tris
« Reply #6 on: January 08, 2015, 01:23:57 AM »
Lateness.
The bushes on the stand on mine are a "rattle fit" so no problem from that perspective. ;-T
I might still replace them if I don't like what I get when it goes back together as not a huge job
Offline v7john
    • The Racing Rhino
« Reply #7 on: January 08, 2015, 02:57:19 PM »
Hi tris.
I get my stuff from Stigs Stainless. They have the crinkle washers 11p each.
http://www.a2stainless.co.uk/M8-Crinkle-wavy-washer-DIN-137B-A2_AESG.aspx?nh=2
1954 BSA M33 500cc.
« Reply #8 on: January 08, 2015, 06:55:34 PM »
Hi tris.
Thanks, seriously good link, they've got M12 x 1.25 stuff in SS too, didn't know anyone did off the shelf, I've made my own in past.
Offline tris
« Reply #9 on: January 10, 2015, 05:04:15 AM »
Hi tris.
Good spot John - I'll give them a coat of looking at!
