Author Topic: 1984 V65c Cylinder Head Rebuild  (Read 5538 times)
Offline magrahamkp08
« on: February 24, 2015, 05:25:46 AM »
Since I have the motor all apart, I figured I would rebuild it.
It appears you can't find the valve springs for the V65 anymore.  But the all knowing internet came up with a solution and I am looking for some more validation.
http://guzzista.wikifoundry.com/page/Older+Small+Block+Issues%3F
According to the internet, it says I can use the Nevada valve spring.  Can anyone verify replacing the two spring setup with the single setup from the Nevada?
Re: 1984 V65c Cylinder Head Rebuild
« Reply #1 on: February 24, 2015, 06:25:18 AM »
That's commonly done with the Lario.
Offline mwrenn
« Reply #2 on: February 24, 2015, 08:06:34 AM »
Yes, they will work.  You have to change out the top and bottom spring cups as well.  The Nevada springs are a little larger in diameter.
« Reply #3 on: February 24, 2015, 09:33:36 AM »
Thanks for the clarification.
