Author Topic: For you Convert lovers  (Read 5271 times)
Offline steven c
« on: January 25, 2015, 08:14:58 PM »
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline yogidozer
Re: For you Convert lovers
« Reply #1 on: January 26, 2015, 06:35:36 AM »
Thanks!
Online chuck peterson
« Reply #2 on: January 26, 2015, 12:23:48 PM »
one of the best reviews of a Convert I've ever read...thanks ;-T
oddly enough, the writer "gets" a Vert...how strange ;D
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
« Reply #3 on: January 26, 2015, 03:07:21 PM »
A little sloggy to read through but as stated above, the author 'gets it' about the Convert better than most.  The one part I think he missed was the reasoning behind low gear.  He says it's to enhance engine braking at high engine speeds (translate -- you run a few rpm higher in low range which makes the engine brake effect more pronounced.  The same road speed in high gear gives more of a 'coast effect' with a heavy flywheel.)  I say it's to keep oil pressure and voltage up in slow traffic.  He also implies that you use the clutch in a traditional way.  It's not a conventional guzzi BB clutch and it's not used like you would with a 5-speed.
Otherwise it's one of the better period reviews I've seen.
Offline bigbikerrick
« Reply #4 on: January 26, 2015, 03:21:10 PM »
Excellent , very well written article, Thanks Steven.
Its true that the writer "gets it" what the  convert is all about.  My Cal II auto , is my favorite bike to use on slick roads, with the sticky shinko tires, and smooth power delivery, its in its element.
Rick.
