Author Topic: Flywheel cleaning  (Read 20459 times)
Offline Allflatblack
Flywheel cleaning
« on: January 12, 2015, 02:35:00 PM »
The G5 that I am restoring had a previous owner who overfilled the transmission by a quart at least. Every seal was weeping as well as lots of oil out the pushrod tube. Clutch soaked, total mess. I ordered the 4mm clutch kit from stein dinse for A very good price. Normally I would just wash the flywheel and pressure plate with gas a few times and feel fine. I do have a kiln at work that I could then bake it for a while to try to burn all of the residual oil out. Overkill? 400 degrees for two hours?
Offline JoeW
    • The Guzzi Doctor
Re: Flywheel cleaning
« Reply #1 on: January 12, 2015, 02:52:09 PM »
I'm not a fan of washing parts in gasoline, leaves a nasty residue not to mention a bit of a fire hazard. I like acetone or brake parts cleaner. Baking it, i think is a bit much. If it were a porous material it might be a good idea but, steel doesn't usually absorb oil.
Joe Walano
« Reply #2 on: January 12, 2015, 03:25:56 PM »
Clean every tooth w/screwdriver, I use mineral spirits
« Reply #3 on: January 12, 2015, 06:19:49 PM »
Mineral spirits worked well on the ex Rocker Lemans V the the "dealer's" "mechanic" grossly overfilled. It's flammable, too.. but nothing like gasoline. I wouldn't...
Offline Rich A
« Reply #4 on: January 12, 2015, 06:22:12 PM »
Cheap vodka. Sorta non-toxic.
Rich A
« Reply #5 on: January 12, 2015, 06:24:37 PM »
Rich A
Too expensive. (Guzzi content)
« Reply #6 on: January 12, 2015, 08:40:30 PM »
Cheap vodka is great for windows. And freshens your breath. Purple degreaser and hot water (to rinse off the gasoline) looks like new.
Thanks guys.
Offline Tobit
« Reply #7 on: January 12, 2015, 09:18:12 PM »
Brake cleaner then straight Simple Green and a brush if needed.
Dad and I used gasoline to clean parts when I was a kid.  We got lucky.  Ever see a gasoline vapor fireball?
Roman, '86 LM IV
Offline normzone
« Reply #8 on: January 12, 2015, 09:53:42 PM »
You're supposed to run a bottle of that stuff through your new still for the first run to clean it out.
Online rodekyll
« Reply #9 on: January 12, 2015, 10:50:31 PM »
I take three bottles of cheep vodka and run it through a distiller to make one bottle of very pure alcohol.  I use it as a solvent and fuel -- it will chemically burn you to drink it.
« Reply #10 on: January 12, 2015, 11:39:41 PM »
 :+1  Mineral spirits.
Online rodekyll
« Reply #11 on: January 13, 2015, 12:06:12 AM »
Hi, Tom.
Offline normzone
« Reply #12 on: January 13, 2015, 01:06:53 AM »
Glad to know somebody can run a device around here...fruit wash through a pot still is my favorite, but it's not as cold here as where you live.
Online Perazzimx14
« Reply #13 on: January 13, 2015, 07:24:41 AM »
Why not just buy a gallon of denatured alcohol for $15.00? Much cheaper than 3 bottles of cheap vodka and more end product.
Or 18lbs of cane sugar, 1 packet of turbo yeast and 5 gallons of water. 7 days later you have about a 20% wine ready for cleaning up.
Offline boatdetective
« Reply #14 on: January 13, 2015, 12:33:54 PM »
You may want to check your proposed solvents for TCE (trichloroethylene). Highly carcinogenic...
Jonathan K
Marblehead, MA
1981 V50III "Gina"
2007 1200 Sport "Ginger"
« Reply #15 on: January 15, 2015, 01:06:28 AM »
Hi, Tom.
Aloha Dave!  I'm still around.  Work is limiting my time.  Looking at working for myself again.
