Author Topic: Center Stand: Cali II vs G5 (and Swingarm)  (Read 8262 times)
Offline Groover
    • Scooteropolis
« on: January 12, 2015, 12:56:01 PM »
Hello, does anyone know what the difference is between the center stand between the California II model and an 81 G5? They look identical, and from what I understand, both models have the same frame - What's the difference?
The Cali II part number is: 29430300
The G5 part number is: 18430360
Also, can the swingarm from a California II be mounted on the G5? I think (not 100% sure though) that the Cali II has an indentation on the swing arm to fit a 120/90/18 tire, whereas the G5 doesn't have that indentation - Are they the same otherwise?
Thanks for the assistance!
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Re: Center Stand: Cali II vs G5 (and Swingarm)
« Reply #1 on: January 12, 2015, 01:50:40 PM »
Centerstand is the arm is abit different.
Swingarm on Cal2 is longer than G5 and has a stiff bar across in front of tire. I run a 130 on my Cal2 rear or 5.10.
Offline Groover
    • Scooteropolis
« Reply #2 on: January 12, 2015, 03:03:13 PM »
Thanks for the reply. Is the difference on the stand to fit the muffler cutout maybe? Do you think I'll I be able to use the Cal2 stand on the G5 with OEM mufflers?
I didn't realize the Cal2 had a longer swingarm - does that mean the wheel base (distance between front axle and rear axle) is different on the cal2 vs the other Tonti frames? (T3, Convert, G5)
Thanks again.
1980 Vespa SI Moped
« Reply #3 on: January 12, 2015, 03:10:46 PM »
Should fit, no cutout on Cal2 mufflers like on G5/T3
Wheelbase is longer front and back of bike.
Offline Groover
    • Scooteropolis
« Reply #4 on: January 12, 2015, 03:38:58 PM »
Ok, thanks again - sorry, one more questions and I'll stop, I promise! The G5, convert, T3 have straight mufflers, whereas the California II, SP, etc. have upsweep mufflers. Can the upsweep muffler be mounted on the stock G5, Convert headers/crossover, or would those need to be changed to mount the upsweep type mufflers?
1980 Vespa SI Moped
« Reply #5 on: January 12, 2015, 05:35:04 PM »
I have seen them on your model, crossover should work. Might have to modify brackets.
Offline Groover
    • Scooteropolis
« Reply #6 on: March 02, 2015, 09:08:32 AM »
I just wanted to do a follow up on this for other in the future with the same question. The California II centerstand won't work on the shorter Tonti frames without some modifications. The Cali II stand is a little bit taller (maybe 1"), but the problem is that the middle brace (the tube that connects to two sides) is lower on the California II and it won't work on the shorter swingarm tonti frames because that brace hits the tire when the center stand is in it's riding position. The stand can be made to work if that center brace were to be moved up an inch or so. I'll post a photo soon comparing the two type.
1980 Vespa SI Moped
Offline Two Checks
« Reply #7 on: March 02, 2015, 09:53:36 AM »
The inlet on the upsweep mufflers is straight so the upsweep shouldn't matter with the SP x-over as it is short. The SPII x-over is the same and I have it on my Cal III with the upswept mufflers. Fits perfectly.
1987 1000 SPII "Il Duce' II"
« Reply #8 on: March 02, 2015, 12:13:57 PM »
Center stands will be different for some models as you have seen.  The one for the T5 is shorter, probably due to the 16" wheels.  It is really too short as it does not raise the rear wheel fully off the pavement.  One day I will fix mine, but, not today  :)
« Reply #9 on: March 02, 2015, 01:18:42 PM »
This.
I did a write up on the differences a couple years or so ago with pics of several variants lined up.  Side-by-side it's easy to see the overall length, cross brace placements and the types of kick bars in the different versions.  My conclusion then was that the long wheelbase stands interfere with SWB rear wheels, and that there are several styles of kick bars to suit your mufflers and personal preferences.
