Author Topic: Michelin Macadam wet road performance?  (Read 8686 times)
Offline SED
« on: March 01, 2015, 01:06:05 PM »
Are Macadams slippery in the wet?
I've had the rear tire break loose twice accelerating out of corners.  It's a V50 Monza - so not exactly tire shredding power.  Both on wet roads during mist-light rain.  The first was accelerating out of an tight corner in 2nd gear.  The second accelerating in 2nd or 3rd on a winding road.  In both cases it felt very controllable and not a big deal - there was a little over steer, but reducing throttle brought it back in line with no drama.
Wondering if I've just hit oil patches or the tire is the problem.
I've been happy with the tires in every other respect and they have lots of tread left.
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Re: Michelin Macadam wet road performance?
« Reply #1 on: March 01, 2015, 01:48:14 PM »
 Had a set of Macs on a beemer , experienced the same thing . They are designed as a cruiser bike tire .
Offline SED
« Reply #2 on: March 01, 2015, 02:02:19 PM »
Thanks for the info Dusty.
So by "cruiser bike tire" do you mean that cruisers never get ridden in the rain or never go around corners?  ;D
« Last Edit: March 01, 2015, 02:22:25 PM by SED »
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #3 on: March 01, 2015, 02:08:59 PM »
So by "cruiser bike tire" do you mean that cruiser never get ridden in the rain or never go around corners?  ;D
 Oh SED , you know that I would NEVER say something derogatory  :o ;D
Offline Kai
« Reply #4 on: March 01, 2015, 02:13:54 PM »
Michelin has replaced the Macadam with the Pilot Active at least 6-7 years ago. Before, the Macadam was a typical „wooden“ tire for riders who payed most attention to economical aspects.
See the two slides as warning and get new tires. If the tread is still OK, flog it on Ebay, they will be sold
Spending my free time mostly with these Guzzis
Offline youcanrunnaked
« Reply #5 on: March 01, 2015, 02:16:11 PM »
In the sticky / hard tread balance, those tires are biased toward durability.  Harder tread means less sticky, especially in wet or slippery conditions.  Try to be smoother with the throttle in low grip situations; change to a stickier tire if you're still not satisfied.
Offline SED
« Reply #6 on: March 01, 2015, 02:21:23 PM »
Thanks for the replies.  I'll be looking for some tires!  ;-T
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #7 on: March 01, 2015, 02:22:27 PM »
Macadam was a radial tire; Pilot Activ is a bias-ply tire, so the latter did not replace the former.  Macadam is an older tire, though.
CORRECTION:  Macadam 50/50E was a bias-ply tire; Macadam 100 was a radial tire.  Both are obsolete.
If you want a Michelin radial tire with better grip in all conditions, with decent tread life, get the Pilot Road 4 tires
EDIT:  I think that with a Monza V50, you want a bias-ply tire to match the chassis.  I recommend the Michelin Pilot Activ.
« Last Edit: March 01, 2015, 02:29:10 PM by youcanrunnaked »
redrider
« Reply #8 on: March 01, 2015, 02:23:07 PM »
Avon Roadrider might work for you. They stick well on the Mille and last a long time.
Offline SED
« Reply #9 on: March 01, 2015, 02:31:56 PM »
Thanks Red,
Agreed.  I've got Roadriders on the Lemans and on both Ariels and have been happy with them - but the Ariels don't put down quite as much power as the Monza, and I seem to ride the Monza with a bit more confidence (cough  ;D) than the LeMans.
1983 LeMans III
1981 Monza
1937 Guzzi GTV
biking sailor
« Reply #10 on: March 01, 2015, 03:21:46 PM »
How old is the tire?
On the used GS I just picked up, I'm getting a bit of sliding around on the 6 year old rear tire that is barely worn.  It is better running lower air pressure than normal (dropping about 4 PSI).
