Author Topic: Will a Bassa Tank fit a Jackal?  (Read 6841 times)
Offline Enrico Pallazzo
« on: March 06, 2015, 05:21:45 PM »
Now that I've managed to get my fiberglass Jackal side covers primed and wet-sanded, I'm feeling really cocky. I'm thinking of buying a tank so I can practice painting. Can anyone tell me whether a Bassa tank will fit a Jackal? For that matter, are there other tanks that will fit?
As might be expected, Ebay prices are all over the map. From a surprisingly almost-reasonably 80 bucks to insane and moronic three-digit prices which are much more like what I expected.
People who claim they don't have ten seconds to answer your stupid questions can always find several minutes to criticize them.
Re:
« Reply #1 on: March 06, 2015, 05:34:22 PM »
I believe as long as it's a tank from another external fuel pump Cali it should be plug and play.
Re: Will a Bassa Tank fit a Jackal?
« Reply #2 on: March 06, 2015, 05:36:22 PM »
Thanks. I think this will be fun, but I don't want to screw up the stock tank.
« Reply #3 on: March 06, 2015, 06:39:23 PM »
If it's a P8 tank it might have reduced fuel capacity compared to the jackal.  I'm not sure.
« Reply #4 on: March 06, 2015, 07:31:03 PM »
I am trying to figure out what P8 means. Is that the fuel injection system? I found a book on Google which says the California 1100s had a P8 system.
BigDave in PA
« Reply #5 on: March 06, 2015, 07:42:33 PM »
It should still work. The 98 EV was a P8 bike and the tank had the same fuel fitting as my '01 with the later computer. If I'm not mistaken the Jackal as well as the Bassa were all the later version.
« Reply #6 on: March 06, 2015, 07:44:19 PM »
 This  :+1
« Reply #7 on: March 06, 2015, 09:12:52 PM »
It will bolt up and the spigots will fit.  I think I read somewhere that the tunnel size is different.  I don't remember where I read it or which tank had the advantage.
Online fotoguzzi
« Reply #8 on: March 07, 2015, 06:59:08 AM »
Yes it will
Offline BillinPA
« Reply #9 on: March 07, 2015, 07:06:27 AM »
It will, If you need a tank I have  an EV tank,  A bassa tank. I also have a larger capacity Cal III tank that I was going to weld the spigots from another on to have a larger capacity on my EV. Never did it. Probably won't!
Offline Yeahoo Whoyah
« Reply #10 on: March 07, 2015, 09:49:53 AM »
http://sfbay.craigslist.org/eby/mpo/4919694942.html
Greg Tillitson
El Dorado Hills Calif.
