Author Topic: An Unnatural Sound  (Read 17758 times)
ChappyBoffins
An Unnatural Sound
« on: January 17, 2015, 12:49:27 AM »
Hello All,
I was wondering if you guys might have some insight into an issue I’m having with my 2012 Griso 8V SE. Every time i start the bike cold it makes this rattling/scraping sound. It only happens at startup. Besides this sound the bike runs perfectly.
I’ve had it since march of last year and I’m the second owner. When i bought it there was 11,500 miles on it now it has 15,500. It does sleep outside but never uncovered. Something to keep in mind if and when the helpful suggestions start flying, I have a rudimentary understanding of how the bike works but I am by no means a capable machanic. I am planning on taking it into my local dealer but I wanted to check in with you guys and see if anyone has had a similar problem.
Here’s a recording of the sound…
http://vid44.photobucket.com/albums/f26/merkaba998/Griso%20Sound_002_zps4ufv7aou.mp4
Thanks in advance for any assistance.
Offline jacksonracingcomau
Re: An Unnatural Sound
« Reply #1 on: January 17, 2015, 01:25:58 AM »
Possibly a deep sleep induced thing, try keeping it awake, maybe leave a radio on under the cover.
Or it could be starter motor not releasing, button sticky in the cold ?
Offline tonga2
« Reply #2 on: January 17, 2015, 02:12:27 AM »
I have the same sound every cold start (Norge 8v)
Hasn't really bothered me I guess I have learned to live with it.
« Reply #3 on: January 17, 2015, 02:28:41 AM »
That's pretty good audio and I think what you are hearing is the sound of the bendix retracting after the starter relay cuts out after four seconds and the starter spins down.
I have no idea of what history of bikes you have but to me that sounds perfectly normal. Perhaps I should post up an audio of my great chunk of shit starting when it's hot! You'd poop yerself! ;D
Really though, that's just what they sound like. Once the chains wear a bit you also will get a brief rattle as the tensioners, that have bled down, take up the slack but on my bike this disappears within a second or so.
Stop worrying and remember it has a rev limiter so there isn o need to be easy with the go-handle.
« Reply #4 on: January 17, 2015, 03:21:24 AM »
  That is only the sound of parts that are un-naturally dry of oil, pay it no mind.
« Reply #5 on: January 17, 2015, 05:33:45 AM »
Sounds Puurrfect to me ;-T
« Reply #6 on: January 17, 2015, 05:46:30 AM »
Sounds like a normal 8V rattletrap engine to me. Welcome to the Forum.
« Reply #7 on: January 17, 2015, 05:56:29 AM »
The correct terminology is bricks fornicating in a tumble drier Steve.  ;-T
Offline Waltr
    • Europa Macchina
« Reply #8 on: January 17, 2015, 06:25:27 AM »
  Nothing to worry about.  I love Pete's descriptions of the sounds these bikes make, especially how his Griso with the open exhaust sounds at idle.  Something like a hippopotamus gargling marbles.
www.motoguzzipa.com
2012 Norge
« Reply #9 on: January 17, 2015, 06:54:28 AM »
Yep..
« Reply #10 on: January 17, 2015, 09:06:34 AM »
I wish my Stelvio was that quiet when it started.  ;D
Sure sound let the starter bendix just spinning for a second when released. My EV and Stelvio both usually do that.
« Last Edit: January 17, 2015, 09:07:14 AM by Wayne Orwig »
Offline fanattic
« Reply #11 on: January 17, 2015, 09:38:03 AM »
Sounds pretty much like mine too.
BTW, you do know to press and release the starter button right? Not press and hold like most other vehicles.
Strange that the Griso has a press and release button, but my Norge does not. It's a press and hold. (both are 8V).
2013 Norge
2012 Griso SE
1981 R100RS
1966 R60/2
1976 RD400
Online John A
« Reply #12 on: January 17, 2015, 10:04:32 AM »
It is completely normal, there are some minor things that can affect it. One is the speed at start, if it is low the starter drive may not clear itself from the flywheel teeth quickly. The drive is disengaged when the flywheel spins faster than the starter drive.Things like temperature ,engine tune, battery voltage, starter current draw etc. Not something you want to pay someone to try and fix as it's not really a defect,just an operating characteristic.
Offline Cage Free
« Reply #13 on: January 17, 2015, 10:30:40 AM »
I think it was MCN that said that the 8V in the Stelvio sounded like a small diesel at idle, and after listening to mine they are right.
ChappyBoffins
« Reply #14 on: January 17, 2015, 03:18:56 PM »
You guys are awesome and hilarious. Much appreciate the feedback. Whew, good to know it's not a big deal. I've only had the privilege of owning this bike since 03/2014 and it didn't start making this noise until it got cold here in middle TN (November-ish). Just wanted to make sure my baby wasn't suffering ;)
Thanks again everyone!
Offline 1Sourdough
« Reply #15 on: January 17, 2015, 09:19:08 PM »
I have neither started, nor listened closely when near someone else starting one.  Does the ECU control the starter, or why does one press & release the start button?  That's sorta cute...
1993 Strada 1000, 1996 R1100RT, 1999 V11 EV
                            -30-
« Reply #16 on: January 17, 2015, 10:21:14 PM »
You do have a certain way with words Pete.... ;D ;D
Offline johnr
« Reply #17 on: January 18, 2015, 03:58:16 AM »
I'd get hold of a car box or something  and make a little house for it to sleep in.
New Zealand
« Reply #18 on: January 18, 2015, 06:19:52 AM »
The way it worked on the earlier bikes is that you touched the starter button and it triggered the relay to the starter. The ECU's logic dictated that if the engine hasn't started in four seconds it drops the relay out. Also if the crank speed exceeds 500rpm it also cuts the relay.
I think later bikes have returned to a more conventional press and hold system but they still kill the relay feed if the engine speed exceeds 500rpm.
