Author Topic: Is there a comparable substance like thread lock for electrical connections?  (Read 13611 times)
Offline kevdog3019
I've got some old spade type connectors on the Lario that pull off quite easily. Also, the neutral switch connection that slides into place also finds its way off. Wondering if there's some product that gives them some holding power without taking away the connection?
'86 V65 "Super" Lario
'85 Honda Nighthawk 700s
'86 V65 Lario
Maybe but a small blob of solder on the end so it has a hard time sliding back through (?)
crc
I normally crimp the female spade carefully with pliers
If they won't bend back down with pliars (and stay that way) they've softened, probably from heat.  In that case they should be replaced.  But no, there's no thread locker level of cure.
Rough Edge racing
 Crimp on type connectors vary greatly in quality,.....T&B brand found in some electrical supply houses are usually high quality. Online vendors like Mouser have thousands of different types, many are specification grade.
I may have misunderstood the question.  If these are standard crimp connectors and the wires are pulling out, as RER said above, you need high quality connectors and a professional ratchet type crimper.  AMP is the brand I use, but as I said in another thread, I solder after crimping for several reasons.  It keeps moisture out of the connection, it ensures low electrical resistance, it eliminates the chance of pull-out, and if you solder at the wire tip and don't linger too long, the solder won't wick down the wire and make a stiff spot.
« Last Edit: February 18, 2015, 08:02:17 AM by Triple Jim »
Offline acogoff
     The female spade connectors that they came with are real junk. after only about 25 years they corrode and loose tension. That's a joke, but they do break-lose tension with age.
 They are easily replaced. Invest in a crimping tool- I think even Menards has them.
« Last Edit: February 18, 2015, 08:21:40 AM by acogoff »
Marshall County Minnesota USA
Offline mtiberio
    • TiberioRacing
dielectric grease
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
I have had the same problem and tried various solutions, like bending with pliers and adding some solder.  They work for a little bit, but, fail in a thousand miles or less, and usually when you can least afford it.  If you are on the road and have to fix it to get home, then crimping  with pliers will usually get you there.
Replace the connectors.  I carry some extra ends with me on the bike.  I have modified part of the wire cutter portion of my Leatherman to be able to crimp them in emergencies (I replace and properly crimp when I get home).
PS I do not use one of the expensive ratcheting crimpers.  When only doing one or two at a time, the cheaper ones have worked well for me.
dilligaf
dielectric grease
Will not solve a loose electrical connection problem.  :BEER:
Matt
Offline kevdog3019
Well, the hopes for a "sticky" solution seem unlikely. I want these removable as they are switched connections. Nothing that won't keep the bike from running. I don't want to hard solder them. I may have to get clever if it keeps happening. Most are fine and will only come off if I'm fiddling in the area. The neutral connection is plain loose as is a weird one. I may have to bend the female end is all. Too bad they don't make something like thread locker for bolts. I suspect we'd be cursing the PO's if they did.
Thanks all.
'86 V65 Lario
Bend them with pliers a little bit to tighten then back up.
I misunderstood twice.   :D   Kevdog was saying the connectors pull off the make tabs they connect to, not the wires as I thought he meant.  Yes, Wayne and others above are right on.
Offline Goosecoop
Hey Kev,
A friend of mine bought the kit from Vintage Connections which included the crimping tool. We used it the other week on a vehicle that we are working on that had the same problem. Worked really, really well. Check it out at www.vintageconnecti ons.com.
Mike
Mike
Frederick, Colorado
'89 Cal 3
'74 Eldo
'06 Mini
There's always conductive epoxy, but once in place, it'll stay in place forever...  ;) ;D
Bill Havins
Matt
Sure it will.  It will always "read" as "not making a connection."  You won't have any doubt.  :D
Offline kevdog3019
Hey Kev,
Mike
Thanks Mike, looks promising!
'86 V65 Lario
I say replace 'em. they are worn out.
biking sailor
Might try liquid solder products.  I have and worked pretty well at keeping electrical spade terminals from vibrating apart.
http://www.ehow.com/about_4779321_liquid-solders.html
Online RinkRat II
  • Lake Powell AZ
Yo Kevdog, Belden makes a couple of different crimping pliers just for that purpose, kind of a multi tool for plugs, spade connectors and specialty connectors. Sorry don't have a link but Google Belden and  Voila.  ~;
     Paul B :BEER:
