Author Topic: UFI filters. Should I use them  (Read 21810 times)
Offline groundhog105
« on: January 28, 2015, 09:55:08 PM »
I have a couple of UFI filters and am doing a service but I thought people have posted some major problems with them. What is the opinion of you guys with a lot of experience with these filters in the older bikes using filters inside the sump.
Offline balvenie
Re: UFI filters. Should I use them
« Reply #1 on: January 29, 2015, 03:06:21 AM »
          The problem you might be referring to, is that of the oil filter unscrewing in service. The fix involves attaching a hose pipe clamp around the filter. There has been so much written about it on WG that a search will almost certainly find it easily ;D
Edited to add
Having said that it was easy, I thought I should try it myself
wildguzzi.com/forum/index.php?topic=398840
reply #7
« Last Edit: January 29, 2015, 03:16:36 AM by balvenie »
Oz
04 Cali
Online Perazzimx14
« Reply #2 on: January 29, 2015, 04:58:35 AM »
Don't use them! Send them to me an I'll properly dispose of them for you.
« Reply #3 on: January 29, 2015, 06:10:58 AM »
I've used up my stock of them, and won't be going back. Spotty quality control. Bad gaskets. Poor paint prep.  :pop
Edit: Oh, forgot. Leaks around the crimp.
« Last Edit: January 29, 2015, 06:21:00 AM by Chuck in Indiana »
RogerGuzzi
« Reply #4 on: January 29, 2015, 06:29:07 AM »
What is the best alternative to the UFI brand? Can someone post a link please? Thanks!
Offline CalVin2007
  • fickle old fool
« Reply #5 on: January 29, 2015, 06:40:27 AM »
    http://www.autozone.com/1/products/340760-oil-filter-bosch-3330.html
   Terry
'07 CalVin
 '79 TT500
 '78 SR500
 '80 SR500
Offline menzies
« Reply #6 on: January 29, 2015, 06:57:11 AM »
FWIW Bosch is all I use on my car/truck/bikes, I buy them at Wal Mart.
2001 Triumph Bonneville
2007 Triumph Bonneville
2006 Triumph Scrambler
dilligaf
« Reply #7 on: January 29, 2015, 07:08:41 AM »
 :+=copcar Perazzimx14 is not an authorized UFI disposal person.  I am, so send them to me.  ;D  :BEER:
Matt
« Reply #8 on: January 29, 2015, 07:11:23 AM »
You can send the UFI small block filters to me..  ;D
« Reply #9 on: January 29, 2015, 07:51:58 AM »
« Reply #11 on: January 29, 2015, 08:47:15 AM »
No, send them to ME!   I have the proper disposal method that will take the evil out of them.
I screw them onto the bottom of my Guzzi motor and let them decontaminate themselves while I travel 6,000 miles or so, then take them off and they're safe ....
Offline twhitaker
« Reply #12 on: January 29, 2015, 08:52:33 AM »
Mobil 1 M1-102 is a good switch from the longer UFI.
'97 Centauro yellow 25,000 mi
MGNOC-11168
Dayton, OH
« Reply #13 on: January 29, 2015, 09:07:35 AM »
DO NOT USE THEM.
Send them to me immediately. I will test them for you and send you a report in about a year...
Just a friendly service that I provide.
Online Perazzimx14
« Reply #14 on: January 29, 2015, 09:58:59 AM »
DO NOT USE THEM.
Matt
i see you mothers never taught you to share  ::(
« Last Edit: January 29, 2015, 10:02:16 AM by Perazzimx14 »
« Reply #15 on: January 29, 2015, 10:01:10 AM »
Your...your..  ;D :BEER:
« Reply #16 on: January 29, 2015, 10:03:43 AM »
Ok,  I got the message. Thanks for the help. I should have done the search before posting instead of after.  I really appreciate everyone input
Offline mgfan
  • Escaping the "home"
« Reply #17 on: January 29, 2015, 10:39:51 AM »
Never mind all your greedy fellow countrymen. As a step towards better international relations send them north of the border !   :BEER:
« Reply #18 on: January 29, 2015, 02:13:54 PM »
 ;D  Sneaky attempt at an oil thread avoided by the members of the forum.   :-*
Offline Groover
    • Scooteropolis
« Reply #19 on: January 29, 2015, 04:26:51 PM »
Is this a regular problem (with the UFI)? That's what I have in mine now, should I be worried?
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline Moto Fugazzi
    • Griso
« Reply #20 on: January 29, 2015, 08:11:10 PM »
I just picked up my V11S from a local dealer after some service work, and he gave me a free oil and filter change. He took off the hose clamp that I put on the last oil filter, and now I'm contemplating dropping the sump and adding the clamp. I also need to install my Roper slopper plate I purchased a few years ago as well…might be a good time to do that.
Has anybody here actually had a UFI filter loosen up on them and cause loss of oil pressure?
Ken
Ken
2004 V11 Cafe Sport
2009 V7C White
2007 Griso Black-Sold
1978 V50 II Blue-Sold
Online rodekyll
« Reply #21 on: January 29, 2015, 08:16:52 PM »
my ufi problems have been a sloppy gasket and leaky seams.  One seam issue was maybe caused by poor paint in the seam area.  There was a split at the seam and the area was rusted after about 2.5k.  The other had no such defects -- straight up seam failure.  The leakers were all externally mounted, so the failures were caught early.  I'd hate to think of what might have happened in they failed in the sump where the leaks wouldn't have been detected until the next time the filter was changed.
« Reply #22 on: January 30, 2015, 07:04:44 AM »
Ken
Oh, yeah. Greg Field was the first to report it when he was at M.I. as well as I can remember. There were several. That's where the hose clamp stuff started. I think they were bad gaskets, but that's only a guess. I had a leaker on the Norge, but wouldn't have known it if it was inside the pan. I've had two glue themselves to the Mighty Scura that I had a devil of a time removing. Gasket again.
The Bosch 3330 is a decent, not great filter according to tests, but it is common automotive filter, and if they had these problems it would be immediately obvious. People don't like their new car dripping on the floor.  ;D
dilligaf
« Reply #23 on: January 30, 2015, 08:03:46 AM »
All the loose filters I have heard of were all second hand info from this forum.  I have never found a loose filter and, to my knowledge, a factory bulletin warning of loose filters and recommending a hose clamp, has never been issued.  However, if you can stand the added weight, a hose clamp will provides piece-of-mind.  A simple adjustment to the suspension should compensate for the additional weight.   ;D  :BEER:
Matt
father guzzi obrian
« Reply #24 on: January 30, 2015, 08:15:29 AM »
Some folks just don't read the packaging..... the delaminating paint is not a problem, UFI realized modern oils do not contain enough ZDDP, so the paint used is high in ZDDP, the natural delamination assures that your engine receives not only the filtering it needs (of the paint chips) but that little extra dose of ZDDP, er, at least that's what I thought it said..... ~;
Offline Crusty
« Reply #25 on: January 30, 2015, 09:21:41 AM »
I've never filtered my UFI. It works just fine without filtering.
'07 Norge
Offline Spuddy
« Reply #26 on: January 30, 2015, 10:31:42 AM »
OKAY: Bosch 3330 appears to be a universal filter for auto applications plus many other motorcycles.  Question I have is the Bosch 72161 [cross referenced tot the 3330] a better filter because of its increased length?
'13 Stelvio NTX
'07 California Vintage
'01 W650
Offline Dean Rose
    • Twin Valley Riders
« Reply #27 on: January 30, 2015, 11:41:31 AM »
http://bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1869907
http://www.calsci.com/motorcycleinfo/FilterXRef.html
« Last Edit: January 30, 2015, 11:45:57 AM by Dean Rose »
Magnolia '02 EV
Sophia '06 Breva 1100
