Author Topic: Looking at Le Mans Mk1 Project  (Read 21968 times)
Offline swooshdave
« on: February 08, 2015, 09:26:45 PM »
I'm looking at this bike. Engine is out and I haven't seen it so I don't know how apart it is. "Parts are all there" but we know how that goes, if they aren't on the bike you will never know.
The big question: How much to offer for it? I tried to trade a Porsche 914 for it and he wouldn't go for it.  ;D
« Last Edit: February 08, 2015, 11:18:47 PM by swooshdave »
2001 V11 Sport
Offline swooshdave
Re: Looking at Le Mans Mk1 Project
« Reply #1 on: February 08, 2015, 09:54:01 PM »
The Airhead went down the road on it's side. I'm putting it in the "No Thanks" category.
2001 V11 Sport
Offline swooshdave
« Reply #2 on: February 08, 2015, 10:07:26 PM »
I'm just looking for some sort of guideline from the experts.
2001 V11 Sport
« Reply #3 on: February 08, 2015, 11:20:05 PM »
I would work backwards from what a bike in concourse condition would be worth and how much it would take to get this bike to that shape. Top dollar for a restored MK1 Le Mans is probably $16 ~ $20K. This bike has been apart at least once, obviously the frame has been painted, ditto the wheels. Mechanical condition? missing parts? A full mechanical rebuild of the engine, transmission, rear drive, carbs, brakes etc.. can easily pass $6K, then there are the cosmetics, what happened to the tank that the cast Moto Guzzi script is gone? the mounting recess has been filled in and the tank repainted. My guess is that bike will take at least $10K to get it to top condition so I would peg the value at $6K absolute tops. If you can and want to do the restoration yourself then $6K may be a good buy. Something tells me that the seller thinks that he is in possession of a much more valuable bike.
I try to buy the absolute worst example I can find or the very best. Buy a wreck and at least you know that everything will be rebuilt or replaced and budget accordingly. Alternately buy an original bike with known history, in good cosmetic condition and just mechanically restore it.
Offline swooshdave
« Reply #4 on: February 08, 2015, 11:23:32 PM »
Good stuff!
I wondered about the decal on the tank. I think I've seen them before in pics. Were they used on the earliest bikes? It has the Series 1 taillight. I don't know what the serial number means, is this one of the bikes that the distributor had to make the numbers match? I wish I could have gotten a look at the engine.
2001 V11 Sport
crc
« Reply #5 on: February 08, 2015, 11:33:26 PM »
also make sure it is a lm motor with correct top end
« Reply #6 on: February 08, 2015, 11:42:10 PM »
Every picture I have seen of a LeMans MK 1 has the cast 'Moto Guzzi' tank emblems. Perhaps the tank was damaged, repainted and the rectangular recess and pin holes were bondo filled or the tank is from a V7 Sport or a reproduction. The engine serial number and the serial number stamped on the ID tag should match if it is a US or Canadian distributed bike.
It is probably an original Series 1 Mk 1 LeMans but there are certainly clones out there, the seat, rear fender, side panels, tank and bikini fairing are all reproduced. Make certain it's an original before you commit. The 180mm triple clamp with the steering damper is correct, same with the bars and controls. Dash has been messed with, foot rests missing boot guards, no exhaust in the pictures, switches and ignition missing in the pictures.
Offline swooshdave
« Reply #7 on: February 09, 2015, 12:28:57 AM »
2001 V11 Sport
Offline Aaron D.
« Reply #8 on: February 09, 2015, 06:56:08 AM »
Fork caps are wrong. Also obviously the frame has been painted, so the tag has been off..what is the date on the tag anyway?
Engine number is key.
Cheese
« Reply #9 on: February 09, 2015, 07:03:03 AM »
071829?
Offline Rich A
« Reply #10 on: February 09, 2015, 09:17:09 AM »
I'd say $2500, $3000 tops. If you put $5000 into a rebuild, even doing a lot of the work yourself, I'd guesstimate that you'd have a $6-7000 bike. But the prices of these things are increasing.
Rich A
« Reply #11 on: February 09, 2015, 09:19:20 AM »
Agree with Rich.. I wouldn't spend over $3k for it. probably less even unless the motor looks perfect.
Offline swooshdave
« Reply #12 on: February 09, 2015, 09:21:31 AM »
I'm very fearful having not seen the engine. I could get in over my head pretty fast.
I will say I've only seen a few Le Mans and I'm shocked at how small they are.
2001 V11 Sport
Offline swooshdave
« Reply #13 on: February 09, 2015, 09:24:18 AM »
071829?
Yes.
Doesn't that put it at the end of the Mk I? Or at the end of the Series 1?
2001 V11 Sport
Offline PeteS
« Reply #14 on: February 09, 2015, 09:38:23 AM »
Rich A
+2. I might consider selling mine for 20K though. 8)
« Reply #15 on: February 09, 2015, 10:09:13 AM »
I'd spend $5K. And you don't have to bring it back to perfect shape in one big project, especially if you intend to ride the bike. Just fix the engine, go through the electrics and put that bike back together. Hell, that alone will increase the value and if you don't like it then sell it as is; I can't imagine you would loose any money on the deal providing you don't dump too many funds into the engine.
« Reply #16 on: February 09, 2015, 10:18:21 AM »
Dave , now you understand why I was asking about the beemer . The experts have suggested a range of $2,000 to
$6,000  ;D How much does the seller think his stuff is worth ?
Offline swooshdave
« Reply #17 on: February 09, 2015, 02:37:37 PM »
Nothing else was offered for sale. The only reason the Guzzi was up for discussion is because I've been pursuing it. So I don't have a good reference. But he's getting too old to ride a Le Mans and knows he'll never get to it.
2001 V11 Sport
Offline dsrdave
« Reply #18 on: February 09, 2015, 05:30:45 PM »
The early round tailight bikes are the most desirable.  They did not have the boot guards.  There are a lot of minor differeces between the first and second gen 850 Lemans.
Offline swooshdave
« Reply #19 on: February 09, 2015, 05:37:35 PM »
From what I have gathered the only way to know if it's real is by the engine serial number? Is there an issue with restamped numbers? Or is that not talked about?
2001 V11 Sport
« Reply #20 on: February 09, 2015, 05:48:18 PM »
Well, it's certainly easy enough to do. These aren't the highest tech data plates known to man.. <shrug>
Offline swooshdave
« Reply #21 on: February 09, 2015, 05:50:54 PM »
Does anyone have a picture of the engine serial number on this type of engine?
2001 V11 Sport
Morizzi
« Reply #22 on: February 09, 2015, 05:56:52 PM »
« Reply #23 on: February 09, 2015, 06:12:10 PM »
This is the stamping on a V7 Sport, the V and the K are a larger font size than the numbers, note the random stamping of the stars before and after the engine number
Courtesy of This Old Tractor - identifying frame numbers:
http://www.thisoldtractor.com/guzzitech.dk/gb_en_technical_moto-guzzi-frame-numbers.htm
Blank reproduction frame tags and rivets are available from several sources, the stamp dies are also readily available so an unscrupulous seller could reproduce a frame tag. I f the frame tag look new then it may well be new, ie a re-stamp.
« Last Edit: February 09, 2015, 06:18:15 PM by canuck750 »
Offline swooshdave
« Reply #24 on: February 09, 2015, 07:13:45 PM »
As you can see the frame plate does not look new.
2001 V11 Sport
« Reply #25 on: February 09, 2015, 09:32:20 PM »
Engine number should begin with a "VE".  I recently bought an 850 LeMans (series 2) with a higher number like this one.  It's a US imported bike.
Offline mantaray
    • mantaray.zenfolio.com
« Reply #26 on: February 10, 2015, 03:15:25 AM »
91xxx is ok for a mk1
saturday i am looking at  920xx range nr , also 1.1
the tacho on "your bike" is 1.2, early tacho's reading till 8.000rpm ( in europe)
speedo is 1.1
« Last Edit: February 10, 2015, 03:19:14 AM by mantaray »
In our stable:
Moto Morini strada 74 and 75, Ducati 696,
White Moto Guzzi LM 850 1978 and Iceblue first series Le Mans 850
More pics
http://mantaray.zenfolio.com
Offline swooshdave
« Reply #27 on: February 10, 2015, 11:51:10 AM »
speedo is 1.1
There is a list of changes on this page. I'm not sure where the 1.2 change happened. Tach apparently changed at 12500.
2001 V11 Sport
Offline PeteS
« Reply #28 on: February 10, 2015, 12:08:48 PM »
I think its a pretty safe bet it started life as a LeMans. That ID plate looks original. If the engine number matches the plate that should confirm it. I still wouldn't pay big bucks for it though.
Offline youcanrunnaked
« Reply #29 on: February 10, 2015, 04:50:34 PM »
I would work backwards from what a bike in concourse condition would be worth and how much it would take to get this bike to that shape. Top dollar for a restored MK1 Le Mans is probably $16 ~ $20K....
A correct Mk I Series I LeMans (assuming that's really what this is), is NOT a $16,000 - $20,000 bike.  Maybe in another ten years, but not today.  It's a $10,000 bike; maybe $12,000 if all-original -- which this one will never again be.
