Author Topic: Bassa bulb blown, socket slagged - Anybody know upgrade socket & bulb P/N ?  (Read 14586 times)
Offline normzone
Haven't ridden for a couple of weeks, got it out yesterday, then today again.
Yesterday it sounded fine. Today at lunch I noticed the left plastichrome throttlebody cover is broke off. Oh well, I have the emesis pan to make another pair from. Actually, I've got two. If somebody needs one let me know.
On my way to lunch the exhaust note sounded louder on the left. I chalked it up to a loose earplug.
On the way home from work it got louder and louder - there also seems to be a lessening of throttle response, although I'll be damned if I can define it properly. So I get home thinking things like exhaust baffle burglars.
The back of the pipes look no different than usual. I guess I'll ride it some this weekend and try to figure out WTF.
« Last Edit: February 18, 2015, 03:17:04 PM by normzone »
Re: Baffled: Bassa bugling - baffle burgled? Blown?
« Reply #1 on: February 04, 2015, 08:12:41 PM »
Norm old man , check the nuts where the pipes connect to the heads , and then check the muffler and crossover connections . The "Baffle Burglar" went extinct in the 1930's  ;D
Offline radguzzi
« Reply #2 on: February 04, 2015, 08:41:44 PM »
Norm,
Yup, as mentioned, check all the exhaust nuts and clamps.  Bet you'll find some loosening has happened.
Intake also, the intake runners and clamps.  Lemme know if you need another set of eyes/ears on the Bassa.
Best,
Rob
08 Norge 1200 GT
04 EVT
01 V11 Sport
'99 EV Hack
'76 V1000 'Vert
'86 LeMans 1000
'80 SP 1000 Two (2) actually
2013 Harley FLHTC
'75 Triumph T160 Trident
'78 Triumph T140V Bonneville
'76 Honda CB550 Four
'88 Honda Hawk GT
'84 RZ350 KR
'71 Dalesman Trials
'68 VW
'73 MGB
The Journey is the Reward
Offline normzone
Re: Baffled: Bassa no longer bugling - but bulb blown?
« Reply #3 on: February 13, 2015, 10:25:18 PM »
The thought plickens.
To see if I could go for a ride tomorrow with [radguzzi], I woke up the bike again to see if the exhaust leak would further identify itself.
Nothing. Gone. I am going to chalk it up to an earplug coming loose. I can't think of a cause for an intermittent exhaust leak. I took it up on the freeway for a few miles and got on it - worked great.
But the headlight is about dead - it comes on, but so dim as to be useless. I have the driving lights to fall back on, but it's not my ideal.
And the brights indicator has been coming on intermittently for a month now, initially going away after a few miles, but now on at the startup  and stays that way, regardless of the switch setting. So the new theory is that the exhaust leak sound may have been a symptom of the headlight going out.
So I'm going for a ride tomorrow. Maybe being around some well behaved Guzzis will be good for the bike - I've seen it work with horses anyway.
« Last Edit: February 13, 2015, 11:28:26 PM by normzone »
« Reply #4 on: February 14, 2015, 12:34:00 AM »
If you have a busted baffle (is that possible with your cans?) it can intermittently rattle in and out of position and change the sound.
That's all I've got.
Offline Don G
« Reply #5 on: February 14, 2015, 03:47:51 AM »
you likely have a head lamp ground problem, pull the headlamp and check the plug, I would bet that the plastic plug is melted. DonG  8)
Online fotoguzzi
« Reply #6 on: February 14, 2015, 07:31:48 AM »
huh?
« Reply #7 on: February 14, 2015, 07:56:31 AM »
:+1
The sockets have a habit of melting, you can pick up another at any auto parts store, throw away the lamp as well the pins are likely burnt.
Online John A
« Reply #8 on: February 14, 2015, 11:11:12 AM »
You can get a high temp version of the headlite connector. Sometimes at Napa or BMW mc dealer. The exhaust may be cracked at the crossover
« Last Edit: February 14, 2015, 11:12:41 AM by john A »
« Reply #9 on: February 14, 2015, 11:22:10 AM »
huh?
 Norm inhabits an alternate reality where zucchinis are a source of energy  ;D
« Reply #10 on: February 14, 2015, 02:24:29 PM »
You HAVE heard of the zucchini battery, haven't you?  It's like the potato battery only greener.  Line up an acre of them and you can power a 3-transistor radio (AM only).
« Reply #11 on: February 14, 2015, 03:26:56 PM »
 Well of course , but in Norm's world the zukes are REALLY large and used kinda like water buffaloes , and not the 2 smoker type  :D My understanding is that they were efficient , but lacking good attachment points , the harness kept slipping off  :D
Offline normzone
« Reply #12 on: February 14, 2015, 09:06:37 PM »
Actually we solved the harness slippage problem using wasp venom to make attachment points swell up. Unfortunately when the rest of team took the buyout from big agriculture / farm equipment manufacturers to kill the Recumbent Modified Zucchinni project, all that technology was destroyed. We couldn't do it over again any more than we could put an Apollo on the moon today.
But I had a great ride with Rob and John today. I haven't had a ride like that for twenty five years. Those boys are fast.
Or I'm slow. Or both. Beautiful day and roads. I saw a couple of nice raptors, a bunch of sky divers behaving like raptors, a host of old technology in a loving environment. Rob's posting pictures.
Offline normzone
Re: Bassa bulb blown, socket slagged - Anybody know upgrade socket & bulb P/N ?
« Reply #13 on: February 18, 2015, 03:23:20 PM »
Well, this is a confusing thread to read, but a man must find his small entertainments in life.
So many of you told me that the ground contacts would be oxidized, or the socket melted, that I followed the exhaust leak sound up into the headlight shell and guess what I found?
You were all correct.
So, instead of kluging a fix, which I could do with my teeth and some tape, I thought I'd ask if anybody knows the P/N for an upgrade socket, and best source for same.
Or I could skip the socket, go to female spade terminals. The socket is an AMP part.
And is there a more bitchin' bulb I can drop in there without having to add relays, circuit breakers, and flag men to the line? Are additional electrical mods required or just advised?
Thanks all - you guys are so cool that my wife is coming around to the idea of yet another Guzzi in the house.
« Reply #14 on: February 18, 2015, 03:38:35 PM »
The more bitchin the bulb, the more it's a bitch.  Higher output halogens have a shorter lifespan and are more susceptible to vibration damage.  Other solutions, as you've noted, require more stuff to install and make work.  It's one of those things that you have to throw time, money, and effort into.  I'm not understanding why this is an issue for you though.  You're looking at the same effort to install a new type of light as it takes to repair the old one -- kind of like replacing your old chrome bores with new chrome bores.
A NAPA ceramic plug will do as well as anyone else's.  You'll still need the odd sized female 'flag' connectors, since yours are undoubtedly softened by heat.  You might ask for a pre-wired one.
« Reply #15 on: February 18, 2015, 03:54:03 PM »
Personally I wouldn't go for a ceramic, I think it's a good thing to melt the plastic if the contacts starts generating heat, at least you have a warning, yes get a pre-wired one, throw the old bulb away, the contacts are probably arced and will compromise the new socket. Add one headlight relay to the bucket it's the biggest Lumen booster you will get for your $1, use an old one from the bike if you have swapped them out. Make sure you have a good ground to the lamp, I like to run a wire back to the main chassis.
« Last Edit: February 18, 2015, 05:46:24 PM by Kiwi_Roy »
Offline Carlo DeSantis
« Reply #16 on: February 19, 2015, 05:00:01 AM »
NAPA p/n LS6235 is what I've used.  Connector with fairly heavy leads ready to splice into your original wiring.
Best,
Carlo
« Last Edit: February 19, 2015, 05:04:10 AM by Carlo DeSantis »
Chuck in Illinois
Crystal Lake, IL USA
'75 850 T3 Custom
'11 R1200R
Offline normzone
« Reply #17 on: February 19, 2015, 09:43:29 AM »
Sweet! Thank you much.
Is the bulb a special Guzzi device, or a readily available automotive crossover?
« Reply #18 on: February 19, 2015, 09:51:48 AM »
Standard H4.
Get a Sylvania Silverstar bulb for a LITTLE more light output. Carry a spare bulb because they have a short life span. Well, and it is a good idea to carry a spare no matter what.
« Reply #19 on: February 19, 2015, 09:52:05 AM »
It may be, but I just use a regular car type, then what do I know?
I try to avoid riding at night otherwise I would likely upgrade the headlight.
