Author Topic: Cleaning out the suspension shelf , Shocks are cheap  (Read 5216 times)
Offline Curtis Harper
    • Harpers Moto Guzzi
« on: March 03, 2015, 04:18:40 PM »
I don't normally do this, but I have to move some shelving units and the stuff on them is in the way. So I am gonna put some stuff on the cheap.
Bitubo fork dampers and rear shock sets.
430057 V65 Lario Bitubo Fork dampner 3 in stock  Retail $265 Sale 175
430059 850T-5 Bitubo Fork dampner 3 in stock  Retail $265 Sale 175
430062 Cal II Bitubo Fork dampner 1 in stock  Retail $265 Sale 175
430068 V50 Bitubo rear shocks 2in Stock Retail 325.00 Sale 200.00
430070 V65 Bitubo rear shocks 2in Stock Retail 325.00 Sale 200.00
430078 LM 1000, T5, SP3, Millie Gt, 1000s Bitubo rear shocks 4 in Stock
               Retail 345.00 Sale 225.00
320207 MDI rear shocks 12.5" 2 instock retail $95 Sale $70
Doing this for wild guzzi only. Mostly because it's easy for me. Not going to find these on the website so best is to call me 800.752.9735 or PM or email curtis@harpermoto.com.
www.harpermoto.com
1-816-697-3411
curtis@harpermotocom
Offline Groover
    • Scooteropolis
Re: Cleaning out the suspension shelf , Shocks are cheap
« Reply #1 on: March 03, 2015, 04:22:22 PM »
I think you need to clean the shelf where you keep the Valtek mufflers and crossovers. I can call!
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #2 on: March 03, 2015, 04:40:25 PM »
Actually the supply of the Valtek Mufflers is running very thin and we may not reproduce them again. Actually just checked and I have one set left for the tonti bikes 75 to 85. So if you want a set, now IS the time.
www.harpermoto.com
1-816-697-3411
Offline Groover
    • Scooteropolis
« Reply #3 on: March 03, 2015, 04:45:55 PM »
... and I now own the last set! Thanks Curtis!
1980 Vespa SI Moped
« Reply #4 on: March 03, 2015, 04:46:24 PM »
And the play at the plate.........                 SAFE! with the last set !
www.harpermoto.com
1-816-697-3411
Offline mtiberio
    • TiberioRacing
« Reply #5 on: March 03, 2015, 04:55:53 PM »
will the lario v65 bitubo stuff fit a 35 mm big block front end?
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
« Reply #6 on: March 03, 2015, 05:03:45 PM »
Standard 35mm fork uses 29mm threads, lario uses 31mm. But a little time with a lathe, a couple beers and some JB weld, anything is possible. Also I think the rod length is different.
www.harpermoto.com
1-816-697-3411
Offline mtiberio
    • TiberioRacing
« Reply #7 on: March 03, 2015, 05:04:33 PM »
just add lario tubes...
« Reply #8 on: March 03, 2015, 05:08:29 PM »
Which I have in stock
www.harpermoto.com
1-816-697-3411
