Author Topic: what parts do you wish were still made?  (Read 44756 times)
Online Groover
    • Scooteropolis
Re: what parts do you wish were still made?
« Reply #30 on: February 19, 2015, 02:22:59 PM »
All badges for all models.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline NCAmother
« Reply #31 on: February 19, 2015, 02:57:58 PM »
LeMans straight cut close ratio transmission
Howdy
Offline keuka4884
« Reply #32 on: February 19, 2015, 04:18:34 PM »
1.1 kg return springs for VHB carbs.
1978 850 T3
« Reply #33 on: February 19, 2015, 04:19:57 PM »
Stock OEM Mufflers for G5, Convert, 850T3
Wish granted, top of the page here: http://www.motostoricheitaliane.com/EN/guzzi-1.html
Online Groover
    • Scooteropolis
« Reply #34 on: February 20, 2015, 10:39:02 AM »
I guess I should have said "CHEAP Stock OEM Mufflers for G5, Convert, 850T3"
There goes one of my wishes.  ;)
(Thanks for linking!)
1980 Vespa SI Moped
« Reply #35 on: February 20, 2015, 11:29:00 AM »
They're probably "cheap" (made), just like the originals. Seams that rust, none too thick metal and typical Italian chrome. Too quiet (even for me) and rather restrictive.
Offline ritratto
« Reply #36 on: February 20, 2015, 06:32:57 PM »
Headlights ears for V7 Sport and the like!
1978 G5
1998 Centauro ( oppsidaisy!)
2003 V11 LeMans
« Reply #37 on: February 20, 2015, 07:30:48 PM »
Oh yea. The "middle" weight spring.  I'm pretty sure I found the last four pair on the planet a few years ago - and I searched long and hard.   A small shop over in England had them.  Still sitting on two pair.
Offline Lee Bruns
« Reply #38 on: February 21, 2015, 12:44:02 PM »
cheap cheap cheap, I want gold, but I want it cheap, chea cheap cheap I want small batch parts, for off rband bikes, but cheap My time is worth everything yours os worth nothing My skills have value, yours should be free, Why won't anyone make cheap high quality for my bike and do it for less than the cost of materials? Cheap cheap cheap
« Reply #39 on: February 21, 2015, 01:04:34 PM »
Here's one I just thought of: 4 spd., 4th gear bushing. Used my last new one in a customer's trans. today, don't seem to be available anywhere. Interested in making a batch, Lee? Looks like this:
Last they were available, the cost was $95.
Offline Lee Bruns
« Reply #40 on: February 21, 2015, 01:37:52 PM »
looks pretty straight forward. Can you pm me some dimensions and tolerances?
« Reply #41 on: February 21, 2015, 03:52:55 PM »
Will do, when I get a chance.
Offline keuka4884
« Reply #42 on: February 21, 2015, 04:22:26 PM »
Cam
Finding those springs would be like finding a few boards of Cuban mahogany. I have looked at every Dellorto and Guzzi parts site for them to no avail. If you should want to part with a set sometime before I mount the PHF 30's I'll put you in my will and on my Christmas card list. You'd even get an invitation to my daughter's wedding in September at Heron Hill winery.
They also made .8 kg springs but I have read that the 1.1 kg variety is the lightest they should be.
I have googled 850 T3 for articles and reviews on it and come across MANY riders whose only complaint with the bike is those nasty, heavy springs.
One last try. Does anyone know a person who makes springs?
1978 850 T3
« Reply #43 on: February 21, 2015, 04:29:47 PM »
The springs Cam has are for Dellorto VHBs, so if you're using PHFs they won't work. Guzzino has three different weight of PHF springs: http://guzzino.com/thspphfphm30.html
Offline mtiberio
    • TiberioRacing
« Reply #44 on: March 05, 2015, 08:23:30 PM »
how about the plastic sleeves that go between the 30mm VHB carbs and the manifolds on 850Ts, T3s, SPs, Converts, etc...
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline mwrenn
« Reply #45 on: March 05, 2015, 11:30:51 PM »
Four Valve Lario and V75 small block heads.  With good valves this time!!! Lol
« Reply #46 on: March 05, 2015, 11:46:01 PM »
Yes.  I happened to get my PHF springs from Bevel Heaven.  They're the lightest of the three, and are exactly what I was looking for.  No sticking slides, and no tired wrist.  I have no idea why they weren't standard on Guzzis.
Offline frans belgium
« Reply #47 on: March 06, 2015, 04:50:56 AM »
Mine
Dean
 ;D
My first reaction, too.
Especially private ones, at 60+, upgrades are welcome   ;D
Owned and sold: V65, Nevada, 2xCali, Breva 1100, Norge 8V, Breva 1100 with Squire sidecar
Currently own: V85 TT
« Reply #48 on: March 06, 2015, 09:28:21 AM »
I've machined some out of Delrin for a customer, but it was time consuming for an amateur machinist like me with an old worn out lathe.
Offline mtiberio
    • TiberioRacing
« Reply #49 on: March 06, 2015, 09:35:24 AM »
better we learn to 3-D print them...
« Reply #50 on: March 06, 2015, 09:38:36 AM »
Any aftermarket wheels for my 95 Spot.
One of those passenger seat replacement filler panel things would be nice for the same.
While I'm dreaming: a "Euro" fairing and headlight too!
Todd.
« Reply #51 on: March 06, 2015, 09:42:18 AM »
I'll continue to just make them when needed, but if there was enough demand, I could have a local machinist whip out a 100 or so...
« Reply #52 on: March 06, 2015, 10:04:20 AM »
Anyone have a  photo?
Edit:  I found a thread on it:  http://wildguzzi.com/forum/index.php?topic=70199.0   What does this part actually do?  Does it take much load, or is it just a spacer?  If I can get the dimensions, I can 3-D print them.
2nd edit:  From the photo at the bottom of that thread, it looks like a 3-D printed version would work fine.   Does this sound correct?  I can get my son to print a couple Nylon ones in a matter of days is anyone is interested in trying them.
« Last Edit: March 06, 2015, 10:12:03 AM by Triple Jim »
« Reply #53 on: March 06, 2015, 10:15:57 AM »
It's mostly for heat isolation and to seal the carb body to the manifold. Load? The weight of the carburetor.
The issue I had with machining them is that if the o.d. was made to the specified 40 mm, when it was installed in the carb body, the i.d. ended up smaller than 37 mm and it wouldn't go on the manifold. I had to "fudge" the o.d. to get the required i.d.
After digging around in my stash recently, I found a n-o-s original which could be used as a pattern.
« Last Edit: March 06, 2015, 10:17:24 AM by Antietam Classic Cycle »
« Reply #54 on: March 06, 2015, 10:27:17 AM »
It sounds like the best way to have a chance of good printed parts is to get a carburetor body, plastic spacer, and "manifold" in hand.  Then I can try the fit of the printed parts and make slight adjustments until they fit correctly.  I'll get it done if someone is able to loan me the parts, which I'll return promptly.
« Reply #55 on: March 06, 2015, 10:36:48 AM »
I have the plastic spacer, but no VHB30 or manifold.
Offline Sheepdog
« Reply #56 on: March 06, 2015, 12:15:08 PM »
Affordable (<$2,000) cast or tubeless wire wheels for injected Californias. I realize that I can cob something together from used parts, but I would appreciate a specialist putting something together with new components...
Offline mtiberio
    • TiberioRacing
« Reply #57 on: March 06, 2015, 04:51:42 PM »
I have all the parts (one good sleeve, manifold, 30mm VHB), but it is cold and my garage is snowed in, and I'm not in the mood right now to go out there and find the parts to make this happen. PM me in a few weeks with your address... FWIW, there is an oring groove on the OEM sleeve that AFAIC is totally useless. These things couldn't leak air if you wanted them to.
« Reply #58 on: March 06, 2015, 05:49:11 PM »
Excellent, thanks very much.  I'll do as you suggested.  If you don't hear from me, it's because I forgot, not because I lost interest.  But I'll try to leave myself some reminders.
Offline T in NC
Re:
« Reply #59 on: March 08, 2015, 01:11:46 PM »
Comfortable seat for 2002 California Special Sport.
Steve Stamilio
