Author Topic: Longer Shocks On Lario Cafe Racer  (Read 7877 times)
reo
« on: February 01, 2015, 01:31:44 PM »
Hello.
I want to raise my Lario cafe racer build with longer shocks. Will increase to 14 "/ 14.5" (366 / 368mm)
Anyone know how much I can improve? Thinking of the angle of the swing arm and drive shaft.
REO
Re: Longer Shocks On Lario Cafe Racer
« Reply #1 on: February 01, 2015, 02:24:37 PM »
No idea but Ed from guzzipower.com has a Nevada scrambler frankenbike with rear shocks at least that long. The frames and other components are pretty simular but bear in mind he did raise the front with long forks & bigger wheel and is prob running more sag than your cafe
Offline kevdog3019
« Reply #2 on: February 01, 2015, 02:39:58 PM »
Hello.
REO
340mm is about it for clearance issues with the lower frame member.  I did that with my cafe Lario build and it worked great.  To even it out you'll also need to drop the fork tubes through quite a ways.  Mine performs way better in the stability department than my stock bike.  I'm also not affected by side winds but don't know why this is exactly.  Didn't realize this until my buddy kept talking about it on a ride we did, then realized I felt nothing when I got back on the bike.  Maybe it's lack of body work??  Strive for a straight line on the sump bottom.  That's what I did and seems to work great.  Also, I'd measure your distance for the 340's to those frame members as not everyone can go longer.  My shaft is still in line.  I got Hagons and like them. Best.
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
reo
« Reply #3 on: February 04, 2015, 11:45:33 AM »
Great.
Thanks.
REO
